This error code is about your connection to the PSN. Somewhere you are losing the communications between your PS3 and the PSN. You've probably heard this a million times, but check your internet speeds.
press 0
U2 if 04 occurs EEPROM read/write error (serial communicationerror)
if 11 occurs Counter check sum error (EEPROM)
if 12 occurs Adjustment value check sum error (EEPROM)
if 40 occurs CRUM chip communication error
uninstalled the program, downloaded the latest trial version from Sony (25 da trial) and recovered the files without errors. I will try to repair my own version later.
Thanks for your reply.
80029945 - Can’t playback burn BDr movie (error in picture above) 80029946
- Attempting to play burnt Dual layer NTSC disc on a Pal ps3 (workarouns
is to transfer files to ps3 via TVersity) (added 24th Sept 2007) 80029301
- An error occurred during the delete operation (attempting to delete some
ps2 homebrew from virtual mem card) (added 15sept2007) 80029516 -
Sign in to PLAYSTATION-Network (needed for some games or Ps3 processes
- have to sign in to use them) (added 04-sept-2007) 80710A06 - An
error occurred during the install operation (error when downloading game
from PSN - network error occured (added 30thAug2007) 8003041F - An
error occurred during the copy operation (using media server) (added 27aug2007) 80010006
- An error occurred during the start operation (added 22aug07 -
corrupted folding install) 80010007 - An error occurred during the
start operation (added 17aug07 - during disc swap tests)
Error 232
Severity
16
Error message text
Arithmetic overflow error for type %s, value = %f.
Explanation
This error occurs when Adaptive Server detects an arithmetic overflow error during execution of a SQL statement. Arithmetic overflows occur when a variable has too few places to store the converted data. In particular, Error 232 is raised when an overflow occurs for a variable of datatype float.
Error 232 can occur during execution of the convert function. It can also occur during implicit conversion within Adaptive Server, either during a stored procedure run or during execution of a SQL statement which converts a float value to some other datatype.
Action
Determine which variable is causing the problem based on the datatype reported in the error message output and the SQL statement on which the error occurred. If the error occurs within a stored procedure, an additional error message will be displayed showing the name of the stored procedure and the line number where the error occurred.
Increase the size of the variable that is causing the error. If it is in a procedure, re-create the procedure.
If this error occurs on a Sybase-supplied system stored procedure, contact Sybase Technical Support.
Versions in which this error is raised
