Dp 24 datawheel doesn't work at all .is there a step i'm missing?
  • Brett Duxbury
    Brett Duxbury Apr 26, 2015
    Hi Mike FerDon, we want to help you with your question, but we need more information from you. Can you please add details in the comment box? what networking connection what is its IP address . How does it hook into your existing network. What he make and model number of the unit in question ?
My printer says "missing component
Please carefully follow steps below to fix this problem:
  1. If the computer is NEW and already has 10.7, download the Webdriver directly at http://bit.ly/onkHQ5.
  2. If the computer got 10.7 via the Software Updates, then run the Cleanup tool, please refer to this article on the Lexmark website: Removing Lexmark Files on your Mac 10.7 Computer
  3. Run the installer, and after add the printer via Print and Fax. Follow the steps in Solution B in this article: How to Manually Add a USB Print Queue, Network Print Queue and Fax Queue on Mac OS X Systems.
  4. Run the Apple Software Update and get the Lexmark 2.5 Drivers installed.
  5. If the printer cannot be added, run the Repair Disk Permissions, then Reboot.
If this doesn't help, please contact Lexmark Technical Support Center for additional assistance.
Aug 23, 2011 | Lexmark X6675 Pro Colour Wireless...
My wii does everything but play games it produces a error message "unable to read disc"
The first step would be to clean your lens using something like this:
http://www.amazon.com/Wii-Lens-Cleaning-Kit-Nintendo/dp/B001GZT1UI/ref=sr_1_1?ie=UTF8&qid=1312762685&sr=8-1
if that doesn't work you will need to contact nintendo for support.
You can do that here:
http://www.nintendo.com/consumer/index.jsp
I hope this helps! If this did help you, please give a thumbs up!
Thank you for choosing FixYa!
Aug 07, 2011 | Nintendo Wii Console
Steps to record then to playback in headphones phantom power and tracks are lit we record then try to playback and get nothing. it shows there is a track there any ideas
I think you need to read the manual CAREFULLY and follow it step by step. I had problems with mine also and found it was me in too much of a hurry to get things done. This unit is easy to record with once you get the procedure figured out. I think you're just missing a step. Good luck
Feb 24, 2010 | Tascam Dp-02cf Digital 8-track Recorder
Tascam 8 track recorder won't play back recording
Does it use MiniDiscs? If so, it cannot work with standard audio MiniDiscs, it requires a special DATA MD.
Jan 21, 2010 | Tascam Dp-02cf Digital 8-track Recorder
Printing Problem
i got my dp-301u to work fine with my hp1020 on 2 different workstations with the following steps.
1. install printer locally via usb and test.
2. create a second printer as per the dlink manual creating a port. don't worry about the name as we will delete it.
3. once created go into the properties of the 2nd printer and change the port to something local - anything will do to free up the port.
4. go into the properties of the printer that was created in step 1. and change the port to that of the print server.
5. test print. should work fine.
cheers!!
Aug 11, 2009 | D-Link DP 301U (DP-301U) Print Server
Unable to record or playback on new DP 02
It sounds like either the inputs are not assigned or the tracks are not armed for recording (or both).
Here is a quick explanation of the procedure involved in recording with the DP-02 that I posted for another person who was asking for some basic instruction on how to record. You might be missing a step somewhere along the line as for instance you will still see the meters move even if you don't have the inputs assigned or don't have any tracks armed, but the DP-02 won't record anything until you do both.
To record you need to first assign your input to a track, then arm the track for recording, and then press play + record at the same time.
1. So you would patch your mixer output, mic or instrument into an input on your DP01 (say input A). You can run some audio to set the level with the input level knob (located next to input A on the front panel).
2. Then to assign that input to a track simply press and hold the 'input A' button and then press the 'rec' button of the track you with to record on. The 'rec' button will flash rapidly to indicate that the input is assigned to the track.
(To assign the input to a different track you have to clear the input assignment from the first track and assign the input to a new track. To clear an assignment press the input assign key, A in this case, and the track it's assigned to will flash its 'rec' button. Hold down the input assign key and then press the flashing 'rec' button. The button will stop flashing and the input can then be assigned to another track by following step 2 again).
3. Next, to arm the track for recording simply press the 'rec' button for that track. The 'rec' button with flash slowly.
4. To begin recording press play + record together in the transport section and the 'rec' light for the armed track will stop flashing and light steadily. Press 'stop' to end recording.
This should get you started. The operation of the DP02 is actually pretty intuitive once you've gone through it a couple of times (which is one of the real strengths of the unit). You'll be multitracking like an expert in no time.
Hope this helped.
Cheers,
bd.
Nov 25, 2008 | Tascam 2488 Portastudio Multitrack...
Unable to setup printer driver fro D-Link DP-301U
I'm not able to install the printer driver Officejet 5610 when conenct to D-Link DP 301U. It always prompt for missing file such as hpzimc09.dll hpzstw09.exe, I'm using the CD proviede when I purchase the printer and also try on the installtion file downlaod from HP website.
May 22, 2008 | D-Link DP-301U (790069251979) Print Server
Wireless laptop not printing
Indeed, you don't need the print server. Since your HP 6310 already has an integrated network port, you may setup and use it on your laptop the same way you do with your desktop. If you can browse the Internet wirelessly with your laptop, you should also be able to print.
Jan 20, 2008 | D-Link Air Plus DP-G310 (dpg-310) Print...
CC, SAP PIP
1) Try hard reset = unplug TV for some time,plug-in,try again.
2) Follow guide instructions carefully = one missed step is all it
takes
3) Consult owner operator manual
4) Further help? provide Model # off back of set..................T.
Jan 02, 2008 | RCA Universal Remote Control
Computers & Internet Logo
291 people viewed this question
David Payne
David Payne
