Question about Building Materials
I might using easy lift mk2 garage door i programmed it's travel and remote but the can on open it, it cannot close with the remote, what can be the problem please help
glenmann62
  • 91 Answers
SOURCE: programing garage door opener remote
ok crystal,calm down this is an easy one! first locate the smart button on your openers , next you will press and hold down the smart button until you see an indicator light above it shut off, while your holding that button the light will be solid ,Now your ready to program your remotes ,first programm one side by taking each of your four remotes and pressing the smart button on machine then pressing the button on the remote you want to program,by doing that you will notice the lightbulbs on your machine shut off and go back on , This is an indicator that your machine has accepted the code , now do it with the other three remotes , after you,ve programmed all four ,go over to the other machine and repeat the process but this time you have to choose another button on your remotes since you,ve programmed all four remotes to the same button on each remote ,just choose the bottom button on your remotes this time to keep them seperated , hope this helps you and it is as easy as 1-2-3 your owners manual will describe exactly the same ,i know because i,ve installed over 27,000 machines working as an installer for sears, please leave a nice feedback rating if i was able to help you, good luck,Sincerely Glenn Mayer
Posted on Apr 01, 2009
  • 3197 Answers
SOURCE: Remote Control closes garage door but does not open
It sounds like a case of your keypad losing signal strength enough that it cannot transmit through the closed door. If a new battery doesn't do the job a new keypad will.
Posted on Sep 12, 2009
  • 3197 Answers
SOURCE: Cannot re-program remote transmitters for garage door opener
If both remotes quit at or about the same time then it is most likely the receiver that has quit. Especially if you have had electrical storms in the area. The receiver is part of your logic board.
Posted on Sep 16, 2009
Testimonial: "Thank you. So does that mean I have to replace my receiver?"
SOURCE: Lift-master 2000SDR remotes will open but not close
Lift-Master 2000SDR opener. Opener generally works fine from the remotes. However, first time in the morning in cooler weather, it will start to close and the reverse and the lights blink. I have checked the senors - appear to be aligned properly. I have lubed the gear and used garage door spray on the rollers and hinges at the proper places. To close the door when this happens, I have to hold the wall button.
Posted on Mar 29, 2010
  • 3197 Answers
SOURCE: lift master 1021499A do not have
You need to get the correct model number which you should be able to find on the end closest to the door. Any door opener service company will be able to help you.
Posted on Aug 17, 2010
Garage door opens randomly
Steve, If you have a remote door opener, change the code, as one of your neighbors may have their door using same code. Also make sure there is nothing hanging or blowing in front of sensor lights.
below are links, how to.
press the helpful button
How to Program Garage Door Remote Change the Battery Craftsman 315
Garage Door Help How to Program Your Garage Door Remote Control
How to Adjust Your Garage Door Opener Travel and Force
Feb 12, 2016 | Building Materials
How do I program the garage door opener?
You post again, what the model is of the opener, the car model, it looks like this control is in a car.
Most times you need the garage door remote, then you have to hold a button and the remote button to sync the two.
What ever you are trying to program, if this is a car, you need the manual.
If you need more help, you need to post the model number of everything.
Not every car, every opener is the same at programing.
Imagine that, life simple.
Apr 03, 2013 | Building Materials
Resetting motor of a dominator garage door
Doe the motor have a battery back-up, or mains only?
Step 1: Disconnect the linking arm from the motor traveller, and test (by pressing button on remote or wall console), that motor runs traveller to the fully open position, and stops where the "open" limit switch is. Then run motor (by pressing button on remote or wall console), to the fully closed position. If the motor fails to run through a full open/ full close cycle, the limit switches require checking.Assuming that the motor runs through the full open/full closed cycle, focus on the door. All motors have built in circuitry, preventing motors from crushing objects. A double garage door should be able to be lifted easily by one hand. The door should be able to be left at any height, and remain there, or creep ever so slowly downwards (travel time of approx 10mm per 5 seconds is ok). If your door is properly balanced, and the motor will still not lift it, the control card on the motor is damaged, and requires replacement.
Jul 02, 2017 | Home Security
The garage door opens on it's own. The receiver and the remote are both new, replaced by a professioanl. we have re-programmed the remote code 5 times. All electrical lines have been checked and are...
There is a possibility that your are receiving interference from another wireless device that operates on the same wireless system as your garage remote. For example, someone else could have the same system for their garage, especially if you live in a community.
Jun 02, 2011 | liftmaster Garage Door 1/2 Hp
Lift-master 2000SDR remotes will open but not close garage door. Same problem with all clickers and even those programmed into the cars. What could this be and better yet, how do I fix it?
Nov 25, 2009 | Sears Craftsman LiftMaster Chamberlain...
PROGRAM PRIUS GARAGE DOOR HOW DO I PROGRAM THE BUTTONS ON THE PRIUS' REAR VIEW MIRROR TO OPEN THE GARAGE DOOR
There was a minor change for mine to work.. see below..
- you must park your Prius close to the gate opener, leaving it running (obviously not in the way of the gate closing)
- Hold the button the the mirror and then push your garage door remote button and hold until the light on the mirror starts to flasyh fast. THIS programs the button on the mirror, but not the garage opener - yet (this was key for me)
- locate the "learning button" on the opener itself
- press the "learning button" on your gate opener and then get back into the Prius within 30 seconds (more time than it sounds) and press the SAME Homelink button you just programmed above. I don't recall how long I held the pre-programmed button, but the light will flash as I recall.
- Then, when working the garage door, you may need to hold the mirror button for a good second for it to work - but I had tried for months to get mine to work, and finally after reading many posts, the above sequence worked on my 2008 Prius with my Lift Master, Security + rolling codes garage opener.
Just - program the button on the mirror with your remote FIRST.. the garage opener will not work.. then use the Learn button on the garage opener and the SAME BUTTON you just programmed.. and it worked great for me. Not programming the mirror button first will not work. Using only the Learn button will not work. You must program the mirror first with the remote, then use the learn button and the SAME button on the mirror. Hope this helps.
Scott 2008 Prius with Lift Master Security + opener.
Oct 30, 2009 | 2007 Toyota Prius
My remote intermittenly opens/closes the garage door
You can find a free manual for your door opener at manualsonline .com You might want to look at how to program it and change the unit to a different frequency. You can sometimes get better response and eliminate interference. Also make sure your battery contacts in the remote are clean.
Sep 26, 2009 | Sears Craftsman LiftMaster Chamberlain...
Programming car remote using garage door opener remote control fo
GOTO HOMELINK.COM
THEY MAKE THE SYSTEM AND HAVE INSTRUCTIONS YOU CAN DOWNLOAD.
PLEASE NOTE: NOT ALL BRANDS/MODELS OF OPENER WILL WORK WITH THIS SYSTEM.
HOPE THIS HELPS
Jul 03, 2009 | 2003 Lexus ES 300
Building Materials Logo
75 people viewed this question
Top Building Materials Experts
Terry Smith
Level 1 Expert
Tom Chichester
ray gallant
Are you a Building Material Expert? Answer questions, earn points and help others
