Question about Poulan Garden
Poulan pro xt675 4x4 lawn mower When I engage the wheels the mower goes to fast, how can you slow it down?
    Top Expert:
  • Poulan Master
  • 45,431 Answers
There is ink to customer support they might know User Manuals
Posted on Apr 26, 2015
  • 86 Answers
SOURCE: my lawn mower will not stay started
Since it starts, it doesn't sound like an electrical problem, it sounds like it runs out of air. To test this, remove the air filter, start it and see if it stays running. If so, replace the air filter.
It could also be varnish or sludge in the carb bowl. This is best serviced by a technician if you have little mechanical prowess.
After sitting for 3 years, I would at minimum do all of this before I expected it to run ok:
  1. Change the oil.
  2. Replace the air filter.
  3. Drain the fuel tank by removing the fuel line from the engine end (not the tank end).
  4. Replace the spark plug.
If the above did not work I would drop the carb bowl and clean it, then add one ounce of carb cleaner to a full tank, and let it run (roughly if necessary) through the engine.
After sitting 3 years I would also replace the fuel line itself!
Posted on Mar 29, 2009
mowerman1857
  • 389 Answers
SOURCE: Poulan lawn mower, Briggs Stratton engine, revving problem
Most likely problem is dirt?moisture in the carburetor float bowl. You would have to remove the bowl, clean it out and also clean the main jet up in the center of the carburetor. Another problem could be that the governor is out of adjustment but this is not something a novice could or should do
Posted on Sep 14, 2009
rwvanlue
  • 486 Answers
SOURCE: craftsman self propelled walk behind lawn mower
Normally grass and debris are clogged under the belt/transmission cover, preventing the full engagement of the transmission cable/lever.
The cover is located on the topside, left front corner of the mower shell. Clean debris, try it again. If OK, re-install cover, If not, there is a cable adjustment (threaded portion with a nut on either side of a fastening arm) move the cable adjustment towards the rear, this will tighten the cable. Sometimes the cable assembly (includes the cable and the control box) needs to be replaced
Posted on Nov 08, 2009
  • 10 Answers
SOURCE: My Self-propelled push lawn mower
try putting new bail one it and see what that dose 9 out of 10 that's what is
Posted on Aug 04, 2010
lolaisbk
  • 3 Answers
SOURCE: Why is there no manual for Poulan Pro lawn Mower
here is the manual for PR650Y22PRK
http://www.hardwarestore.com/media/pdf-misc/124361.pdf
Posted on Apr 17, 2012
Poulan pro lawn mower will start with pull. Will NOT start with KEY
Take key switch out and look for damaged or broken parts or replace switch.They will come with new key.
Jun 11, 2016 | Poulan Pro 22inch 625 Series Briggs ...
I have a Poulan Pro 30 414 snow blower.When I engage my self propel handle the wheels do not engage
might handle cable not be pulling far enough on drive engauge arm ? cables do stretch ya know
Feb 03, 2015 | Poulan Garden
To much slack in pull cord on poulan pro push lawn mower
u need to remove the recoil assbly and restring.remove recoil and cut not out of string.remove line.rotat the coil assbley counter clockwish till spring presser is tight.hold it in place and reinstall cord threw eye whole tie new not and let off recoil slow.slack should go away.
Aug 19, 2013 | Poulan Pro PR550N22SH 22Inch Briggs ...
Poulan pro 625 lawn mower idles slow and rough
Try changing your plug and check gap and put in some fresh fuel. Empty out the old stuff especially if it has been there a while. Also check your low idle setting on the carb open it up a half turn for starters. Good Luck...
Aug 27, 2011 | Poulan Pro 22inch 625 Series Briggs ...
I have a 42 in poulan pro riding mower that keeps cutting off while mowing the lawn
safety switch on seat, are you bopping or are you going to fast for the mower slow down speed kills ha ha , other than that get it serviced maybe, try going slower they are not v8 mowers , hope this helps ,, keeps cutting off means it does start again yes
Jun 05, 2010 | Garden
Can't push my self propelled lawn mower!
Remove the drive wheels and have a look at the gear teeth in them. If even slightly worn, they need replacing. If you run the mower with the wheels off, that end elevated with a block, see if the axle turns when you engage the drive. If it does, your transmission is fine. Wheels are a lot easier to change than a tranny.
Sep 11, 2009 | Poulan Pro " Pro" Self Propelled Mower
Poulan Pro riding mower jerks in forward and the blades engaged
This is a lawn mower catagorized as a chainsaw. We don't answer lawn mower questions ands you don't cut down trees.
Mar 23, 2009 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Garden Logo
106 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
