Why is my cycles taking twice as long now?? - Washing Machines
    Genius:
  • Washing Mach... Master
  • 1,585 Answers
Heater or thermostat
Posted on Apr 27, 2015
I have a Tromm Washer and Dryer. Washer cycle time taking twice as long as time on indicator. Mildew smell still there after I have cleaned filter and run wash cycle. Drum vibrates horribly on spin...
You may have a problem with the motor sensor. Replace the motor sensor and it should take care of the problem. As for the mold issue, purchase some washing machine cleaner and follow directions. It should take care of most of the smell issue. Good luck
Jun 21, 2011 | LG Washing Machines
Restarting the dishwasher
Hi Kathleen,
Welcome to Fixya, you came to the right place.
I`m not sure what model you have, but typically you should be able to select another cycle by choosing a button and pressing it twice quickly.
For instance if you want`"normal" press the normal button twice in 2-4 seconds and it should go to normal cycle.
Let me know how you make out. Good luck and thanks for visiting "fixya".
Please take moment and rate this solution favorable if indeed it helped you, if not let me know and we`ll move forward from here.
macmarkus :)
May 05, 2010 | Bosch Dishwashers
Kenmore elite 27032/27042 F1 code appears at beginning of wash cycle I redistribute the colthes once or twice and it continues to fill but sometimes does the same in rinse cycle
You have something stuck in your pump, turn machine on it's side and take the bottom off you will see the pump, take the bottom off of pump and remove whatever is stuck, just had this problem today!!
Oct 11, 2009 | Kenmore Elite 45986 Front Load Washer
98 deville can't start key disabled
1-insert and remove key from ignition two times
2-close and open driver door two times
3-insert and remove key once from ign.
4-close and open drvr door twice
5-insert key into ign.,then close driver door
6-turn key to on (not start) then off, twice this is rewrite mode,have all remotes to reprogram it will clear any lost remotes.
7-remove key from ignition,the door locks should cycle twice.if not start over.it may take a few tries.
8-press lock/unlock together and hold for a second
9-release,and press lock on remote,the door locks will cycle confirming program.continue to do other remotes you have,steps 8 and 9.if only one in possession,you are done. To end mode open door or insert key into ignition.
You'll need to follow the steps with no more than a 1-2 second delay between each step.. hope it works
Aug 14, 2009 | 1998 Cadillac DeVille
How do i program a remote control for a 1998 toyota vienta
Aug 04, 2009 | 1998 Toyota Camry
Loads have to run through high heat cycle twice to get completely dry. It was drying completely with one run through any cycle.
have you checked your wall vent hole and dryer vent hole to make sure they are clear?if there not it will keep the hot wet air from coming out and take forever to dry,let me know-mike
Apr 14, 2009 | Whirlpool LER4634J Electric Dryer
Cleaning Cycle goes twice around or more before completing cycle?
Ours did that too. I figured ou that it was because I was putting it on ultra wash by hitting normal wash + high temp, that automaticly sets it to Ultra wash. If you just set it to normal wash and hit start it should only do one cycle.
Sep 08, 2008 | Kenmore 24 in. 15932 Built-in Dishwasher
Whirlpool super capacity plus squeeeeels!!! Help!!
Got 2 screws on each side of the head assebly.. take screws out flip head back.. got 2 clips on each side, take clips loose and pull whole cabinate off.. should be able to determine where noise is coming from
Sep 26, 2006 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Washing Machines Logo
Top Washing Machines Experts
