Question about Sharp Televison & Video
What is the factory settings of sharp LCD model 60le640x
How can I re-set a Sharp model 1C 24" LCD TV back to the original factory settings? My son set 5 seconds on the sleep timer so the TV doesn't stay on long enough to re-set with the remote
There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts.
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
Jun 30, 2017 | Sharp Televison & Video
I have a Sharp Aquos LC-60LE640X TV and I am trying to connect a Samsung HW-H751 Soundbar to it. I have hooked up the optical cable, adaptor and sub woofer, I have tested the Bluetooth function throug
If you are connecting the soundbar to your TV with the digital audio cable, make sure to select "D IN" using the source button on the soundbar. Bluetooth (BT) is a separate source from another device. (phone, etc.) The TV will need to be set to use the digital audio output and probably PCM format. (?) The subwoofer is preconfigured at the factory to mate up with your soundbar. (See below instructions - your soundbar includes the amplifier:)
Digital audio output setting:
After connecting an amplifier with digital audio input and
external speakers as shown, you should set an audio
output format compatible with the programme you are
watching or the device connected.
Go to "HOME" > "TV Menu" > "Setup" > "Option" >
"Terminal setting" > "Digital audio output" > select
"PCM" or "Bitstream".
NOTE
• When set to "Bitstream", Dolby Digital is output when the Dolby
Digital or Dolby Digital Plus audio formats are received. When
set to "PCM", PCM is output no matter what audio formats are
received.
• When set to "Bitstream", HE-AAC audio formats can be output
as Dolby Digital.
Jan 24, 2015 | Sharp Aquos Televison & Video
I bought a Sharp 52" LCD stuck in demo mode
Hi jmartinezua,
Here is how you fix this:
Go to menu--> setup --> reset
This will reset your TV to factory settings. The Demo Mode will cease.
JJ
Feb 23, 2010 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Forgotten password for sharp tv model #LC-19SB25U
Its in the user's manual. Press menu, setup and find 'reset' to factory settings. It will require inputting all changes you made...
Dec 27, 2009 | Sharp LC-19SB25U 19 in. LCD HDTV
My sharp aquos 32' LCD has a heavy green tint to it. I tried reseting the settings back to factory settings, but it didn't help.
My sharp tv also had a green tint and resetting to facotry setting did not work, what finally worked is making sure that all cables were inserted all the way into the tv and receiver. Someone else advised this for another Tv and it worked on my sharp so it is worth a try.
Aug 19, 2009 | Sharp AQUOS LC-32D44U 32 in. LCD TV
I have no 'input selection' on my Sharp HDTV 37", model LC37DW99U
On your menu, go to the channel settings. Go to add/delete channel. You will have to add this channel manualy. The tv might have went into autoprogram mode and deleted it.
Feb 02, 2009 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Remote stopped working
frpm baldmeaney i unpluged my tv same model for 5 min and all was well again . this may work for you . good luck!
Dec 31, 2008 | Sharp LC52SB55U LCD TV
Televison & Video Logo
41 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
