OK. If cleaning the oil cooler and knowing the oil level is ok I recommend replacing the thermostat element. If you have a manual on your unit the part number will be in it. Recommend getting the kit which comes with spring, thermostat and o ring.
Heating elements should not be in direct contact or near a combustable materiel. Heating element should be in free space and away from touching the pot base. If you have oil touching your heating element you wil have sponsteous combustion and create a fire. In your case have someone qualified to disassemble your unit and clean the chamber where your heating element is located, have the pot verifed for possible leaks. Note: someone may have spilled oil over the edge of the pot which ingressed to the bottom of the fryer where your heating element is located. Good house keeping with your appliances is essentiel for your safety. Good luck and be aware of fire.
FIRST OF ALL YOU NEED 4.0 QUARTS OF OIL FOR 2.2L 2.3L AND 2.4L OHC ENGINES AND THE 2.2L OHC USES 5.0 QUARTS WITH NEW OIL FILTER.TO GET START YOU NEED A FILTER WRENCH,DRAIN PAN, RUBBER GLOVES WHICH PROTECT HANDS FROM OIL. OILWILL CAUSE CANCER , IF STAYS ON SKIN TOO LONG.YOU NEED TO CRANK ENGINE UP LET IT IDLE 5 MINUTES TO THIN OUT MOTOR OIL SO IT CAN FLOW FASTER.WHEN 5 MINUTES UP.TURN OFF ENGINE.SAFELY RAISE SUPPORT VECHICLE ON JACK STANDS ON SOLID LEVEL GROUND.SLIDE DRAIN PAN UNDER THE CAR OIL PAN. PUT ON RUBBER GLOVES THEN REMOVE OIL PAN DRAIN PLUG ON BOTTOM OF OIL PAN USING A 15 METRIC SOCKET WITH RATCHET WRENCH.WHEN ALL OIL DRIPS.SCREW IN TIGHTEN OIL PAN DRAIN PLUG BACK IN OIL PAN REMOVE OIL FILTER ITS NEXT TO OIL PAN USE SOCKET TYPE OIL FILTER WRENCH IF OIL FILTER IS DOWNWARD POSITION. IF OIL FILTER ON THE SIDE YOU NEED THE BAND TYPE OIL FILTER WRENCH. ****** NOTE THIS THE 2.2L OHC ENGINE USES A OIL FILTER ELEMENT THAT HOUSED INSIDE A RECEPTACLE LOCATED AT THE LEFT FRONT CORNER OF THE ENGINE.YOU UNSCREW THE OIL FILTER CAP THEN LIFT THE CAP AND OIL FILTER FROM THE FILTER RECEPTACLE IN THE ENGINE.SEPERATE THE OIL FILTER ELEMENT FROM THE CAP USING A CLEAN RAG REMOVE OIL DIRT AND SLUDGE FROM THE OIL FILTER CAP AND FROM THE RIM AROUND THE OIL FILTER RECEPTACLES.INSTALL A NEW O RING INTO THE GROOVE IN THE CAP.THEN INSTALL THE NEW FILTER ELEMENT IN THE CAP AND INSERT BOTH INTO THE FILTER RECEPTACLE.SCREW DOWN THE CAP AND TIGHTEN IT SECURELY. WHEN ALL IS DONE POUR NEW OIL IN CRANK CASE.MAKE SURE OIL LEVEL ON DIP STICK ON THE FULL MARK YOU CRANK THE ENGINE.MAKE SURE OIL DRAIN PLUG SCREWED BACK IN OIL PAN.WHEN INSTALLING OIL FILTER FILL IT HALF WAY WITH NEW ENGINE OIL,RUB OIL ON FILTER SEAL TO HELP IT SEAL TO ENGINE.BESURE WIPE OIL FILTER SEAL SURFACE ON ENGINE TO MAKE SURE IT CLEAN. WHEN ALL IS DONE CRANK ENGINE UP CHECK FOR OIL LEAKS.IF ALL IS GOOD LOWER CAR BACK TO GROUND,YOU DONE.
2008 Scion xD oil filter is a cartridge (element only) type. It is located under a heavy, black plastic cap right next to the oil drain plug. To remove the cap, you will need a Toyota "Special Service Tool" or an Assenmacher Specialty Tools "TOY640" or similar cap wrench. Toyota is the only source for the oil filter element; make sure you get a new o-ring (should be in the box with the filter element) and a new drain plug gasket.
if just your broil element does not work and the bake element does work after using a self clean cycle then your broil element must have went out , self clean is a torture proccess for any self clean oven and it runs both elements at 500 deg. F, it may be still under warranty , if not then replace the broil element for the fix.
Phil
Yes you can get it wet, but make sure it is dry before you turn it on. If the element is detachable, that is good. If not, you may not be able to put it under water because water could get into the electrical components. There should be a caution tag on it that tells you if you can put it in water. One thing you can consider is drain the oil and put in water with a cleaning agent and then turn it on and let it come to a boil, then shut off and do this several times. This will remove a lot of the build up on it.
On my unit with the same problem it is the element contact located under the oil pan. The contacts obviously began arcing due to corosion or poor contct causing deteriotion of the contact points. I am trying to find the necessary replacement part. It isnt hard to replace but finding the part may be.
