Question about OEM Systems 2003-2010 FORD EXPEDITION 4 Button Remote Keyless Entry Key Fob with Quick and Easy Programming Instructions
The transmitter or module it says ford security system on it it caught on fire and now i can't find another one
  • OEM Systems Master
  • 3,497 Answers
Have you tried a ford dealer or a locksmith
Posted on Apr 26, 2015
  • Trena Mowitch
    Trena Mowitch May 06, 2015
    yes i tried a ford dealership but they were unable to find the part. i took the one that caught on fire into the dealership. even though it says FORD vehicle security system right on it they could not find a replacement. The previous owner had a blow and go installed but since removed the box that everything runs thru is what caught on fire. it controls everything starter, ignition, doors everything is wired to this box and I can not start my car without it. any suggestions
03 Lincoln Navigator - No Door Locks, Auto Lights - Already used process of elimination - missing something - Help!
Simple fix; bring the vehicle to the dealership and let them reprogram the system!
Feb 21, 2017 | Ford Cars & Trucks
I went through programing as far as lock recycling but wont go any further
Remote Transmitter Programming NOTE: All keyless entry remote transmitters must be programmed at the same time.
NOTE: Programming (or reprogramming) the keyless entry remote transmitters into the central security module can be accomplished using a diagnostic tool or by carrying out the following steps.
  1. Turn the ignition switch from OFF to RUN eight times within 10 seconds, ending in RUN. If the module has successfully entered program mode, it will lock and then unlock all doors.
  1. Within 20 seconds, press any button on a keyless entry remote transmitter, and the doors will lock and then unlock to confirm that each keyless entry remote transmitter has been programmed. Repeat this step for each transmitter.
  1. If the door locks do not respond for any keyless entry remote transmitter, wait several seconds and press the button again. If the door locks still fail to respond, refer to Inspection and Verification.
  1. Turn the ignition switch to the OFF position, or wait up to 20 seconds after Step 2, to exit program mode. If a keyless entry remote transmitter has been programmed (or reprogrammed), the doors will lock and unlock one last time to confirm.
Mar 18, 2016 | 2004 Ford F150
2004 ford expedition eddie bauer All the doors won't lock/unlock, just make a buzzing sound repeatedly. Also does this when shutting the vehicle off.
What makes a buzzing sound , the door lock actuators ? Or where do you hear the buzzing coming from if not at the doors ?
Power Lock
The power lock/unlock feature requests all of the vehicle doors, including the liftgate, be locked or unlocked upon a customer request from any interior door lock switch in the vehicle. The power door locking system functions independently of ignition status or vehicle speed. When the vehicle security module receives an unlock/lock command from any door lock control switch, the vehicle security module will activate relays internal to the module to supply the correct power and grounds for the door lock actuators.
Visual Inspection Chart Mechanical Electrical
  • Binding latches
  • Central junction box (CJB) fuse(s):
    • 5 (7.5A)
    • 30 (30A)
  • Circuitry
  • Relays
  • Remote transmitter
  • Keyless entry keypad
  • Vehicle security module
  1. If an obvious cause for an observed or reported concern is found, correct the cause (if possible) before proceeding to the next step.
  1. If the diagnostic tool does not power up, refer to the diagnostic tool manual.
    1. Carry out the diagnostic tool data link test. If the diagnostic tool responds with:
      • SCP, UBP or ISO; all elctrconic control unitw, no response/not equipped, refer to Section 418-00 .
      • No response, not equipped for vehicle security module, refer to Section 419-10 .
      • System passed, retrieve and record the continuous diagnostic trouble codes (DTCs), erase the continuous DTCs, and carry out the self-test diagnostics for the vehicle security module.
    1. If the DTCs retrieved are related to the concern, go to the Vehicle Security Module Diagnostic Trouble Code (DTC) Index to continue diagnostics.
    1. If DTCs are retrieved that are not found in the following Vehicle Security Module Diagnostic Trouble Code (DTC) Index, refer to the Master Vehicle Security Module Diagnostic Trouble Code (DTC) Index in Section 419-10 .
    1. If no DTCs related to the concern are retrieved, proceed to the Symptom Chart to continue diagnostics.
Jan 13, 2016 | Ford Cars & Trucks
Need to change fuse on remote keyless entry but don't where it's located on fuse box on 2004 explorer
Do any doors lock/unlock with remote keyless entry ?
  • The doors do not lock/unlock using the remote transmitter
  • Remote transmitter battery.
  • Remote transmitter.
  • Remote transmitter programming.
  • Aftermarket system.
  • High power devices.
  • TV/radio transmission towers.
  • Vehicle security module.
  • Go To Pinpoint Test C .
Pinpoint Test C: The Doors Do Not Lock/Unlock Using The Remote Transmitter
Normal Operation
Remote locking and unlocking of the doors is accomplished by the vehicle security module receiving a command message from the remote transmitter. The vehicle security module processes the command and sends a signal directly to the door lock actuators.
All remote transmitters must be present to begin diagnosis of the remote keyless entry (RKE) system.
Aftermarket or dealer-installed systems may adversely effect the RKE system operation. These systems should be disconnected before diagnosing any RKE concerns.
  • Latches
  • Battery junction box (BJB) fuse(s):
    • 2 (30A)
    • 16 (15A)
    • 22 (20A)
    • 29 (60A)
  • Central junction box (CJB) fuse 20 (5A)
  • Circuitry
  • Relays
  1. If the cause is not visually evident, connect the diagnostic tool to the vehicle to be tested from the diagnostic tool menu. If the diagnostic tool does not communicate with the vehicle:
  • Check that the program card is correctly installed.
  • Check the connections to the vehicle.
  • Check the ignition switch position.
  1. If the diagnostic tool still does not communicate with the vehicle, refer to the diagnostic tool operating manual.
    • SCP+, SCP- OR UBP circuits fault; all electronic control units no response/not equipped, refer to Section 418-00 .
    • No response/not equipped for vehicle security module, refer to Section 418-00 .
  1. If DTCs are retrieved that are not found in the following Vehicle Security Module Diagnostic Trouble Code (DTC) Index, refer to the Master Vehicle Security Module Diagnostic Trouble Code (DTC) Index in Section 418-00 .
Nov 18, 2015 | Cars & Trucks
Remote car starter donot work
just open the remote transmitter key Fob and check battery and replace it with new one.if this does not work then detail testing of remote module is required w.r.t programming and connections.
Dec 20, 2011 | Ford Vehicle Parts & Accessories
I have a 96 ford conversion van with a 600 plus addon keyless system and need to program new keyless remots , need to know how to get system in program mode.
Hi.
To program ( or reprogram ) a keyless entry remote transmitter into the remote keyless entry module, perform the following steps:
1. Turn the key to ON or ACC and short the two terminals of the program connector, a two-pin connector located below the driver's side of the instrument panel at the base of the steering column. All doors should lock and then unlock.
2. Press any button on each keyless entry remote transmitter in turn. All doors should lock and then unlock. If the door locks do not respond, press the button again (up to three times maximum with the same keyless entry remote transmitter). If the door locks still fail to respond, go to Pinpoint Test A.
3. Repeat Step 2 to program additional keyless entry remote transmitters into the remote keyless entry module (up to four keyless entry remote transmitters maximum).
4. Turn key off.
5. Remove the short from the program connector. All doors should lock and then unlock.
6. Verify that the keyless entry remote transmitters have been successfully programmed by pressing the LOCK or UNLOCK button on each one, and observing that the system responds by locking and/or unlocking the doors.
I hope this helps you.
Thanks!
Nov 28, 2010 | 1996 Ford Econoline
I need to program my transmitter to work with the db dlm-3 for a 2003 suburban. The transmitter is also operating a silencer alarm model 6918a. It is a silencer 4 button transmitter
the db-dlm3 is a module to make your door locks work with any alarm. the transmitter is not programed to the module but to the alarm if you need to program transmitter turn key to on position push valet 5 times then hit lock button on remote
Dec 10, 2009 | DB-DLM-3 Door Lock Module
Keyless remote wont work
try to reprogram the remotes using these instructions..........
i assume for 02 explorer not th 05 frestyle listed (although similar procedure)
Remote Transmitter Programming NOTE: All remote transmitters are programmable and must be set at the same time.
  1. Make sure that the anti-theft system is not armed or triggered and key code programming is not active.
  1. Open the door, then press the driver door lock control switch UNLOCK button.
  1. Turn the key from OFF to ON 8 times within 10 seconds, with the eighth turn ending in ON. If the program mode is sucessfully entered the doors will lock and unlock to confirm.
  1. Press any button on a remote transmitter, and the doors will lock and then unlock all doors to confirm that the remote transmitter is programmed. All remote transmitters must be programmed within 20 seconds of each other. Up to four remote transmitters can be programmed to the vehicles security module each time programming mode is entered.
  1. If the door locks do not respond for any remote transmitter, wait several seconds and press the button again. If the door locks still fail to respond, refer to Locks, Latches and Entry Systems — Late Build or Locks, Latches and Entry Systems — Early Build in this section.
  1. NOTE: Exiting is acknowledged by locking and unlocking the doors if at least one remote transmitter has been programmed.
    Exiting the programming mode is accomplished if one of the following has occurred:
    • The key transitions to OFF.
    • 20 seconds have passed since entering programming mode or since the last remote transmitter was programmed.
    • Four remote transmitters have been programmed.
Jun 02, 2009 | 2005 Ford Freestyle
Need to program autopage 5b remote
Note: This mode will only retain the last 4 remote transmitters programmed. If the transmitter memory is exceeded,
the security system will start deleting transmitters from memory in chronological order.
1. Turn the Ignition 'switch ‘OFF/ON’ 3 TIMES and stay in ON position. Within 15 seconds.
2. Push the Valet switch 3 times and holding in on 3rd push until a long chirp is heard then release the valet switch.
You are now in the Transmitter programming mode.
3. Press and hold any button of the transmitter until the siren responds with a confirming chirp, indicating the signal
has been stored into memory.
4. If you have additional transmitters (up to 4) that need to be programmed, repeat step 3 for each transmitter.
Exit: Turn Ignition to 'OFF' position, or leave it for 15 seconds. 3 long chirps & 3 parking
light flashes will confirm exit.
Feb 17, 2009 | Megatronix - TW71 - 5 Button 2 Way LCD...
The black box under drivers seat caught fire
Hello, nothing to my knowledge is factory. After market music AMP or security system? Any markings remaining on box? Perhaps followings wire down to where it goes could be of help. Does the car still run okay?
Dec 21, 2008 | 1992 Ford Escort 4 Door
OEM Systems 2003-2010 FORD EXPEDITION 4 Button Remote Keyless Entry Key Fob with Quick and Easy Programming Instructions Logo
195 people viewed this question
Top OEM Systems Home Security Experts
Lawrence Oravetz
ka4iup
ka4iup
Jerry Kramer
Jerry Kramer
Are you an OEM Systems Home Security Expert? Answer questions, earn points and help others
