Question about Vacuums
Just out of box and all I get is red light - Vacuums
    New Friend:
  • 21 Answers
Hi patricia, if its cordless try charging before use, if its corded take it back for exchange.
good luck
Posted on Apr 26, 2015
My Sebo X4 does not switch on, when powered up two red lights flash momentarily. There was a buzzing from the black box underneath but that has now stopped. I changed the bag yesterday as it said it w
Your red lights flashing momentarily is normal start-up. The fact that your servo motor is operating tells you that you are getting power. If the vacuum motor does not turn on, you likely have a problem with the motor itself or the power supply board that feeds power to the motor. These items should be covered under warranty. However, if your vacuum is outside the manufacturers warranty, you can replace either of these parts fairly easily with only a phillips head screwdriver.I have included a link to the parts list for this machine. We do stock both parts. http://sebo.us/pdfs/website_schematicsPDFs/AUTOMATIC%20X%20Schematics.pdf
Sep 24, 2014 | Sebo X4 Extra Bagged Upright Vacuum
I LOST MY REMOTE CONTROL, INSIDE THE LIGHT THERE IS A PLASTIC HOUSING WITH CIRCUIT BOARD AND DIP SWITCHS THERE ARE SOME NUMBERS ON THE OUTSIDE, FCC NO CHQ8BT7051R MODEL NO UC7051R SERIAL NO...
i got a new remote switch box to put inside the fan, wiring in the lights was a snap but i have a red pink grey and yellow wire that control the fan and i should have tested the wires before i unplugged and re wired the light because the fan was running on low speed when we flipped the switch on thewall sending power to the fixture itself now i suppose there are only 16 different combonations to send power to the fan unless you factor in that maybe the red and pink are high and low respectivly and grey is "close" to black and yellow is white then you gotta have a switch to go high or low, God save us all and bless the person who can tell me what the other 4 wires go to
Apr 18, 2011 | Vacuums
I am installing a ge #15070 basic timer and there are 3 wires. Which wire do I attach to the ground?
GE 15070 timer does not have ground wire.
I assume this timer is double insulated, just like some power tools and electronics only have two prong plug.
Leave bare ground wire attached to other bare grounds in the box, and shove grounds to back of box.
I have one of these timers installed.
Timer has red, black and white wires
http://waterheatertimer.org/GE-timers-and-manuals.html#15070
How to wire GE 15070 timer:
1) Switch has 2 insulated wires. Take switch wires and connect them to timer-black-wire and timer-red-wire. Choose either one for now.
2) In back of electric box are white wires twisted together and covered with wire nut. Connect timer-white to these wires.
3) If electric box does not have white wires described above, then connect timer-white to bare ground, along with timer-green wire.
4) Turn on electricity, and slide switch to ON-or-OFF. If lights come on, timer is wired correctly. If lights do not come on, then reverse timer-red and timer-black wires.
5) Add a comment for more free help.
6) Also take advantage of fixya phone service.
For a price, fixya expert speaks with you over phone while you work on timer or any do-it-yourself project.
Jan 13, 2011 | GE Vacuums
The Red light indicator of full box is on although the box is empty. Would not take in paper
I am a bit puzzled by the category your question is under:
VACUUMS--
I am puzzled what vacuum 'takes in paper'?--
Maybe you have a paper shredder?
Please give us some more information--- maybe we can help then.
Mack B
Jan 10, 2011 | Vacuums
I have a broken chain switch that will not allow me to use all four light sockets. presently only using two sockets. Question: can I by pass the switch by combining all the black wires from the leading...
The blue should be for the lights and you can ty this into the black. The red should be the incoming for the motor to the fans. Some models are different and I strongly believe you have got to be talking about a ceiling fan and not a vacuum. Is this a test question? Because it is a darn good one if you do not mind me saying so however you might have not noticed to check or uncheck a box for the fans. Good luck.
Nov 02, 2010 | Vacuums
Bought new battery roomba 540 still have problem it stats then stopps red light on left goes on and it wont move
This happens when the Cleaning Head Module needs cleaning. You will need to open its gear box and remove all debris that are found inside.
Sep 21, 2010 | Roomba Robotic Floor Bagless Vacuum
Status light is red, why? I have a Roomba Discovery.
Hi.
If the red light is solid, that means that the Roomba is near to full discharge. If the light is flashing red, then the Roomba is completely out of charge.
If the Roomba is fully charged, then there may be a fault.
Here full list of light codes:
Pulsing Amber - Charging
Green - Fully Charged
Amber - Partially Discharged
Red - Almost Fully Discharged
Flashing Red - Fully Discharged"
Here manual
See also
Roomba DISCOVERY MODELS' DIAGNOSTIC TESTS
May 24, 2010 | Vacuums
Battery does not seem to fit machine
the light only shows that its plugged in, it wont shut off when its fully charged
Jul 03, 2009 | Vacuums
Low tire light stays lit.
If there is a red reset button in the fuse box, press & hold till your air pressure light flashes off....do this with the key on, engine off
Jan 09, 2009 | NexxTech 611-8212 Handheld Wet/Dry Vacuum
Vacuums Logo
46 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
