Question about Zanussi Washing Machines
How to change a suspension leg on a zanussi washing machine how do you remove the bolts
    Genius:
  • Zanussi Master
  • 1,585 Answers
Has 2 cleakes ether side of plastic insert
Posted on Apr 27, 2015
Left screws in the back of new Zanussi washing now it wont spin
It must have broken some plastic off inside or may have jammed the belt mechanism. Check the belt and suspension/mounting.
Jan 16, 2014 | Zanussi Washing Machines
Sounds like ametal object in drum but there is nothing visible its making a loud banging noise
hello they usually make this noise sometimes a few thing to check make sure the washer feet are adjusted properly if ok .with the power off you could take the top off see if the 2 springs are attach either side of the washer sometimes the snap or come loose also have a look at the suspension legs make sure there tight or not broken hope it helps
regards
shaun
Mar 27, 2011 | Zanussi ZWF12070 Front Load Washer
How do i get the heater out on a zanussi zw12070w washing machine
The case splits in half remove side bolts and back top bolts,once case is removed you will see the element with wiring attached, its fitted via a 10mm nut loosen this and pull out heater element,including rubber seal,refit in reverse and carry out a water test for leakage before using......
Feb 18, 2011 | Zanussi ZWF12070 Front Load Washer
Excessive vibrations on spin(transit bolts)
you must remove these transit bolts . after you do try it . of course the legs of the washer must be set to make the machine levl. and then make sure the lock nuts on each leg are tightened. with a level machine with the leg locknuts tight the machine should spin smoothly. if you fasled to remove the transit bolts first then you may have damaged the suspension. then you will have to call for professional service. good luck
Aug 04, 2010 | Washing Machines
How do I change suspension legs on Hotpoint WMA 62? The drum on my Hotpoint WMA 62 is bouncing around really badly on fast spin which disconnects an electrical connector turning the machine off. Both the...
Could be worn or broken dampers, or loose concrete balance weight.
This would cause the problem you describe.
There are 2 wieghts, one in the top, and one at the bottom of washer.
Check that the nylon locating pins are securly fixed in the damper legs, as sometimes they have been known to come out of socket.
Mar 22, 2010 | Washing Machines
Tubs unbalanced i tightened all I bolts on springs leveled machine still have problem
Suspension legs not working
Drum counterbalance loose
Drum loose on spider
Drum out of shape through constant banking
Take your pick !!
Dec 31, 2009 | Maytag Washing Machines
Suspension legs for hotpoint WF740P
change all 3 legs together quote model no.of machine
Jun 30, 2009 | Washing Machines
Replace drum bearing
To complete this repair correctly and to prevent problem re occuring within months you must change the inner drum spider at the same time as the bearing kit, otherwise you are wasting your time, to complete the repair if you have not done one before will take you aprox 1 to 3 hours depending on space available and practicle ability, here goes, remove lid and outer case from machine to do this remove bolts on lower back and two side bolts (under small white covers) remove bolts along top edges both sides on top of macnine, remove cabinet, remove motor, remove hoses, remove heater and thermostat wires, noting location for refitting, remove suspension leg pins and lift outer drum assembly complete fron lower frame, split two halves of outer drum by removing bolts around centre seem, split drum in two, remove drum pully, refit pully bolt and drift inner drum out having put nut back on drum spider thread to avoid flaring shaft, using hammer knock shaft through bearings, then using a chisel or similer object knock out bearings and seal, reverse process refitting new bearins and spider, make sure to replace centre outer drum seal, as these are prone tro leaking I suggest you also seal with a layer of clear silicon, and problems contact me again, not really a job for a novice. Good Luck you will need it. Regards Advisor
Aug 29, 2007 | Zanussi FJS1225W Front Load Washer
Washing Machines Logo
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
