What am I doing wrong/? Have set up new router but cannot get TV to work.
Router is not in same room as TV. Internet working but it is a seperate room.
  • 7,733 Answers
Myabe is the signal. Also you will need an extender
What am I doing wrong/?  Have set up new router bu - 25666210-ay4m315zlbb531v4ndd4zbzw-2-0.jpg
PC Range Extenders
Posted on May 12, 2015
SOURCE: laptop connects to router but internet will not work although green light is on
nnjhg ghgh hghgh hgghghg
Posted on Mar 01, 2009
enoch_cog80
  • 33 Answers
SOURCE: Suddenly no connection to the internet via wirelss. LAN via the same router works fine.
its the problem of your service provider.... contact your service provider
Posted on May 23, 2009
  • 6 Answers
SOURCE: linksys router will not connect to internet
Routers job are to interpret outside world into your own world.
Linksys Wizard will guide you step by step on how to figure out who is connected to what and where.
At the back of the Linksys Router, there is a small white button if not black, in order for any end-user to reset it back to Factory Default. The purpose of Factory Default is to give you a chance to start from scratch!!!
Press that button for the next 30 seconds while unplugging its power cord. After such time, you will need to plug the power cord back on and your will be ale to Re-run your Wizard to confogure your router.
By the way, Linksys routers comes with a CD in order for you to make your life easy. Have that CD ready and install in your local computer.
I hope this helps. I can't give you play by play instructions on the wizard because I don't have one.
Posted on Jul 24, 2009
bob_computer
  • 3153 Answers
SOURCE: wrt54g router will not pick up internet
It is possible that the routers IP conflicts with your modems IP
This is quite common and the fix is equally common and easy to do.
First disconnect the router and connectone computer directly to the modem.
goto the start menu and in XP hit the run button then type in CMD
a dos screen will open at which time you should type "ipconfig /all" and take note of the numbers esp any IP which are usually in the form of XXX.XXX.XXX.XXX eg 192.16.1.1
One of the numbers you have just written down is the IP of your modem and will be the the one after "default gateway"
Now unplug the modem and plug only the router into the computer and repeat the little test above. If you see an IP that is the same default gateway as your modem you have found the culprit and can now move on to fix the problem.
Connect to the router using your web browser by typing http://192.168.1.1
Whilst here you can set your default username and password for DSL so that you dont have todo it from the computer all the time.
now look for "network setup"
It is here you will find the number you have to change
http://register.wireless.utoronto.ca/?page=linksys
See section 5 and change the number in the box marked "local ip address" change the third box to say 3 so that the IP reads 192.168.3.1
Now make sure you save the changes and exit.
Time to test it all out so now connect the modem to the line or cable, connect the router to the modem, and with a cable to start with connect a computer to the router and if you set it up correctly you should be able to use the new connection wizard and follow that carefully to the end.
At this point I would do a shut down restart and you should now have wired internet.
To use wireless use the new address for the router which will be 192.168.3.1 and make the changes you need to set up the wireless but make sure you enable WEP or greater If it has WPA that is more secure.
Posted on Aug 11, 2009
garethmt
  • 111 Answers
SOURCE: New Belkin router wont connect to internet.
your user name and password have been entered incorrectly, they are case sensitive and must be exact. Make sure your ADSL settings are set at 0/38 (you'll see where)
Posted on Nov 13, 2009
How do i get my linksys router to work
You may need to reset your device and you will see a reset button at back of your router so all you need is to keep holding it for 10 seconds then unplug the power jack for like 1 min and then your device shall be reset.But please make sure to backup your all settings first.
May 05, 2012 | Linksys Wireless Broadband Router,...
Hi, I'm having problems connecting to the router (Virgin) to my bedroom from lost of signal strength, so i brought Sitecom Wireless Range Extender 300N to boast the signal. I've installed the Range...
1. did you first try to connect to the router via wire directly with it in the same room? then set up the wireless to work in the same room too.
2. once you've done that and it worked then move it to your bedroom. If it doesn't work there it could be that there is something inbetween the two rooms that is blocking the signal...ie a furnace can do that
3. if it won't work try relocating the router to another location. Try a different location in the same room first
but as i said , first get it set up and running in the same room so you know for sure it works.
Mar 21, 2011 | Computers & Internet
Wii lost connection to internet how to reconnect
FIRST, you want to check and make sure that your router is working and sending a network signal. When you find that it is and your Wii still won't connect, try moving your router to a better location where the wii can receive the signal more clearly. Then go to the Wii "Options", then Wii "Settings, Scroll through screens to "Internet" option, then "Connection Settings". Choose your Wireless Connection that you were using and do a "Connection Test". Sometimes it's only a matter of a couple of feet and the signal won't be strong enough, especially if the Wii and the router are in seperate rooms. If all else fails, simply clear the settings for the wireless connection you were using and start from scratch by re-entering the connection settings for your home network. Hope this helps!
Nov 30, 2010 | Nintendo Wii Console
My belkin n1 vision router hang at least 3 times a week regularly, what wrong with it? I must pull out powercable and plug in again in 5 seconds will work again or sometimes it will automatic restart but...
1.Log into router. Using either 192.168.0.1 to 192.168.1.1 in a browser window that is ( internet Explorer or Firefox)
2. Verify wireless router name( on the computer) >>> ( on/off) ( router status window)
3.Note router name you are connecting to.
4.. Check the laptop do ipconfig /all to see current IP addresses.
5. Set the laptop up in the router by WEP KEY or MAC address. This set up in the "security tab" in the router. using 192.168.0.1 or 192.168.1.1 to access through a browser.
6.Note router name you are connecting to.
7. Move the laptop about 20ft away and try to log on to the internet.
This is for all routers to set up wirelessly.
8. check for firmware update at the manufacturers site for your model router
9. cell phones, cordless phones, digital TV's, can affect the data signal from a router. Also distance from the router can be a factor. If your router is in a basement place the router to a upper floor and center it in the room.
Sep 08, 2010 | Belkin N1 Vision Router
Troubles connecting WRT160Nv3 Linksys router to Wii
I am thinking the router was set to get it's IP from the modem and when you changed the IP after the power failure, is when you problems started. I suggest looking at your networks IP addresses. I think they are not on the same subnet.
My first step would be to record the settings and do a hard reset on the router, then proceed to reinstall the settings and make sure your network is on the same subnet.
Dec 14, 2009 | Linksys WRT160N Wireless Router
I have a brand new Acer Inspire 5516, purchased for the wireless function. Have a DSL modem in the same room. Can't get the Acer to work wireless, only with the modem connected. What am I doing wrong? Or...
You need to have your DSL modem connected to a wireless router. The wireless router will then put your internet connection on the airwaves so your Acers will connect wirelessly to the router then they will be able to access the internet.
Jul 26, 2009 | Acer Computers & Internet
Have wireless router in other room PS3 setup can't connect www
  1. Make sure that your wireless Internet is turned on and working properly.
  2. Step 2 Turn on the Playstation 32.gif game console.
  3. Step 3 Access the "Network Settings" screen under the "Settings" screen in the main menu.
  4. Step 4 Select the "Internet Connection" tab and select "yes" when the system displays a new screen.
  5. Step 5 Select "easy" on the new screen that pops up asking what type of installation you want to use.
  6. Step 6 Select "wireless" when it asks you what type of Internet connection you have.
  7. Step 7 Select "scan" on the next screen so that the system searches for all available Internet connections in the area.
  8. Step 8 Select your home Internet when the screen pops up displaying the available Internet options.
  9. Step 9 Save your settings on the next screen.
  10. Step 10 Test the connection to make sure that it works properly.
Apr 11, 2009 | Linksys WRT610N IEEE 802.3/3u IEEE...
New laptop, connected to router, no connection to internet
Your DHCP server is either disabled or have not enough room for anymore computers. set the number of ips to "more" than what you need ie 3 or 4.
Nov 23, 2008 | D-Link AirPlus DI-524 Wireless Router
Net gear router troble shooting problem.
Mirrors, thick walls, and metal objects can block internet signal from going into certain rooms. Make sure that you are in a good room for this.
Apr 12, 2008 | Computers & Internet
Exactly ASUS WL-500g, no internet connection
My advice and personal experiences with both wired and wireless connectivity, is if you wish to share files and internet connection, purchase a combined Modem/Router and not a seperate router to work along side your original modem. Your modem will send your router an ip address in turn your pc is sent one from your router and can get complicated; keep it simple! These are much easier to set up and control as one unit and if there are ever any connection problems you will know it's either a setting or a modem/router problem and not have to wonder ; is it the modem?; Router? settings? etc. As there are frequent loss of connections both internet and LAN it makes sense have one peice of equipment to maintain.
Dec 22, 2006 | ASUS WL-500g Wireless Router (WL500GDLX)
Computers & Internet Logo
69 people viewed this question
David Payne
David Payne
