Question about Building Materials
I'm using easy lift mk2 garage motor,i programmed it's travel and the remote and the programming went successful but it can only opens with the remote it can't close please help
    New Friend:
  • 21 Answers
Re program
Posted on Apr 26, 2015
glenmann62
  • 91 Answers
SOURCE: programing garage door opener remote
ok crystal,calm down this is an easy one! first locate the smart button on your openers , next you will press and hold down the smart button until you see an indicator light above it shut off, while your holding that button the light will be solid ,Now your ready to program your remotes ,first programm one side by taking each of your four remotes and pressing the smart button on machine then pressing the button on the remote you want to program,by doing that you will notice the lightbulbs on your machine shut off and go back on , This is an indicator that your machine has accepted the code , now do it with the other three remotes , after you,ve programmed all four ,go over to the other machine and repeat the process but this time you have to choose another button on your remotes since you,ve programmed all four remotes to the same button on each remote ,just choose the bottom button on your remotes this time to keep them seperated , hope this helps you and it is as easy as 1-2-3 your owners manual will describe exactly the same ,i know because i,ve installed over 27,000 machines working as an installer for sears, please leave a nice feedback rating if i was able to help you, good luck,Sincerely Glenn Mayer
Posted on Apr 01, 2009
  • 3197 Answers
SOURCE: Remote Control closes garage door but does not open
It sounds like a case of your keypad losing signal strength enough that it cannot transmit through the closed door. If a new battery doesn't do the job a new keypad will.
Posted on Sep 12, 2009
  • 3197 Answers
SOURCE: 2006 Honda Accord Garage door Homelink Program with Chamberlain
useful info.
Posted on Sep 14, 2009
  • 3197 Answers
SOURCE: Cannot re-program remote transmitters for garage door opener
If both remotes quit at or about the same time then it is most likely the receiver that has quit. Especially if you have had electrical storms in the area. The receiver is part of your logic board.
Posted on Sep 16, 2009
Testimonial: "Thank you. So does that mean I have to replace my receiver?"
  • 3197 Answers
SOURCE: Programming remote, unit will not flash.
The easiest way to program is to hold the button on the remote while you press and immediately release the smart/learn button. If it worked before there is no reason for it not to work now unless it totally failed.
Posted on Oct 05, 2009
Garage door opens randomly
Steve, If you have a remote door opener, change the code, as one of your neighbors may have their door using same code. Also make sure there is nothing hanging or blowing in front of sensor lights.
below are links, how to.
press the helpful button
How to Program Garage Door Remote Change the Battery Craftsman 315
Garage Door Help How to Program Your Garage Door Remote Control
How to Adjust Your Garage Door Opener Travel and Force
Feb 12, 2016 | Building Materials
How do I program the garage door opener?
You post again, what the model is of the opener, the car model, it looks like this control is in a car.
Most times you need the garage door remote, then you have to hold a button and the remote button to sync the two.
What ever you are trying to program, if this is a car, you need the manual.
If you need more help, you need to post the model number of everything.
Not every car, every opener is the same at programing.
Imagine that, life simple.
Apr 03, 2013 | Building Materials
Oct 05, 2009 | Sears Craftsman LiftMaster Chamberlain...
Programming car remote using garage door opener remote control fo
GOTO HOMELINK.COM
THEY MAKE THE SYSTEM AND HAVE INSTRUCTIONS YOU CAN DOWNLOAD.
PLEASE NOTE: NOT ALL BRANDS/MODELS OF OPENER WILL WORK WITH THIS SYSTEM.
HOPE THIS HELPS
Jul 03, 2009 | 2003 Lexus ES 300
Chamberlain Whisper drive remote control unit not working
THE NEW REMOTE MAY NOT BE THE CORRECT SYSTEM FOR THE UNIT YOU HAVE.
THE ONE THAT DOESN'T WORK MOST LIKELY NEEDS A NEW BATTERY.
NOTE IT MUST BE REPROGRAMED AFTER CHANGING THE BATTERY
HOPE THIS HELPS
May 14, 2009 | Chamberlain 950CB Remote Control
Program instruction garage door opener in 2005 chrysler pacifica
if your garage motor have rolling codes you need to put your car inside garage near the motor leave ignition on go to the motor locate learn button press it then quickly go to the car and press and hold one of the buttons for approximately 30 sec or until it start blinking rapidly, if you have a regular motor take one hand held opener go inside car ignition on same time press open button on handheld remote and on the car button 30 sec and it should be programmed.
Apr 24, 2009 | 2005 Chrysler Pacifica
Remote garage door opener
1-800-355-3515
www.homelink.com
1. Position vehicle within 10 feet of garage door- engine off and battery on.
2. Press/hold 2 outside buttons of Homelink transceiver until red indicator starts flashing rapidly, then release button. This should take about 20 seconds. This erases any previously learned codes.
3. Press/hold remote control and press/hold button of Homelink transceiver simultaneously. Slowly move remote control from 5" away to 1" away from Homelink transceiver. Release both buttons after red indicator starts blinking rapidly. This should take about 5 seconds. I discovered that the Homelink in my TL is a bit faulty because it took much longer to accomplish this than when programming the Homelink in my MDX. My TL's Homelink may "unlearn" it's code in the future and the needed proximity of the TL to the garage door may be much closer than desired until I get the Homelink fixed.
4. Press training button on garage door opener unit until the indicator lights illuminates- this should be immediate.
5. Within 30 seconds press/hold the Homelink button for 2-3 seconds until the red indicator starts flashing rapidly. Repeat a second time. It should now be programmed. Check it by pressing the programmed button on the Homelink receiver.
6. When programming more than 1 garage door opener unit, disconnect power from unit before programming more units. By not doing this the programmed unit could conflict with the unprogrammed units commands.
Problems:
1. The Battery in the garage door remote may be too weak to program Homelink. However, the battery may be strong enough to operate the garage door. One of my remote controls had a weak battery- my system was installed today, fresh out of the box. I had to use the second remote control for the programming of Homelink on my 2 vehicles.
2. Antenna on the garage door opener unit must be hanging down, fully extended.
Oct 11, 2008 | 2003 Acura MDX
Garage door opener
I was having a problem with the remotes. Program one remote, and the other stops working and vice-versa. I found the solution to be as follows: Using 61LM single-button remotes for Lift-master WhisperDrive (belt drive) garage door opener, I set the dipswitches (find them by removing battery replacement cover) to identical settings in both remotes. Set the first dipswitch to the neutral (0) setting. Next -- and this is the important part -- press the learn button on the main door opening unit, and, while the small LED light is lit, press the button on ONE of the remotes. DO NOT REPEAT ON THE SECOND REMOTE. Upon doing this, I found that BOTH remotes at last worked. I then went on to program a keyless entry pad, which was accomplished by again pressing the learn button on the main unit, and then entering the number sequence I had chosen for my entry code on the keypad, and pressing Enter. Both remotes continued to function and the keypad functions as well.
Mar 11, 2008 | Sears Craftsman LiftMaster Chamberlain...
Building Materials Logo
291 people viewed this question
Top Building Materials Experts
Terry Smith
Level 1 Expert
Tom Chichester
ray gallant
Are you a Building Material Expert? Answer questions, earn points and help others
