Put on printer and it said scanner error: Error code 0x9A And machine will not work!
  • Brett Duxbury
    Brett Duxbury Apr 26, 2015
    Hi Allan Rodger, we want to help you with your question, but we need more information from you. Can you please add details in the comment box? how is it connected to computer . Waht model number and make is the printer ?
SOURCE: scanner error
While scanning it gives the msg "cannot communicate with scanner.Cable may be disconnected or scanner may be turned off.Checked Status.Scanner driver will be closed.
Posted on Mar 23, 2008
jtuminaro
  • 56 Answers
SOURCE: machine error. no error code.
Go into maint. mode.
With-in 2 seconds hit Menu,*,2,8,6,4
Then hit 82 when in maint mode.
This will give you a machine error code.
Let me know what that number is and I will help you with a solution.
Posted on Jan 15, 2009
pdouglasss
  • 125 Answers
SOURCE: I just put in a yellow cartridge. Previously the printer was working just fine. Now it is showing an error code: 10.92.00 So I put the old yellow cartridge back in. The same error code now appears? He
Hi ron0911170:
This is your problem.
10.92.YY CARTRIDGES
NOT ENGAGED
alternates with
Open and close
front door.
The cartridges are not engaged,
poor primary transfer bias contacts,
defective high-voltage supply, or
control signal errors.
YY Description:
00 - Black print cartridge
01 - Cyan print cartridge
02 - Magenta print cartridge
03 - Yellow print cartridge
1. Open and close the front door to fully
engage the cartridges.
2. Reseat the print cartridges.
3. Check the printer primary transfer bias
contacts to the transfer unit. Clean if
dirty. If the contracts cannot be
cleaned or they are damaged, replace
the transfer unit.
4. Replace the high-voltage power supply
PCB.
5. Replace the DC controller PCB.
Hope this helps
Posted on May 24, 2009
shockwave727
  • 262 Answers
SOURCE: Scanner motor move failed error code 6202
6202 error code means that the scanner motor failed
to solve this
-Open the printer access door of your printer
-Unplug power cable
-then after 30secs plug the power able back
-If the printer is already power-up the message printer access door will appear
-Close th printer access door
-try to scan or print
If this issue not solve call tech support of kodak Toll free 1 800 421 6699
Posted on Nov 08, 2009
sandimcp
SOURCE: Scanner Error 5 "error message" on my all in one
I had this problem and it had to do with the scan bulb head not recognising the marker. My temporary fix until the bulb is replaced is to turn the printer off, open the top (ADF and all) with the gray button on the right so that it's slightly raised and then switch the printer on. When it comes up, just close and print/scan/copy as usual. Apparently the spring in the arm warped the interior surface where the head moves and it can't line up when it's closed. Hope this helps.
Posted on Sep 01, 2010
What are the error codes on my printer,5010 & 6100?
The 5010 error indicates a scanner error. The scanner unit cannot detect the home position, or the scanner unit warming-up is not done properly at power-on. On the LCD, "Scanner is not operating correctly." is displayed.
The 6100 error indicates a logic board error. The check sum value is incorrect in the ROM check at hard-power-on.
Fixing these errors is more expensive than replacing the printer. Sorry.
Fixing F
Feb 05, 2015 | Canon PIXMA MP830 All-In-One InkJet...
ERROR CODE 0x9A
this error is because the print head is fill with ink, clean print head area with alcohol and allow it to dry. make sure your printer power is off while doing this.
Nov 05, 2014 | Epson Expression Premium XP-600 WiFi...
Epson Stylus CX7800 All-in-One Printer ERROR CODE 0X9A
Hi
I would hazard a guess that the print head electrics have been flooded with ink causing this error, you could try giving the whole area a good splash and clean of alcohol then blow dry the heads with a hair drier set to cold for a few minutes.
Before carrying out any work on your printer make sure you unplug it from the wall first and then leave it for an hour before powering it back on again.
Good Luck Mark
Sep 13, 2014 | Office Equipment & Supplies
Error Code
the pw sensor on the cr assy is dirty.clean it.
move the printhead with your hand and place it to the right end and turn the printer on....
maybe will work...
Apr 29, 2014 | Epson Office Equipment & Supplies
Epson Error Code 0x9A
0x9A Circuit error (include blowout of a fuse F1 on mainboard). Main board failure.
Mar 18, 2014 | Epson WorkForce Pro GT-S50 Scanner, 600...
Error code : 0x9a
Can you tell more of the issue you are going through as to know what problem you are facing....
Hope to hear from you soon.
Regards
Nov 12, 2013 | Epson Expression Premium XP-600...
52 scanner error
HP LASER PRINTER ERROR CODE 52 – INCORRECT SCANNER SPEED ERROR
HP LASER PRINTERS 2, 2D, 3, 3D
1. Defective cable laser scanner to dc controller.
2. Defective laser scanner assembly.
HP LASER PRINTERS 2P, 2P+, 3P
1. Bad scanner motor.
2. bad dc controller.
HP LASER PRINTERS 3SI, 4SI, 4V
1. Faulty cable assembly.
2. Scanner motor problem.
3. Defective laser scanner assembly.
4. Defective dc controller.
HP LASER PRINTERS 4, 4+, 5
1. Faulty laser scanner cable.
HP LASER PRINTERS 4L, 4P, 5P, 5L, 5SI
1. Temporary error. Scanner startup failure.
2. Improperly fitted scanning assembly.
3. Scanner cable problem.
4. Defective laser scanner assembly.
5. Defective dc controller board.
HP LASER PRINTERS 1200, 2200, 3100 FAX, 3200 FAX, 4100
1. Temporary error. scanner rotation error.
2. Replace contact image sensor.
4. Replace laser scanner.
5. Replace cables to laser scanner and engine board
HP LASER PRINTERS  1100, 2100, 4000, 4050, 8000
1. Scanner start up error
2. Replace scanner cable to the D.C. controller and back to scanner. Or replace scanner cable from engine board to scanner ***'y.
3. Replace scanner ***'y.
4. Replace the engine board.
5. Replace the D.C. controller only on the 8000.
HP LASER PRINTER 2300 ERROR 52.X
1. A temporary scanner start up error.
2. This can also be the shutter tab on the print cartridge. Replace the toner cartridge.
3. Replace the scanner ***'y.
HP LASER PRINTERS 4200, 4300 ERROR 52.XX
1. Printer scanner speed error has occurred.
2. Replace laser scanner ***'y
3. Replace the D.C. controller ***'y
HP COLOR LASER PRINTER 4600, 5500 ERROR 52.XK, 52.XC, 52.XM, 52.XY
1. Error code K - No Black Color.
2. Error code C - No Cyan Color
3. Error code M - No Magenta color
4. Error code Y - No Yellow color
5. Replace laser scanner ***'y
6. Replace the D.C. controller ***'y
HP LASER PRINTERS 5000, 5100
4. Replace cable ***'y from scanner to D.C. controller.
HP LASER PRINTERS 8100, 8150
1.Laser scanner error/start up/rotation error
2.Replace laser scanner ***'y.
3.Replace D.C. controller board.
4.Replace cable ***'y from scanner to D.C. controller
HP LASER PRINTER 4500, 4550
1. Temporary error. Laser scanner error/start up/rotation error
2. Replace laser scanner.
3. Replace D.C. controller ***'y
HP COLOR LASER PRINTERS 4600, 5500
1.Laser scanner error/start up/rotation error.
2.Take the toners out and reseat them, or replace them
3. Replace laser scanner ***'y
4. Replace D.C controller board.
HP LASER PRINTER 8500, 8550
2. Replace laser scanner motor.
HP LASER PRINTER 9000
1. Temporary laser scanner error/start up/rotation error
3. Replace upper cable guide assembly.
4. Replace DC controller.
Oct 22, 2008 | HP LaserJet 2840 All-In-One Printer
k24674
