Question about Halonet 98-02 HONDA ACCORD 4DR POWER FRONT WINDOW REGULATOR W/ CABLE TYPE, W/ MOTOR
Flat battery cant open doors with remote ,cant open door manualy with key
Cant open doors due to flat battery
    New Friend:
  • 21 Answers
Hi kayne, is it possible to open the boot with the key and climb through to get access to the bonnet release catch.
good luck
Posted on Apr 26, 2015
Audi central locking
Lock ALL DOORS, Disconnect the Battery... Wait 2-3 minutes and connect the battery and it should reset itself. Make sure all doors are LOCKED...
AND that you have a KEY to open the door in case it does not work.
Feb 12, 2014 | Cars & Trucks
I have a 2005 JGC 5.7 hemi and sometimes remotes wont work only when you want to unlock it.If you use the key to open door alarm sounds. what could be the problem?
Have you tried a new battery in the remote, or do you have a second remote you can test. Either your remote is worn out or the battery is dead.
Once you lock the car with your remote it will active the alarm and if you use your key it won't deactive the alarm only your remote will, on some cars putting the key in the ignition will deactive it.
If you can deactive your alarm with your remote and can just manualy lock and unlock your doors and that should prevent your alarm from going off until you get a new remote or battery.
Aug 05, 2011 | 2005 Jeep Grand Cherokee
Whenever i unlock my camry manualy ( key in the door ) the alarm goes off. Also if i open the back door before the front door the alarm goes off. I have to use the remote key or i cant get into my car and...
this is due to a bad switch in the drivers door, when you use the key to unlock the door it should shut down alarm, also the alarm module may be going bad, the alarm is setting itself on, when ever you lock the door the alarm turns on, you will need to replace the switch on the drivers door or unlock the passenger side door that also has a switch that disarms it, the switch is on the lock itself, thats the problem you are having , good day,
Apr 15, 2011 | 1997 Toyota Camry
The battery in the key died does this mean the car cant be started?
CAN BE SO. BUT GENERALLY IS DUE TOO THAT C-LOCK DOSENT DISCONECT THE IMMO-ALARM WHEN YOU OPEN THE DOOR MANUALY,
Sep 26, 2010 | 2002 Mitsubishi Eclipse
Alarm is going off but couldn't unlock doors with remote; opened door with mechanical key but can't start the engine; battery is old- would the battery failing cause these events; do the remote keys go...
Depending on the type of vehicle you can but not usually. The alarm would have tripped off due to the battery going flat thats why you could not open the doors with the remote, or switch the alarm off.
The only way you can disengage the alarm is to remove the alarm relay and bypass it.
But unfortunately we can not give you this type of information as it can be used in a ' negative way ' or thieft of vehicles.
But for you, just fit a good battery and then you should beable to switch the alarm off with the remote.
Hope this helped.
Jason
Jun 19, 2010 | Cars & Trucks
Battery flat, cannot open doors key not working on
If your key will not manualy open door
Try it in boot lock,it might activate central locking
Feb 24, 2010 | 2000 Porsche Boxster
Left solstice in garage 6 months when i whent to open door battery was flat had to open door with key manualy alarm whent off since then car does not drive well any sugestions
Hi
Have you put new fuel in the car? fuel left for 6mths wont be very good. and most likely will need a service, new plugs etc etc, change the oil and check the battery connections.
Hope this helps
Regards
Dan
Feb 13, 2010 | 2007 Pontiac Solstice Convertible
1990 accord ex power door lock
I don't think is the modual control due to the fact if it would be your control modul then it would not open anyway either using your key to unlock. My feeling on this is that either your connection on your alarm is not sending the right voltage to the unit and therefore you are not getting the signal. I would check your connection in your alarm unit and then if that is not the problem, I will replace the modul. Hope it helps!
Sep 08, 2008 | 1991 Honda Accord
SEARS/CRAFTSMAN 53628SRT Not Closing properly
sounds like the safety door sensors are at fault,also did you reprogram the remotes by pressing the smart button on the logic board,when the safety sensors are bad the door will reverse to open state.you can pully the rip cord to manualy close the door untill you solve the problem.
Sep 04, 2007 | Sears Craftsman LiftMaster Chamberlain...
Halonet 98-02 HONDA ACCORD 4DR POWER FRONT WINDOW REGULATOR W/ CABLE TYPE, W/ MOTOR Logo
1,116 people viewed this question
Top Halonet Scuba Diving & Snorkeling Experts
Tom Chichester
Bill Boyd
micky dee
Are you a Halonet Scuba Diving and Snorkeling Expert? Answer questions, earn points and help others
