Question about Garden
I have just topped up my mountfield sp470 lawnmower with oil and petrol and know it's just stopping with smoke coming out the engine what could be the problem
    Top Expert:
  • 10,875 Answers
Too much oil or oil in gas
Posted on Apr 26, 2015
5 Suggested Answers
mowerman1857
  • 389 Answers
SOURCE: How do I replace primer bulb on mountfield SP470
I believe this mower has a Briggs & Stratton engine, if that is the case:
Look at the base of the primer bulb where it is mounted on the carburetor, you will see an opening on both sides of the plastic that the bulb is mounted in where the locking tabs are.
Take two small screwdrivers, press in on the tabs and pry toward the outside of the housing at the same time to release the tabs and bulb. Pull the entire bulb and mounting ring out as an assembly. Don't worry too much about damaging the ring, a new one should come with the new bulb, in fact, it would be wise to purchase the new bulb prior to beginning so you can see what you are working on
Posted on Nov 03, 2009
Testimonial: "Many thanks for your expert advice, as soon as the weather picks up I will replace said primer bulb. "
  • 37 Answers
SOURCE: mountfield sp470
Hi, first you'll have to change the air filter and the spark plug. now, go buy some hi octane gas. drain the old gas and put the fresh gas in. if this don't solve your problem please write again.
Posted on Nov 23, 2008
SOURCE: How do I change a worn Carburettor Gasket and
Hunting and erratic operation are signs of air leaks or diminished fuel flow at WOT settings.
If this mower is running a vacu jet style carb with a diaphragm you simply take off the air cleaner, the vent tube, and then the four screws holding the carb on the gas tank and after the carb body can be lifted remove the throttle linkage so you can flip over the carb and pull the main jet and clean the inlet screens.
http://www.psep.biz/store/briggs_stratton_carburetor_kits.htm
Posted on Aug 11, 2010
kel1guy2002
  • 3740 Answers
SOURCE: i have a mountfield sp470
Hi. The SP470 has a 4 HP Briggs and Stratton engine.
The part number should be 687171 and you can look here:
http://www.worldofmowers.ltd.uk/Products/ProductList.aspx?search=Head+gasket+&type=3&searchBtton.x=20&searchBtton.y=10
Take a good look at the valve end of the head gasket. From the pictures on the page you should be able to see which one of the 4 head gaskets on the page is yours.
If you have yellow pages you can look up lawn mower repair. Or small engine repair shops. All of them should have this commonly used headgasket in stock. Just find one close to you or.. use the link above.
Here is yet another link for the head gaskets but you have to scroll way way down the page or page search for 698717 or 272171.
http://www.briggsbits.co.uk/acatalog/Horizontal_crankshaft_2-7_HP_Sidevalve_Engines.html
Thanks for choosing FixYa.
Kelly
Posted on Sep 12, 2010
What oil do you put in a sp470 mountfield
Hi use SAE 30 in warmer conditions or SAE 10W-30 for varying condition's improves cold weather starting ... Cheers
Sep 06, 2016 | Garden
I am looking for a Mountfield HP 470 Lawnmower instruction manual
I have a Mountfield HP 470 Petrol Mower 8 years old and I have started it the for the first time and it runs but seems to be hunting or missing as I cut the lawn.
Mar 24, 2011 | Garden
I have a mountfield sp470 petrol self proppelled lawn mower. the engine is briggs& stratton but i dont know the engine model. i need this as the cylinder head gasket has gone and needs replacing.
Kelly
Sep 12, 2010 | Garden
How do I change a worn Carburettor Gasket and Diaphram on a SP470 B&S Engine on my Mountfield Lawnmower? I'm good at DIY. The engine is hunting and running erratically.
Aug 11, 2010 | Briggs & Stratton Garden
I have a honda gv100 lawn mower and there is no petrol going to the engine
I have a mountfield omega petrol lawnmower with a gv100 honda engine. I turned it upside down to replace the blade and now it won,t start. Any help would be appreciated
May 30, 2010 | Honda 8 HP Engine
How do I replace primer bulb on mountfield SP470 lawnmower
Nov 02, 2009 | Garden
How much oil does a mountfield omega lawnmower take
If it is a small horsepower engine 4, 5, 6 HP, it will take approximately 20 ounces. If it is a larger engine8, 9 ,10, 11, 12 and on up it will take from 40 to 48 ounces
Sep 13, 2009 | Garden
Change the Oil
the easiest way would be to purchase a manually pump up oil change device that draws a vacuum and you put the tube from that device in the oil fill hole and draw it out to its own container
May 25, 2009 | Briggs & Stratton Lawn-Boy Insight Series...
Mountfield sp470
Nov 20, 2008 | Garden
Garden Logo
232 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
