I have a 32 inch flat screen TV by Insignia. It's only a year old.only on channel 9 the sound goes on and off.it stays on for a minute and turns off for 2 minutes. .Why is it doing this???????
    Novelist:
  • 206 Answers
If this is only happening on channel 9 and no other channels at all.
This would be a channel issue. The TV would have to have the same issues on every channel for it to be a TV issue.
Hope this helps..
Posted on Apr 26, 2015
  • lisa rowe Apr 26, 2015
    It only does it in the tv in the bedroom.
SOURCE: TV No Picture
My 32D40U would turn on for 5-10 seconds (Please Wait would appear) and the screen would go black. Sound Normal. It would also sometimes do this after running 5-10 minutes. I read somewhere that the inverter board would come loose and lose proper ground. I took the set apart, removed the board, and cleaned up the grounding points. I reassembled using some copper paste on the ground points and LockTite on the screws. I used some contact cleaner on all the connectors going to the board. I noticed two cables that are covered with copper shield tape where too tight at their connectors and repositioned the tape to give them some slack. The problem hasn't occurred since the fix.
Posted on Mar 22, 2008
  • 6 Answers
SOURCE: I have a LG 42LB1DR
I purchased four 2200uf @ 25v capacitor’s for $8 at a repair shop. I upgraded to 25v because these will run cooler. The tv came with 2200uf @ 10v Samxon caps that seem to be problematic in all the units they were used in. Do not buy Samxon if you do this job yourself.... I opened the set by taking off the plastic back panel and then by removing the second metal panel. There are three boards and a hard drive. The board on the far left just above where the plug goes in is the power supply board. There are five data cables and one red power cable attached to it that can be removed simply by unplugging them. The board is fastened to the unit with five small screws, one on each corner and one in the middle of the right side. If you look for three green capacitors grouped together around the middle of the board and slightly off to the right, you will probably see one that is bulging out at the top. This is most likely "C235", the main problem. The other three caps that need replacing are C202, C201 and C219. C219 is closer to the top part of the board.....
The process to replace is simple, believe it or not, and it could save you hundreds of dollars. 1, Go to RadioShack and buy a cheap soldering iron and a small roll of solder. 2, Buy four, 2200uf @ 25v capacitors, online or at an electronics store. 3, Plug the soldering iron in and let it heat up. 4, Locate C235 on the back side of the board and mark the negative terminal with a felt tip marker (you want to make sure that you put the negative terminal on the capacitor through the right hole, otherwise you will pop the cap. The negative terminal is clearly marker on all the capacitors). 5, With needle nose pliers, grip the cap and pull down while heating up the terminals. The cap will eventually come out. 6, Put the new cap in (you may need to heat the solder that is left on the board to clear the hole so it can push through). 6, When both terminals are through, bend them slightly so it stays in place. Take the solder and stretch out a few inches off the roll and while holding it in one hand, lightly touch the base of the terminal where it comes through the board, with the soldering iron and the solder at the same time. --- Try not to use too much solder.. you only need a tiny drop. This will solder the cap in place. 7, cut off the terminals close to the board with some snips and repeat this on the other three. 8, put the board back in, plug in the cables. Test the TV before putting the back panels on. It should work fine if all went well..... If you hear a pop than you reversed the terminals on a capacitor and that one will need to be redone correctly.... This might sound lengthy and potentially difficult but its worth a try. Otherwise you can pay someone to replace the entire board for BIG BUCKS with the same junk caps on it and have the same problem in a year or so. LG doesn’t want to take responsibility for this and I'm sure that it has cost a lot of people a lot of money for about $8 in parts........... This worked for me and it can work for anybody with the same problem.. Good Luck!
Posted on Apr 28, 2009
  • 53 Answers
SOURCE: Picture goes black but hear the sound
this is the problem related to display of ur TV screen...please contact the service centre...plz dont try to repair it urself..
Posted on Apr 30, 2009
  • 148 Answers
SOURCE: After turning on tv screen stays up for 1 minute
Hi there, first off, place a fan as close to the back of the tv as you can, this could prolong the use of your tv by cooling down the powerboard inside, The reason why your tv is doing this is becouse the caps (capacitors) in the powerboard are going out. This is a very common problem in all class and price ranges of modern lcd and plasma tv's/ monitor's. I don't know if this problem has been like this for awhile or it just started, but either way, if the tv takes an abnormal amount of time to "warm" up then it most likely will go out all the way sometime in the (near) future. If you have a tiny bit of will and knowledge ypou can open the unit and get to the print board. Examine this for "popped" capacitors, they will have a buldging top instead of a flat one. Im gonna try to include a pic of them here, if i can get it this time, I've tried bfore lol. But you can google image a "popped" or "bad" capacitor and you would be able, with ease, to diagnose if you have any of these. Usually only one or two. Radioshack sells capacitors (couple anyway) for $1.59 each. MAKE SURE the replacement is of the SAME voltage or HIGHER, or you will be right back replacing those 2. Every capacitor has a negative pole marked with an (-) on the side of the capacitor(by one of the "legs", always puit the negative (-) "leg" of the new capacitor in the same hole in the printboard as where the previous negative (-) "leg" of the capacitor was ( a capacitor with the negative and positive "legs" put in backwards will result in the new piece "popping" as sson as you turn it on!!) make sure the "uf" rating (for example the most common popped capacitor is the 1000 uf) is the same as the one you are replacing. I needed 1000 uf, 105 c and 26v (volt) ratings for the 1 capacitor I needed to replace to fix my LG 19" lcd panel monitor I found by the trash that the light came on off, but it didn't come on. I replaced that capacitor with ; 1000uf, 85 c and 36 v (volts0...It works fine eventhough the volts and the temperature rating (36v and 85c) was not the same as the (26v(volt) and 105c ) capacitor I removed !! Further, I've replaced capacitors that had the celcius rating of 105 with the only ones Radioshack had, namely 85 c(celsius) they have been working great, but I'm not sure about any effect, nor have I heard or read (yet?) about that making an urgent difference. Many threads that I've read people have done the same, so we should be ok (my stuff has been running good for a while longer then most brand new ones!.............(all these ratings ; 'uf ' and 'c' etc are on the side of the capacitor you are replacing and on the side of the ones you are replacing them with)...For all this all you need is the cheapest solder gun u can find (I bought one for $7.99 at Radioshack), a camera (to take pictures as you go to remember how to reassemble the unit) and, once you have your materials, 20 minutes to replace 2 or 3 capacitors and you are good to go...Most monitors and tvs (lcd/plasma) I've seen you have to lay flat on the ground/bed/blanket etc, to work on (screen side down). Usually there are 2 or 3 screws (or a few more) to remove, then you will have to carefully (its comes off easily most times)insert a flat screwdriver inbetween the casing and gently pry it up as you go around the whole frame. Sometimes you have to remove the little washer arouind the cable input orso, just be gentle and you cant go wrong. Once insidet here will be a box with wires running to the sides etc...unplug, gently, these wires and open the box. Inside you will find 2 or 3 circuitboards, check them all for "popped" capacitors, replace, reassemble and plug it in....Have fun becoming an overnight tv mechanic lol! If this helped you (or not) then please rate, thankl you!05f6799.jpg
Posted on Feb 05, 2010
SOURCE: westinghouse 32 inch screen goes blank
Westinghouse LTV-32w1
replace capacitor c162 on power supply
power supply was a delta electric dps210ep-2c rev01
reheat any solder joints that don't look 100% as well .
such as c310 .
this is a known working fix . try before you buy a supply .
Posted on Apr 15, 2010
Insignia 32 flat screen will not stay on. Power on and go right back out? What is the cause for this to happen?
Top 144 Complaints and Reviews about Insignia TV
www.consumeraffairs.com > Electronics > Televisions
Rating: 1.5 - ‎80 votes My son purchased a 42" Insignia TV for me before he died. ... Bought 50 inch Insigniaand after 13 months screen starts going black but sound stays on. ... I was having problems with the Netflix app on my 42" Insignia smart TV, so I took the ...
Sep 23, 2015 | Insignia Televison & Video
Just purchased a 32 inch insignia flat screen model # NS-32L430A11, How do I make the picture the full 32 inc instead of the small screen in a box?
Look for 'ASPECT', 'MODE', 'VIDEO', or 'DISPLAY' on the remote button to change the aspect ratio.
One thing to remember is that if the video was made for 4:3 old TV format, when you expand it to fill 16:9 screen, people will loof short and fat.
Dec 04, 2010 | Insignia IS-LCDTV32 32 in. Television
My 27 inch Insignia flat screen tube TV goes blank
The vertical deflection has gone out. Put it in the shop.
Apr 24, 2010 | Insignia NS-27RTV 27" TV
No picture
It sounds like the LCD controller board is bad. There are more than one versions of this board because this brand of TV are made by more than one manufacturers. You need to get the number printed on the circuit board and look here: http://www.shopjimmy.com/catalogsearch/result/?q=Insignia+IS-LCDTV32+
Jan 07, 2010 | Insignia IS-LCDTV32 32 in. Television
Black box showing up in center of tv
your closed caption feature is turn on and in the text mode. either turn off the closed captions or change it from text to cc1
Jan 08, 2009 | Toshiba 32A33 32" TV
It's the 26 inch version but have problem with picture
Hi Paul,
It looks like your TV might have a main board failure if the screen stays white without video. Since your TV is less then a year, I would suggest to contact the manufacturers to get fix under warranty. Most electronics devices carry one year warranty.
Good Luck.
Dec 19, 2008 | Olevia LT32HVE 32 in. LCD Television
Sound and Volume trouble
I bought my Insignia 32" LCD in November 2007 - same problem. I figured out that if you press the "input" button on your remote select any of the other options "component 1, composite 1, etc.. that you're TV isn't on -then press "input" again and go back to the component that you're TV plays on - you'll have volume when you go back every time. I've gotten so used to doing it now that it's become habit. 9 times out of 10 I have to do it.
Mar 15, 2008 | Insignia IS-LCDTV32 32 in. Television
Insignia lcd tv 32"
have good tec replace if nessary, The inverter module
Mar 03, 2007 | Insignia IS-LCDTV32 32 in. Television
Televison & Video Logo
56 people viewed this question
Top Televison & Video Experts
