Question about Kenmore 52642 / 52644 / 52649 Side by Side Refrigerator
Kenmore 52649 side by side
Our power went out. I have a portable generator hooked directly to the power box. When I threw the breaker to bring up the refrigerator, I got a let down then surge up of power. Since then, the unit runs but with very little cool and no freeze. Can you help?
  • twosweets Nov 14, 2007
    I unplugged the unit for 30 minutes and replugged. The unit has power, interior lights, underneath fan, etc. The unit is cool on the bottom (crisper area and lower freezer), but certainly not cold.
  • twosweets Nov 15, 2007
    There is ice in both sides, freezer and refrigerator, in the lower quarter. Still require repair?
    Sergeant:
    Champion:
  • 306 Answers
Try unpluging it for about 5 mins. Sounds as if it might need to recharge the coolent, Possibly during the surge might have blown an internal fuse. Contact the manufacturer. Curently their site is down.
Posted on Nov 14, 2007
  • cory casper
    cory casper Nov 14, 2007
    yeah its going to need serviced/repaired.
Sparking in power box when we use the generator and trips the braker
When you say "power box" do you mean the main breaker box in your house? Is the generator hooked up to the breaker that you say trips when the generator is on? There is a short somewhere. First check the generator. Is it running OK. In other words if you plug something into the generator receptacle directly, does it work? If the generator itself works properly, then check the wiring from the generator to the circuit breaker. DO NOT use the generator until the problem solved = safety first.
Jun 12, 2014 | Cars & Trucks
Schematic
most 3 in 1s come with a diagram. as for the factory style you can order a new relay and capacitor from Sears or on the web.
Jan 21, 2013 | Kenmore 52642 / 52644 / 52649 Side by Side...
Why is there only power coming out of one side of the 30 amp outlet not both
Check that you have power on the generator side of the circuit breaker, check each leg to neutral and you shoudl see 120V approx. If you still only see it on one side you have a bad stator. if you see it on both legs measure across them L1 L2 and you should have 240V, then check again on the receptacle side of the breaker, if you don't have it you need a new breaker
Oct 27, 2012 | Coleman Powermate Premium Plus 6250W...
Where is the breaker box on 1998 travleze trailer
All travel trailers and motorhomes have different set ups, but the majority of them install the breaker box in the generator compartment, even if it doesn't have a generator installed.
Jan 01, 2012 | General Electric GE ELECTRICAL TQD22200X2...
My husky 5000w generator wont produce power
Usually when generators do that it is because they were hooked up to too great of a load and that took out the diodes...
heatman101
Aug 18, 2010 | Coleman Powermate Subaru 5000W Portable...
Portable generator pops breaker when temp is over 75 degrees
I take it you have RV plugged into generator. Hopefully direct with no extension cords. Are you using a 30 to 15 amp adapter to plug into generator? What is the rating of the breaker on the generator that keeps tripping, suspect it's only 15 amp?
Jul 20, 2009 | Dometic Rooftop RV Air Conditioner
McCulloch fg6000mk: generator motor runs, no power.
You need to trace out the power wires the come out of the genset. They will end up on a breaker. With a volt meter measure both sides of the breaker. If one side has voltage and the other side doesn't, then your breaker is opened. Press the breaker in closed to see if it actually closes. If it don't then you will need a breaker. However, if no voltage is being produced, it is possible that the voltage regulator let go.
Apr 11, 2009 | McCulloch 13HP 338 Cc Portable Generator #...
I can't remember if you plug in the generator to the electric panel first (with power turned to the generator and off of the main line feed) and then start the generator, or start the generator and then...
OK, by talking about a plug, I am assuming you have made a double male plug to hook the generator to the electric panel. This is not really advised, because it is so easy for it to be plugged into an outlet by someone not knowing what it is far, and getting electricuted. Now, away from preaching, and to helping.
It is best to hook it to the generator and then crank it, so you are not dealing with a load when you plug the systems together. When your power is restored, it would be good to install a plug to your electrical box and have it go to a disconnect like is on your outside A/C unit. It moves you away from the hot wires.
Hope your power is on soon!
Dec 21, 2008 | McCulloch 13HP 338 Cc Portable Generator #...
Kenmore 52642 / 52644 / 52649 Side by Side Refrigerator Logo
87 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
