Question about Husqvarna Garden
Ran my husqvarna 445 out of gas now it won't start. What's the problem and what's the fix?
    Sergeant:
  • Husqvarna Expert
  • 398 Answers
It should not cause this type of problem. I suspect the diaphram in the carburetor is getting stiff and brittle. This prevents the fuel being pulled into the carburetor. If you can prime the unit and make it run, then you may need to have the carburetor rebuilt or replaced.
Posted on Apr 27, 2015
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • 484 Answers
Remove the spark plug and dabble about 6 drops of gas into the plug hole and quickly reinstall the plug and give it a go....sometimes that will be just enough to get one to fire good enough to take off.
I run my saws dry intentionally every time I expect them to sit idle for more than a month or two. Running them dry should not cause a 'no start' condition.
Posted on Apr 26, 2015
steve_lima
  • 181 Answers
SOURCE: fly wheel seemds locked up on Husqvarna 445
the flywheel does not have a brake,the clutch side has the break.if you have the chain side cover off the brake is no longer on the clutch drum.the fly wheel is on the oppiset side (starter rewind).take the starter rewind off and see if the motor will turn.if hte motor turns the problem is in the clutch side.if it doesn't the problem is in the flywheel side.the ignition coil has been known to loosen up.the screws streitch out from heat.check the air gap between the flywheel magnets and the ignition coil.should be .10 to .12 inches.if problem is on clutch side check to make sure that the springs are on between the clutch discs.they have been known to break and that does not let the chain spin on bar.any questions get me an e mail
Posted on Feb 11, 2009
  • 25 Answers
SOURCE: my husqvarna 445 starts and runs until full
chanes are the carb needs to be adjusted and the diaphrams in the carb need to be replaced over time they get stiff and hard from old feul, causing it to not pump feul and meter the feul properly
Posted on May 16, 2009
#1 Taper
  • 1040 Answers
SOURCE: brand new husqvarna 445, won't start
Try not giving any throttle when first starting. The newer trimmers are this way many times. (Maybe the newer chainsaws are this way now.)You prime the carburetor, set the choke and pull, but don't throttle until it runs for 10 or 15 seconds.
Jim
Posted on Jun 03, 2009
  • 154 Answers
SOURCE: new 445 husqvarna chainsaw will not start. it had
add new gas, plug,
Posted on Aug 02, 2009
  • 1015 Answers
SOURCE: How to start a Husqvarna 445?
Set choke to full on. To do this depress throttle all the way down and set choke lever to on. Pull starter rapidly until saw fires . Once it has fired set to start and pull starter cord until it starts. If it doesn't start in ten - twelve pulls,reset choke for two or three pulls,then switch back to start. Pull starter cord until it starts. When it starts it wii be at full R.P.Ms. Let run for twenty to thirty seconds. then move switch to run. Hope his helps, Thanks
Posted on Nov 18, 2010
445 HUSQVANA SAW QUITS
Sounds like fuel starvation, always start with simple things first, replace the fuel filter in the fuel tank, check the fuel hose up to the carb for signs of leaking.
Jan 18, 2013 | Husqvarna , No.455 Rancher, 20" Gas -...
My Husqvarna starts but won't accelerate when you pull the trigger, acts like the brake is on but the handle is in the free position.
It may be running very rich, make sure the air filter is clean, if ok. check the spark arrestor in the muffler outlet ( if fitted ) has not carboned up, if ok, check the exhaust port is not blocked with carbon.
Dec 30, 2012 | Husqvarna 445 18" 45.7 Cc Chainsaw...
Husqvarna 445 start/stop switch won't stay in choke
remove the top cover and see if the pins are broken from the sides of the lever
Sep 05, 2012 | Husqvarna Garden
New saw idles great, but when i give it gas it stalls out
MAKE SURE WHEN YOU START A JOB YOU NEED TO PULL THE UPPER BAR TOWARDS YOU IN ORDER TO RELEASE THE CARB CHOKE SENSOR.WHEN YOU DO A COLD START THE UPPER BAR GO TO THE FRONT POSITION TO WARM IT UP OR STOP SAW JOB.
Nov 09, 2010 | Husqvarna 16" 457cc Prosumer Chain Saw ...
Model 445 chainsaw. Was cutting all day and no problem. Good gasoline, Husqvarna 2 cycle oil. All of a sudden started racing like the carb was stuck full open even when throttle trigger released. Then...
Engine speeding up on idle is normally due to an air leak, check the carb securing screws are tight, if you have a leaking crank seal it will be a shop repair.
Feb 28, 2010 | Husqvarna Forest & Garden #966906636 445...
Changing the chain on husqvarna 445
make sure the chain brake is off. Then undo the two retaining bolts and take the cover off.
Sep 19, 2009 | Husqvarna Forest & Garden #966906636 445...
Brand new husqvarna 445, won't start
Jim
Jun 03, 2009 | Husqvarna Garden
Hi
there is too much gas accumulated at the plug.Remove the the plug ,turn the switch at off position and opperate the starter for few times until the cilinder has no gas inside.Try to start the engine.
regards savumihai71
Mar 15, 2009 | Husqvarna Garden
Garden Logo
74 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
