Corded unit appears fine until incoming call comes in and unit resets. You cant answer phone calls because unit resets. Other phones on the same line can pick it up, then Siemens can pick up line. LCD display goes blank when unit resets. Could be a overload from ring voltage coming in from line while ringing. Anyone out there have any experiences like this?
OK, here's what happened. I had the same issue of the phone resetting when a call came in, I thought it was a power issue and through some testing it was not. Here's the fix...Menu \ system settings \ enter pin (if you haven't changed it it is 0000) scroll to factory default and reset. This fixed the problem somehow for me, make sure to write down any impotant messages because it will erase everyting (silly me). I hope this helps.
Your caller id log is full, you can fix your phone by pressing the Calls button, then the delete button over and over until it is empty. This will fix your problem without deleting all your programming.
I have the same phone with the exact same problem it is driving me crazy. I have tried everything and think it may be the power supply. I have 3 of these phones and they all do the exact same thing when plugged in.
forasong's solution worked. Thanks! -max1ornot
The factory default reset worked for me too!
