Question about Sharp Televison & Video
I have sharp LCD 60le640x the red light is flashing what do I do please
javswr
  • 44 Answers
SOURCE: lcd tv
Hi!
Sounds like you have a bad power supply board! This is not hard to do yourself, as long as you are somewhat handy! Take the case apart (back side), and look for some bad caps (capacitors) on the power supply board. They will look bulged on the top an may be a little leaky (brownish stain).
If you see this problem, you can buy a new power supply at www.shopjimmy.com or ebay. You will need the make and model, of your tv to order! Good luck, I hope this is helpful!!
Posted on Mar 08, 2009
ginko
  • 19396 Answers
SOURCE: LC-37AF3X Sharp Aquos KCD TV
If the TV goes in standby, then it is in protection mode.
Ensure also that the fault is not coming from a faulty receiver box sending
bad signal, check if you get same problem on DVD with no receiver box
connected.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible causes.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , starting the flashing light.
If you are in situation one, then the TV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
If you want to DIY you find parts here,
All: Appliance parts, electronics parts & more from PartStore.com
Encompass Parts Distribution
LCD/Plasma Electronic Replacement Parts: Plasma & LCD TVs, Appliances |
On LCD Pay particular attention at inverter and power board, power board can be inspected looking for bulged or leaking capacitors, then tested with a multimeter. The inverter is more difficult to test , there is need to read voltages, should be done by a tech. Also the LCD controller board can cause same problem
On Plasma, test Sustain (Ysus/Zsus) / Buffer boards , cables to plasma, digital board and power board.
On Rear Projection : check lamp, lamp ballast, power board, and convergence.
On CRT TVs, check ballast , flyback transformer, CRT, Tuner, Convergence.
Posted on May 05, 2009
  • 321 Answers
SOURCE: Sharp LCD flashing red light and no picture
yes thats is a common problem for all flat tv not only
sharp ;/ first theres is capacitor in power supply
you probly have few one there blow up and it could bee from the power section of your back light circuit
a good technician can fix that easy
good luck
Posted on Apr 02, 2010
  • 16 Answers
SOURCE: 37"sharp aques lcd red flashing
It is a problem with your power supply board. It is most common on LCD tvs. If you know a little about electronics and soldiering you can fix it. What you need to do is take the back of the tv off and find the power supply board, easiest way is to follow the connector for you power cord up to it. Then i want you to look at the capacitors on the board, the are the cylinder looking things and they should have a metal top to them. Those tops are suppose to be flat, if any of them are raised that means that capacitor is bad. You can read the rating of the capacitor on the side of it and by new ones. I would suggest high temp 105 degrees C ones for tvs. To take them off its as easy as taking the board out, desoldiering the two connections on the bottom, pulling it off, and sticking in the new one and resoldiering it. Make sure when you put the new ones on that you line up the side with with the positive line to the same side that the old one came from, the positive line looks like a greyish stripe down the side of the capacitor. Do this to all that apply, you will need a desoldiering gun that cost like 10 bucks at a radioshack to take the soldier off properly.
Posted on Sep 06, 2011
maatmartin7
  • 1229 Answers
SOURCE: My Sharp 19" LCD Tv
Bad capacitors in the power supply are common on most of these small Tvs. I have not repaired this model, but my suspicions and expeience tell me where to start! Thanks for asking and show all hands of support!
Posted on Sep 13, 2011
Power light comes on along with OCP light. No screen or sound. internal switching noises coming from inside the tv
Sharp TV - Flashing OPC & Power Lights - YouTube
? 0:50
https://www.youtube.com/watch?v=BH1OcQ6dIEE
Jul 1, 2011 - Uploaded by Tweetssun
Sharp Aquos TV flashing a OPC & Power Lights in a pattern of 3 flashes, ... Sharp Aquos LC-32D44 - One blink lamp error - Nopicture or sound - Diagnosis ... Repairing Flat Screen TV - Blacked out with blinking red light ...Missing: 32dv22u
Sharp lcd tv power button flashing - HDTV - Streaming Video & TVs ...
www.tomsguide.com/forum/54708-4-sharp-power-button-flashing
Feb 8, 2012 - 7 posts - ‎3 authors
We have owned a Sharp 32" LCD TV for about two years. ... However a quick Bing search shows that the blinking green light usually means a bad power board, which seems ... No picture, no sound, just a black screen and two blinking green ... a cable surge block on the coax where it comes into the house. Sharp lcd tv power button flashing - Digital TV
Oct 14, 2012
Sharp hd tv blinking power no picture - Digital TV
Jan 7, 2012
More results from www.tomsguide.com
Missing: 32dv22u
Sharp Aquos LC 42DH77: Inverter, Backlight, Power and ...
www.normsweb.com/tektips/42dh77.shtml
Jan 31, 2016 | Sharp LC-32DV22U Widescreen 32-Inch Class...
Sharp model lc-20sh1u won't turn on, just makes a clicking sound and indicator light flashes red.
The clicking sound may be a power relay coming on and then off--problem indicates a trouble in the main power supply.
Nov 02, 2012 | Sharp LC-20SH3U 20 in. EDTV-Ready LCD...
My Sharp 19" LCD Tv
Sep 13, 2011 | Sharp 19 in. LCD HDTV
Hi, i have a 46"
dear user,
supply capacitor are weak.kindly change the capacitors
Feb 21, 2011 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
good luck
Apr 02, 2010 | Sharp AQUOS 52" Flat-Panel LCD HDTV
My sharp tv wont stay on, it flashes green
Hi i have seen this before sharp hdtv's are known for having the internal power supply go faulty
Feb 01, 2010 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
Flashing red light and
this is a inverter board defective, please send to repair shop, for repair.
Nov 29, 2009 | Sharp Aquos LC-30HV4U 30 in. LCD HDTV
Blinking power light.
i hve the same problem. I turned on my Sharp Aquos lc-32d62u HDTV last night for the first time, but it is black and a blinking green light.
did you find a solution?
Mar 06, 2008 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
Blinking lights
i have same problem, do anyone know how to fix it? thx
Jan 10, 2008 | Sharp LC-32P50E 32 in. LCD Television
Televison & Video Logo
63 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
