Excessive drum movement and noise
The front rubber is being worn away by the excessive drum movement and the drum seems lower in location than normal. I have checked the springs and they have not broken.
    New Friend:
  • 21 Answers
Hi nick, it will be the bearing on the drum that's at the back of the machine.
Posted on Apr 26, 2015
Whats wrong with Dryer
The drum slides at the front are made of felt. Yours have worn away. The drum is banging up and down. If you open the door you will find that you can lift and lower the drum. If you drop the drum, you will hear it bang. They are easy to replace if you can get the front off the machine.
It could also be that the rear drum bearing is worn, but that doesn't normally make a banging noise. It is a metal spindle attached to the drum into a nylon sleeve in the back of the machine.
Nov 04, 2015 | Dryers
It is makeing a lot of noise
Hello. You didn't provide a brand/model number or the type of noise the unit is making. If the dryer is making a screeching noise, it's probably the idler pulley(spring-loaded tensioner pulley that keeps the drum belt tight so the electric motor can turn the drum properly) being worn out or binding up due to lint build-up in the dryer. However, if the dryer is "thumping" loudly, most likely it's a worn out support roller either on the front or rear bulkhead. They're made of hard rubber and can become malformed due to wear/age causing a rough movement of the drum as it spins.
Aug 18, 2015 | Dryers
My Kenmore dryer model #110.9757 is making a loud noise
DRYER MAKES NOISES.
A loose or worn BELT can make funny noises
Or the idler pulley that puts tension on the dryer drum drive belt could be worn out. If the pulley is bad we recommend also replacing the belt.
The glides on drum worn and making metal to metal contact.
The drum slides or glides support the front of the drum. As the drum rotates over the years, the glides wear out and then the dryer makes noise. Replace all of the glides as a set if they are worn out.
CHECK FOR LOOSE BELLOES inside the drum
Sometimes an item can get stuck inbetween the drum and the housing and scrape and grind making funny noises, things like coins, bra wire, nails, hair pins, etc sometimes u can just remove the cabinet and observe by turning the drum by hand or looking for scratch or scrape marks on housing.
The blower:
Clumps of lint, socks, and other small articles of clothing can get past the lint filter and into the blower wheel. If the dryer makes noise, and the noise seems to be at a very fast pace, there might be something caught in the blower wheel. In addition, the blower wheel sleeve might be worn out, allowing the blower wheel to wobble on the motor shaft. If this happens, replace the blower wheel.
The bearings:
The drum bearing supports the rear of the dryer drum. If the dryer makes noise this bearing might be worn out. Replace the bearing if it is worn out. Do not lubricate the bearing, the lubrication will attract lint and dirt and accelerate the wearing process.
The bearings TEST by moving drum by hand u may be able to feel loose or rough movement. And listen to sounds when turning it.
The drum rollers or castors:
It is very common for dryer drum rollers to wear out. If the dryer makes noise, particularly a loud rumbling noise, one or more of the rollers may be worn out. After removing the drum from the dryer, inspect the rollers.
Check for cracks, dryness, or damage and not engaging drum properly. Sometimes u can use high density LITHIUM BASE gear grease to re oil/grease them.
GOD IS GOOD !!!!
Oct 07, 2014 | Dryers
When the machine goes to top speed it's banging x
There are three reasons for a spinning washing machine drum to knock:
  1. It is out of balance owing to an unevenly balanced clothing load, with possibly a belt buckle, button, or other hard object knocking from within the drum.
  2. A drum suspension support has worked itself loose and needs re-tightening
  3. A worn or partially split drive belt or possible crack in the pulley wheel
A solution to number 1. is simply to distribute the wash load evenly.
Solution no. 2. will require removal of the rear carcass cover to access the drum suspension connections. Sheet metal screws are the usual fasteners for this cover. First unplug the electrical supply. Get someone to roughly force the drum to move laterally side to side and up-down, from the front of the machine, while you look and listen from the rear, for signs of looseness at suspension joints. A perished rubber bushing may have partially disintegrated so look for signs of black rubber dust or debris. Another rare possibility may be excessive play in the bearings which support the drum. Excessive play in the bearings---if severe---may be felt again through very gentle lateral drum movement, but first proving no play exists in the suspension joints beforehand, otherwise confusion will result.
Solution No. 3. requires inspection of both drive belt and drum pulley wheel for any signs of wear or cracking. First have someone rotate the drum by hand from the front of the machine while you check out the belt and pulley---mind your fingers! If you still haven't located the source of the noise, try running the machine empty of water through its spin cycle while you observe from the rear. Keep your hands well clear of moving parts while doing so.
Jan 05, 2013 | Washing Machines
Washing machine is jumping around on the spin cycle
A few possibilities here.
Make sure the washer is level, both back to front, and side to side.
Do not over load, and make sure that there is more than 1 article in it, otherwise you will get an out of balance load.
Make sure the water is drainlng away properly.
Check the drum for excess movement, this would indicate a broken spring or worn drum bearings or worn or broken drum shaft.
Check the concrete wieghts at the top and bottom are not loose or broken.
Check the suspensions for excessive wear.
Hope this helps
Mar 31, 2010 | Maytag Performa PAV2200
Machine making a loud noise in spin cycle. We
Inspect the outer drum to see if one of your springs has popped off. You can also inspect the lower drum area to see if your vibration dampener has worn out or broken free. Also you may need to check your rear bearing just between the large pulley and the drom to make sure is hasn't separated from it's mount.
Mar 02, 2010 | Frigidaire ATF6000ES Front Load Washer
We have a whirlpool duet washing machine that is about 7 years old. During trhe spin cycle it makes a loud noise. Not the typical "airplane noise." There is also an odor. A burning engine odor. If you...
The rubber belt is worn and slipping under load. (like a fan belt)
There could also be something caught in the belt or pulleys; clear it out and it should work.
If worn, replace belt soon...
Hope this helps!
Sep 15, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Dryer noise
A drum support wheel bearing could need lubrication or be replaced.  Also some drum support wheels have a rubber coating that wears off causing misalignment and noise.  Possibly drum gasket (sometimes felt material) where drum meets rear panel is worn allowing metal-to-metal contact--should be replaced.
Jun 02, 2009 | Maytag Atlantis MDG7400AW Gas Dryer
Whirlpool Front Load Washing Machine is very Noisy when spin
if it make noise like a train coming in on track,,,bad tub bearing,,,do you see any water leaks back there ..on the back tub or on the base of unit...if so seal damage,,
Dec 31, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Very loud banging noise when spinning
sounds like a balance problem may be when the drum was replaced they didn't fit the new drum in the correct spot the other thing that would cause load banging and excessive vibrations in the machine is if the shockers are worn out,
believe it our not even washing machines have shockers to dampen the movement of the drum spinning
Dec 19, 2008 | Indesit W 123 Front Load Washer
Washing Machines Logo
52 people viewed this question
Top Washing Machines Experts
