Question about Cell Phones
Code c6 appears what does it mean - Cell Phones
What does code C6 mean
Hi Michele....C6 means the water level switch or
sensor is faulty. The only Customer Service phone
number I have is 0300479 0775 - probably in England
It is for AEG Lavamat..
Regards,
Dennis
Oct 12, 2014 | Washing Machines
Forget lock code for nokia c6 how can i handle it.please help me
1 - Switch ON your phone without SIM Card, 2 - As if making a phone call, on your dial pad compose: #PW+UNLOCKCODE+1# * For Bell Canada NOKIA C6-00 Please 1st use #PW+UNLOCKCODE+5# * For Fido NOKIA C6-00 Please 1st use #PW+UNLOCKCODE+7# The letter P appear after press 3 times quickly the button star ( * ) The letter W appear after press 4 times quickly the button star ( * ) The letter + appear after press 2 times quickly the button star ( * ) 3-The phone will show "SIM Restriction Off" * NOKIA C6-00 has been unlocked now visit my blog for more complete tutorial this unlock
http://pcgadgetdeni.blogspot.com/2013/02/how-to-unlock-nokia-c6-00.html
Feb 19, 2013 | Nokia C6 Smartphone
Bosch she45 dishwasher code c6
Fan -Related Problem code c6 Means the Fan Rotation to too low Durning Operation
Jul 09, 2012 | Bosch 24 in. SHU43 Built-in Dishwasher
I block my nokia c6 mobile
what do you mean by "block" ?
do you forget your security code?
Dec 27, 2011 | Nokia C6 Smartphone
HI MY NOKIA C6 LOCKED I FORGET LOCK CODE OF C6-- PLZ HELP ME IMEI NO. is___ 355398042831551
my nokia c6 is locked and i forgot my lock code ....imei no. is355398047589410
Apr 26, 2011 | Nokia C6 Smartphone
Our airconditioner has the code C6 on it. It has cut out and displayed that code. We were instructed to turn it off at the power board and turn it back on, which we did. It went back on again and tried to...
I previously asked you, if the C6 appear on the unit or on the hand held remote. I contacted a friend of mine who is a service technician for the LG Split System units and he advised that it's an error code that can only be solved by a LG trained service tech or LG itself. It may have been caused by a power surge, which may have caused some damage to the circuit board.
Sorry I couldn't be of more help.
Feb 03, 2011 | LG LA185HV Split System Air Conditioner
Replace cover on Bosch Dish washer> Now a C6 code is displayed in the window
I had the same problem after replacing the white panel on my Bosch SHE45M02UC with a stainless panel. I got the C6 error code. I called Bosch customer service twice and neither rep was helpful. One guy told me he didn't know what the C6 code meant. He suggested that I call a local appliance repair guy and he would know what the code meant. I replied, you mean to tell me you work for the manufacturer of the dishwasher and don't know what the error code stands for but a local repair guy that doesn't work for Bosch does?
After all this frustration, I took the panels off and tested the dishwasher with no buttons. It worked fine! Turns out, each identical button isn't identical. Each one is labeled A-G. After putting it back together, no more C6 code! On a side note, try reseting the dishwasher. With the dishwasher on and door closed, hold down the cancel/reset buttons for 5 seconds and release. The disher should drain and reset.
Mar 27, 2010 | Bosch 24 in. SHU43 Built-in Dishwasher
Kyocera Mita KM 1500
Still sounds like there is a problem with the fuser unit. The technician that replaced the parts should be able to troubleshoot the problem.
C6 = Fuser error. The unit is not heating up due to a bad Fuser lamp, fuse, or thermostat, or bad thermistor.
The circuit is open, and the machine won't work til the problem is repaired. Once open circuit is repaired/closed, the machine should reset on it's own after you power the machine down and back up.
Does the machine flash the C6 right away as soon as you turn it on OR, does the C6 show up after about 3-5 minutes?
If you get the C6 right away, then the circuit is open, and that needs to be fixed.
If you get a c6 after 3-5 minutes, then there is a good chance the lamp is bad.
Hope this helps.
Good luck
Feb 08, 2008 | Video Cameras
Cell Phones Logo
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
