I was wanting to know how to get HDMI cord to work from the computer to yet
I am trying to hook my AOC tv up to my samsung bd-5900 Blu ray/ DVD player with hdmi cord but it still says no signal I don't know what else to do
The owner's manual says not to connect the power cord of the samsung until after you have made the HDMI connection. Try disconnecting the power cord for a few minutes. When you plug in and turn on, all should be well.
If that does not work, you may have a bad HDMI cord - try another one.
Oct 04, 2016 | AOC L19W89V 19 in TV
How do i connect my gateway zx6970 to tv
Hi
I don't know how helpful I can be but I will try.
Firstly. Are you selecting the correct HDMI input on the TV. I have four on mine, and need to select the correct one for what I want to view.
Secondly, have you got the HDMI outlet selected on the computer, via your graphics card controller, as I suspect that HDMI will not be the default outlet. I would expect automatic detection when connected, but that option may be disabled in the controller.
Cheers
Dec 26, 2014 | Gateway ZX6970 All-In-One Desktop...
I cant connect to my tv threw my acer laptop .
The TV probably doesn't have a resolution your graphics card can detect, you're going to have to get a different GPU if you want to do this, or possibly use an HDMI port since those will adapt and stretch the screen resolution.
Feb 22, 2013 | Computers & Internet
My acer aspire 7540-1317 has a broken screen and i want to connect it to my tv but i don't know if i have the right cord, i am using an hdmi cord going from the port on the computer to the port on the...
You are actually well on your way. Depending upon the make and model of your television an HDMI cable is all you will need. The rest of the process will require you to go into your control panel on your laptop and using your remote for your television. I have put together the steps necessary to connect your laptop to your television
  1. Connect HDMI cable to HDMI Connection on back or side of your television ( remember if you use HDMI 1 thru 4, you will need to remember it)
  2. Turn on Laptop and let boot. Loggin using your user name and password if you have one.
  3. Turn on television
  4. On your television remote press the HDMI button for the Connector you used, example ( HDMI 1, HDMI2, HDMI3, HDMI4) You will see a no signal on the screen until you get the right one, Once you have the right HDMI connection it will say Acquiring Signal then you will see your Desktop on your computer on your television.
  5. From here it is a matter of getting the screen resolution right for the best possible viewing experience.
  6. Happy Viewing
Jul 12, 2011 | Computers & Internet
I just want to know how to hook up a hdmi cord to an old big screen hitachi tv
You can't, at least not directly. Older sets don't have any HDMI inputs, only composite video (the yellow RCA jack) and possibly component video (red, green and blue RCA jacks). Converters that take an HDMI input and generate the necessary video outputs are available, but they aren't cheap. And don't fall for the adapter cables you might find advertised with an HDMI plug on one end and RCA plugs on the other that supposedly convert the signal for you. HDMI can only be converted with some active electronics; a simple cable just won't work. If you want to hook and HDMI-only device to your old Hitachi, you'll need the converter.
Dec 28, 2010 | Computers & Internet
What is the name of the cord i buy, or what do i need?
yes no problem m8 i would if i was you (unless you have one) get an hdmi gfx card for the computer install that and then its hdmi to hdmi in the tv and the card slots in but if you have not got one and want to use a normal go to maplands and ask for a normal output (tell him its blue not white or if its white on the back of the coputer tell him its white to scart
Mar 13, 2010 | E-Machines eMachines Desktop PC
I have the Panasonic TH-50PE8U plasma tv and a Dell Latitude laptop. I tried connecting those two together as the tv as a monitor but when i plugged it in and restarted the laptop it would show up on the...
My girlfriends computer did this a lot. What we did and I don't know if it would work for you was to use the HDMI cord (obviously your laptop has to have an HDMI). The S-Video cord was very tricky to keep it from going black we had to mess with the cord a lot!
May 16, 2009 | Panasonic TH-65XVS30U 65 in. HDTV Plasma...
Ps3 gets sound but no picture when using hdmi cord
you need an optical lead for the sound and hdmi for the picture
Dec 29, 2008 | Philips 23PF4321 23 in. HD-Ready LCD...
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
