How do I stop the CD tray from opening just after it closes, so that my disk can be read?
I was unable to open my CD tray, so i carefully disassembled the unit using the manual and checked the belt, which was fine. I lightly lubricated the guide shaft with lithium grease, and puffed air lightly yo dispel any dust inside. After re-assembling, the disk tray now opens, I put on a CD, press close which it does, but then a few seconds later it opens again - without reading the disk or allowing me to play it. Could it be due to the levers at the back of the disk tray, or over-lubrication ... or what? Many thanks in advance for your ideas ...
    New Friend:
    Problem Solver:
  • 15 Answers
It might be the lazer that reads the disc
Posted on May 03, 2017
  • 883 Answers
SOURCE: CD opens and closes perpetually. CD won't play.
likely yes. does not sound like coincidence. try this: search ebay for an AS-IS item for $1 and use it for part-swapping. first to swap-the main circuit board holding the micro chip.
Posted on Jun 04, 2007
SOURCE: CD drawer will not open or close
Had The Same With Mine. Its was the belt Inside that joins Motor To Cd Tray. Its Black and directly under the cd tray at the front. Its probably either loose like mine of maybe broken. I replaced mine with an elastic band and its been fine since.
Posted on Oct 29, 2007
  • 31 Answers
Hi, The CD drawer mechanism needs a new belt. They have a motor that drives the tray mechanism, and there's a small belt that drives the main gear so that pushing the drawer in gently to close it doesn't damage anything. However, once that belt breaks/wears out, the drawer will stay in whatever position it was last in.
Posted on Sep 17, 2008
  • 107 Answers
SOURCE: Technics SC-CH515 CD Tray Does Not Stay Open
I DO NOT think that problem related with CD cleaner
3 possibility here
1 The loading belt was lose it can not open fully to reach the switch open when the time limited was out as program design from system control it automatic close
2 The loading gear system out of position 1 tooth
3 Dry joints on switch open and close or connector from CD tray to system control intermittent contact
In any case it require a qualifier Tech from Panasonic to reset the timimg gear or service
I hope that give you some ideas if you need further info or service manual I am willing to help you out
Posted on Dec 10, 2008
SOURCE: CD Player tray will not rotate or open or close - no power
my cd player will open and rotates but will NOT play, can anyone help me?
Posted on Dec 04, 2009
The disktray automaticly opens and closed several times. When I put a cd in de tray the tray closed and opend without playing
Hi, when a disk tray automatically opens and closed several time, might be from the disk tray itself is jambed that's why it opening and closes by itself. You can open up the player and check if any thing in hooking it.
Also it might need to be replaced, the wheels inside the DVD player might be too weak to move in and out without moving automatically.
The way i see it, you might end up replacing the disk tray with a new one..
Have a nice day.
Feb 18, 2011 | Audio Players & Recorders
Will not read disks. Cycled power usally worked not this time.
First Turn your X-box on
Second Take out your game or CD
Third Open tray
Fourth Close tray
Fifth Repeat Third and Fourth a couple times and let it load then open
Sixth Stop when you hear the xbox make a spinning noise like when it is reading a game
Seventh Open tray
Eighth Pit a game in
Ninth Close tray
Tenth Play you game!
Dec 30, 2010 | Microsoft Xbox 360 Console
The upper disc tray, the DVD-RW, will not open. It read the disk inside, but only makes a clicking sound when I press the button to open it. I disassembled the Computer, and removed the tray. However, I...
Use a straightened paperclip to insert in the hole found on the front of and underneath the tray (different makes different positions but all at the front). You may have to use a little force, but not too much. The mechanism uses a cantilever action to push the tray out.
Let me know how you go.
Dec 17, 2010 | HP Pavilion a775c (A775CB) PC Desktop
My Xbox 360 isn't reading any discs. Games nor Movies. When i put either in the game console it tells me to open the tray because it didn't the way it makes a funny noise when it tries to read the...
take out the cd. close the tray with no disk in it. let it read till it says open tray
open and close it like 3 times with tha method mentioned above with out the disk. then put the disk back in and it will probly work.
sometimes the system turns dumb and u haft to remind it to reconize when there is actally no disk.
Oct 25, 2010 | Microsoft Xbox 360 Console
Disk placed wrongly and cannot be read.
  • shut the computer off..
close to the eject button you will find a small pin hole
straighten out a paper clip and push it strongly into the hole and the drivr will pop open.. even if just slightly,, just pull out the draw and remove the disc.. close draw firmly and turn on pc..
the pin hole is there trust me..
Mar 18, 2010 | Acer Computers & Internet
I put a blank CD into the tray to record. It
If there is a tiny hole somewhere near the tray you need to poke a needle or something like that in there to open the tray.
Dec 02, 2009 | Philips CDR785 3-Disc CD Recorder
Open tray on xbox when it's closed
when the tray is closed and it does not
see a cd it should say open tray
The problem weak or dead laser
laser are chep 30.00- 40.00
and not to hard to swap out.
second it may be a bad drive motor
or bad spindel motor .in that
case you will to buy a new
drive and swap out the P.C. board
from the old drive to the new one
Sep 16, 2009 | Microsoft Xbox 360 Console
My NAD C251i CD player isn't reading disks - platform stops short
To fix it, you need to replace the spindle motor top bearing. The bearing is worn and the player mistracks as the armature moves about under the changing drive conditions. Makes the player mistrack and skip. Because the disc is spinning fast.
Replacing the bearing should resolves the problem.
Hope this helps and have a great day!
Sep 01, 2009 | NAD C521 CD Player
360 disk tray
What I did was took apart my Xbox and put the disc tray back on the tracks, carefully lifting it over the circle thing in the middle. When I lay my Box down horizontally, it opens and closes fine.
Jul 27, 2008 | Microsoft Xbox 360 Console
Cd tray error Canon Pixma MP810
Sorry a little late only just read your problem.
The location is not the bottom tray feeder but the disk tray. In settings change your media type to "Printable Disk" the paper scource should automatically change to "Disk Tray" and hopefully every thing will work OK.
May 19, 2008 | Canon PIXMA MP810 All-In-One InkJet...
109 people viewed this question
