Question about Microwave Ovens
Turn table has stopped turning. - Microwave Ovens
    New Friend:
  • 21 Answers
Hi ann, electrical items can be very dangerous and sometimes fatal so please take care.
remove the plug from the wall and take the outer casing off and check to see if a drive belt has snapped or come off or see if any gears have been damaged. if it hasn't the motor may have gone that turns the table which if it has its probably best just to get a new microwave.
good luck
Posted on Apr 26, 2015
Microwave Inverter NN-ST651BB 1200W Works fine but the turn table still turn when I open the door.
Does the turn table ever stop? If not you need to either replace the oven or have it repaired, it is likely cheaper to just replace it.
Dec 06, 2016 | Microwave Ovens
Turn table will not turn
I'd check to see if the turntable motor has continuity. If it does, check to see if 120 volts is being supplied to it. If both are o.k., then the motor has probably bound-up in some way internally. There's also the possibility that it has mechanically become detached from the hub that turns the glass tray.
May 06, 2014 | GE Spacemaker JVM1640SJ Microwave Oven
The turn table stopped turning and the unit stopped heating.
the turn table stopped and the unit stopped heating.What should I do?
May 30, 2011 | Goldstar MV-1501 Microwave Oven
Hi, I have a Sharp R-254 microwave and the turn table turns for approx 30 seconds. After 30 seconds it stops and makes a clunking noise, if you open the door and manually turn the glass plate 1/4 of a...
Either the coupler that is located in the center of the oven cavity that the turntable sits on is defective or the turn table motor is defective. . Either repair is rather simple (coupler being the easiest) with parts available online.
Nov 11, 2017 | Sharp R-254 Microwave Oven
GE turn table microwave stopped warming food
my microwave 1640GB from GE suddenly cannot heat food and make some noisy sound. as it is mounting in the closet, it is not easy to replace. any solutions or suggestion
Mar 18, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Ge microwave xl1800 has stopped spinning
if the microwave still heats then the turn table motor will need to be replaced.. very easy repair
Jan 19, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Turn Table wont turn
if you can check the turn table motor for resistance. 90 percent would be a broken motor which you could replace. just look for the motor at the bottom of the microwave and race the wire back to the pc board.
i hope i was able to help..
pls rate me
tnx,
drcool
Jul 19, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave Oven EM-804T
You need to trace the power feeding the high voltage transfomer. Because the table doesn't turn, it implies that a door switch or safety interlock is the problem.
Jan 01, 2008 | Microwave Ovens
Microwave Ovens Logo
49 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
