Why is it putting pure salt in water - Washing Machines
  • 3,554 Answers
Http://www.sawater.com.au/NR/rdonlyres/290D4C25-FC0A-4F1E-B2A7-BE639CB6173A/0/FactSheet_Hardness.pdf
to alter the water hardness to allow soap detergent to work efficiently
Posted on Apr 26, 2015
Bibliography on does floating objects float better in salt or fresh water
Salt water has a higher density than pure water, so objects sink less in salt water.
Dec 06, 2013 | Computers & Internet
Water damage
If this was salt watercor contaminated water, then the only chance is to immediately remove the battery and rinse the Phone several times in clean pure water to remove the conductive salt / contaminated water. Then leave it to dry out in the sun or in a warm place for a few hours until all the residual moisture evaporates & drys out. With any luck the phone will turn on and work. If it was left with salt water or contaminated water for a long period before rinsing this may lead to permanent internal damage.
Nov 01, 2013 | Motorola Mobility MOTO W755 Cellular Phone
Salt water
Yes, because the water resistance is not effected by the salt content of the water.
Salt water is very slightly corrosive in it's natural state, but it can become very corrosive as it dries and the salts attract and hold on to moisture that can keep it's corrosive properties active long after you take it out of the salt water.
If you expose your camera to salt water rinse it off very well with fresh water once you're finished.
If you can see the seals in places like the battery compartment, you might also occasionally give those seals a coating of silicone grease.
If the worst happens and you notice moisture inside the camera, remove the batteries IMMEDIATELY and try to remove the moisture any way you can, even with cotton swabs if necessary.
Pure water is not conductive but most tap water and certainly salt water is, and if salt water bridges electrically charged parts of your camera when the batteries are in the camera, it will remove metal from one side and deposit it on the other side, (electrolsis), and that will permanently ruin you camera.
Oct 25, 2013 | FUJIFILM FinePix XP20 / XP22 Digital...
I have a jandy pda and have no idea what the message that its displaying means. This is our first pool and the owners manual has not helped! It says aqua pure 100% salt 4500 ppm, check aqua pure high salt...
it is showing your status aqua pure is set at 100% salt is at 4500 parts per million which is too high to operate should be between 2700 and 3400 to work properly you need to drain some water out and add fresh to dilute the salt general fault is because salt level is too high it is showing your filter pump and extra aux is on go to the equipment on on main screen it will give you a list of all your equipment any questions send me more info
Sep 20, 2013 | Jandy Aqualink Pda Ps6 Wireless Handheld...
How salt to use for start up for a 22 x 52 above ground pool
You need to know how much salt is currently in pool...
then what is total gallons of your pool?
Round pool? 22' round?
52" walls?
Use only Pure Pool Salt, NOT Softener salt!
2700 ppm to 3400 ppm is the range for ideal levels in your pool.
check out this link...
http://www.conelyco.com/images/saltchart.jpg
btw... Your pool, if what I asked above is correct, has 11,400 gallons
May 31, 2012 | Intex Automatic Salt Water System for ...
I Have a Easy Set Pool 15X36, And a Salt Water Generator How much Salt do I add for the first Time?
The Compupool CPSC/CPA Series is recommended to run at a salt concentration of 3500 ppm. If you are not installing a Compupool unit, check your manufacturer's instructions for their recommended level of concentration . Use a salt that is at least 99.8% pure NaCl. The preferred salt is an evaporated, granulated, food quality, NON-iodized salt. Avoid using salt with anti-caking agents like sodium ferrocyanide, also known as yellow YPS (prussiate of soda. These cause some discoloration of fittings and pool surface finishes. DO NOT use calcium chloride.
Using a salt water test strip, measure the current salt level of your pool. For the Compupool generators, ideal is 3500 ppm. If the level is low, determine the number of gallons in your pool and add salt according to the Salt Table. For example, if your pool has 15,000 gals of water and your current salt level is 2500, you need to add 125 lbs of salt.
Jun 08, 2011 | Sport & Outdoor - Others
I just got an Intex automatic Salt water system for my above ground pool. The pool is 18' X 48" I was wondering how much salt to get and what kind of salt to get? At the store.
hello
you are looking at about 135 pounds to start
Bags of salt are usually 40 lbs
Buy 4 but only put in 3 to start.
You need to get 99%pure pool salt sold at walmart and pool stores 6-10 dollors.
Also get a test kit for salt and get your pool to 3000ppm
only filter for the first 24 hours or so until pool registers the 3000ppm no more than 3800 and no less than 2700 lesser amounts than 3000 does not produce enough sanitizer when you generate. Now that you are close to the 3000 you can generate chlorine.
Use this web page to further assist you
http://www.intexcorp.com.hk/proifv/proifv_dl_client.jsp?lst_docsea=2009&source=intexstore&gid=2&lid=8738
Jun 25, 2010 | Intex Automatic Salt Water System for ...
Fell in salt water, dryed it for 3 days, is displaying "battery is required... powering off" when the battery is in. ALSO " Repair mode, please remove the battery to reboot your phone. Is it a write off?
the fact that it fell in salt water is proberly affecting it, try rincing it in pure clean water and then let it dry out, that might help. water shouldn't affect the phone, but the sault would.
Aug 02, 2009 | Cell Phones
We have a GE Model GXSF27E01 water softener. It
Try looking on the computer board for a battery back up. If it does have one, unplug that and then plug it back in and see if that will reset your control.
Jul 18, 2009 | House Brand Aqua-Pure AP102T Whole House...
My saltwater pool tastes very salty, but my intex saltwater pump keeps saying low salt. I have to clean the cell everyday or it will not operate properly because the cell gets covered with white buildup...
Your salt is way to high if you can taste it. You will need to dilute with fresh water until you get the salt back down and then clean the cell for continued use.
Jun 25, 2009 | Intex Automatic Salt Water System for ...
Washing Machines Logo
35 people viewed this question
Top Washing Machines Experts
