Question about 3100L 1way Security System
Avital 3100 keyless entry remote sets off alarm when trying to unlock or lock doors with remote. Doors stay unlocked but alarm keeps sounding off and car wont start.
Avital 3100 alarm keyless entry system The armed red light inside car keeps flashing even though doors are unlocked. If I try to unlock or lock doors with the keyless entry remote the alram starts going off and doors stay unlocked. I try to start the car and it wont start. The red light stops flashing when key is in ignigtion and turned to the on position. Miraculously got the car to start by turning key ignintion to on position turning lights on and cranking car. While driving the car the alarm kept sounding off during my drive home. Not sure what to do no atter what I do the alarm stars to go off. It seems as though the alarm is in a armed state regardless if doors are locked or unlocked or f the car is on or not. Any suggestions?
    Sergeant:
  • 206 Answers
Hi'
i think the wire that connects to the door trigger for the interior light
a negative or a positive one has been mixed up
if its neg change it to the positive one
if its positive change it for the negative one
Avital 3100 keyless entry remote sets off alarm wh - 25666027-extj4arg1t42xbh3l3byl5v2-3-0.jpg the purple or green wire
cheers
Posted on May 29, 2015
4 Suggested Answers
logosc75
  • 625 Answers
SOURCE: I am trying to remote start my car and it wont
The secondary chirp alerts you to an open trigger, probably the hood pin switch since the car is not remote starting. Check under the hood for a broken or bent out of place hood pin switch. Make the adjustment so the pin makes contact with the hood when the hood is closed.
Posted on Feb 05, 2011
  • 1833 Answers
SOURCE: After starting vehicle with remote
According to your problem you can first change your remote battery to if it is not malfunctioned for battery. Before start the vehicle press lock key for 1 second to lock the door from remote. If the door locks are connected then horn will honk and the parking light will flash once. If the system is armed then status Led will flash once per second. After check it you can start your vehicle. But don't remote start your vehicle when the key is in ignition. It may help you to solve your problem.
To know more you can follow the manual.
Posted on Mar 16, 2011
replacemyrem
SOURCE: I bought a used Ford Crown Victoria with an Avital system installed and the seller told me the way the system was setup was using the keyless entry to unlock the doors as the only way to start the car
Nice i totally agree with it thanks for your useful contributions.
Posted on Dec 29, 2014
How do I reset keyless door entry that is in lock out mode
Viper Keyless Entry Systems
https://www.viper.com/car/keylessentry/
Viper is the industry leader in keyless entry systems. Add the convenience of keylessentry to virtually any vehicle - even vehicles without power door locks!
Alarms, Remote Car Starters, Keyless Entry & Locks - JC ...
www.jcwhitney.com > Audio, Video & Electronics
20 out of 32 products in Alarms, Remote Car Starters, Keyless Entry & Locks ..... ofKeyless Entry & Car Alarms allow you to lock and unlock power door locks.
How to program your keyless entry keypad - Ford Ownerhttps://owner.ford.com/.../locks.../how-to-program...Ford Motor CompanyDiscover how to lock and unlock your doors and how to program memory settings that will adjust seats & mirrors for each driver.SecuriCode™ Keyless Entry Keypad - Ford Ownerowner.ford.com/.../locks.../securicode-keyless-entr...Ford Motor CompanyLearn how to set a 5 digit SecuriCode on the Ford keyless entry keypad. ... Sign out. Register/Sign In · Your Vehicle. Service & Maintenance. Service & .... vehicle's SecuriCode keypad to lock and unlock your doors without having to use a key. ... Thekeypad will go into an anti-scan mode if you enter the wrong code seven ...How Programming Your Keyless Entry Can Make ... - Ford Life
Jan 08, 2016 | Cars & Trucks
Avital alarm wont lock or unlock doors
If the remote is arming and disarming the alarm then, it should be locking and unlocking the doors as well. The door lock and unlock wires need to be connected. Are sure that they are connected? Do the door locks work with the switch?
Mar 03, 2014 | AviStart 5303 2-Way Security / Remote...
When locking doors they unlock
What's the year, make and model of the vehicle? Are you saying that the door locks cycle...like the door is open when you try to lock it?
Dec 14, 2012 | 2101L Keyless Entry
The way the system was set up?! Here is what it sounds like. If you cannot start the car with the key but, you can start it with the remote starter means two things; the car has a starter inhibit installed and it's active or, the starter wire is cut and isolated from the ignition cylinder and the remote starter is connected to the starter side only of said cut wire.
About the keyless entry; Ford vehicle have a battery save mode that, after 10 minutes or so, the GEM module goes to sleep. The installation of a keyless entry system on these vehicles require connections at the unlock, driver's door ajar/latch wire and factory alarm disarm and programmed to double pulse. This will wake up the GEM and unlock the doors.
Nov 19, 2012 | Avital Vehicle Parts & Accessories
I have a 2000 ford mustang. Suddenly my keyless entry remote stopped working. I replaced the battery and turned the off and on 8 times and the locks cycled. after which i pushed the unlock but nothing...
The keyless entry system is controlled by the (GEM) - generic electronic module .
Keyless Entry The electronic door lock system has two main components:
  • generic electronic module (GEM)(14B204)
  • keyless entry remote transmitter (15K601)
  • NOTE: Battery power and ground must be remove before disconnecting the GEM connectors to avoid setting false codes.
    Power Locks Operation The power locks feature allows the customer to lock and unlock the doors via momentary switches located on the driver and passenger door. When the GEM detects a momentary press of the driver or passenger lock button, the GEM will supply power to the driver or passenger lock actuators for approximately 250 ms from relays internal to the GEM. When the GEM detects a momentary press of the driver or passenger unlock button, the GEM will supply power to the driver or passenger unlock actuators for approximately 250 ms from relays internal to the GEM.
    Remote Keyless Entry Door Locks Operation The remote entry feature allows the customer to unlock the driver door, unlock all doors, and lock all doors using a valid remote transmitter as long as the ignition switch is not in RUN or START. The driver door is unlocked whenever the GEM detects a valid remote transmitter unlock transmission. All the doors are unlocked when the GEM detects a second valid remote transmitter unlock transmission within three seconds of the first transmission. All the doors are locked when the GEM detects a valid remote transmitter lock transmission. If the GEM detects a second valid remote transmitter lock transmission within three seconds of the first transmission, the doors will lock again, the horn will sound for 20 ms and the parking lamps will flash for 200 ms to indicate the doors are locked. If the GEM detects the driver or passenger door is ajar during the second lock transmission, the doors are locked again and the horn is sounded twice. If the GEM detects a valid remote transmitter lock transmission within three seconds of detecting a valid remote transmitter unlock transmission, the GEM will lock all the doors
    • The doors do not lock/unlock using the remote transmitter
    • Ignition switch.
    • GEM.
    • Remote transmitter.
    • Remote transmitter batteries.
    • GO to Pinpoint Test C .
    You followed the program instructions to the letter ? Programming -Keyless Entry Remote Transmitter NOTE: All keyless entry remote transmitters (15K601) must be programmed at the same time.
    NOTE: All previous transmitter identification codes (TIC's) will be erased when programming mode is entered.
    NOTE: To program (or reprogram) the keyless entry remote transmitters into the generic electronic module (GEM)(14B204), perform the following steps.
    1. Turn the ignition from OFF to RUN eight times within 10 seconds, ending in RUN. If the GEM has successfully entered program mode, it will lock and unlock all the doors.
    1. NOTE: The first TIC must be entered within 7.5 seconds of entering the program mode and additional TICs must be entered within 7.5 seconds of the first TIC. The programming mode is exited whenever the timing constraints are not met.
      Press any button on a keyless entry remote transmitter, and the doors will lock and then unlock to confirm that each keyless entry remote transmitter has been programmed.
    1. If the door locks do not respond for any keyless entry remote transmitter, wait for several seconds and press the button again.
    1. Turn the ignition switch to the OFF position, or wait up to five minutes after step 1, to exit program mode. If a keyless entry remote transmitter has been programmed (or reprogrammed), the GEM will lock and unlock all the doors one last time.
    1. Take an have the vehicle checked for DTC'S
B1396 Power Door Lock Circuit Short to Battery GEM GO to Pinpoint Test B . B1397 Power Door Unlock Circuit Short to Battery GEM
Apr 12, 2017 | Ford Mustang Cars & Trucks
My valet remote control RPN491 Starts vehiclr and unlocks doors but will not lock doors do I need to reprogram remoteto unlock doors?
Ok you said "unlock doors' but you said it already unlocks the doors. This remote should lock and unlock door on same button, if you are describing the 2 button remote. If it is not then it could be alot of things. Does the alarm lock itself? Does the alarm lock the door when you turn on the ignition? More info is really needed. Like what veh and what model alarm.
Sep 11, 2009 | DEI Valet Keyless Entry System
2001 subaru impreza WRX unlocking doors with key
usually after opening the door you can deactivate the alarm by pushing th unlock button or simply insert keyy in ignition and turn it on.
Aug 13, 2009 | 2001 Subaru Impreza
Keyless Entry doesn't unlock my doors anymore
Did you get help? My problem is similar but not as bad. My viper550ESP no longer remotely unlocks the doors (well very, very occasionally it does). That is the only problem.
Jul 21, 2009 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
Keyless entry stopped working on 05 cobalt now i have to unlock door with the key and when i do that the alarm goes off. Help
Lock all the doors from the inside (with all the doors closed), unlock your driver's door by manually lifting the lock, then press it back down after you are out - this will prevent the alarm from sounding when you use the key to unlock the door.
Aug 02, 2008 | 2007 Chevrolet Cobalt Coupe
3100L 1way Security System Logo
511 people viewed this question
Top Avital Vehicle Parts & Accessories Experts
D. E. Hev
baire
Billy Mac
Are you an Avital Vehicle Part and Accessory Expert? Answer questions, earn points and help others
