Question about Radio Communications
How do i fix my kyocero phone? The setting indicates out of headset but i am unable to receive a call because it goes straight to headset mode. My kid was pressing buttons,now it will not come off.
    Top Expert:
  • 10,875 Answers
Do you have a manual or cell provider??,then use them
Posted on Apr 26, 2015
I have a Nokia E75 and am unable to pair my Plantronics Explorer 210 with the phone. I tried to hold the big button down for quick pair mode. When I try to pair, it says unable to create bluetooth...
hello,
Step One:
Prepare Phone-
Turn on Bluetooth
For most phones, go to Settings/
Tools menu and select Bluetooth
or Connectivity and select "On."
(Or see the user guide for your
phone.)
Step Two:
Prepare Headset-
Pairing Mode
Step Three:
Pairing-
Add Headset to Phone
For most phones, go to Settings/Tools
> Bluetooth > Search or Add a Device,
then Select "220Plantronics."
For passkey enter 0000. Headset
will flash blue when paired
successfully. It is now powered on
and ready to use.
Begin with headset turned off. Turn
headset on (hold call control button
for 2 seconds until the light flashes
blue) and it will automatically go
into pairing mode, flashing red
and blue. hope it works
regards
shaun
Oct 10, 2010 | Plantronics Explorer 220 Bluetooth Headset...
Is Blue tooth headset Plantronics Explorer 210 compatible with k790i. I got this headset recently, but am unable to pair with my Sony Ericson k790i mobile. Please help?
Your headset must be in paring mode, in order to be paired with your phone. If, after turning it on, the indicator light doesn't alternately flash in red and blue (thus indicating it is in pairing mode), it has, most probably, been paired to another phone before. In this case, turn it off, wait for the indicator light to turn red, and, then, off. Then, turn your headset on again, and hold the call button until the indicator light is flashing alternately in red and blue. Either way, make your phone's bluetooth application search for new devices. After a while, your headset should appear on-screen. Make it connect. If a pairing code (or PIN, or passkey) is requested, enter '0000' (four zeros). If the pairing process has been successful, your headset will enter the stand-by mode.
Hope it works for you.
By the way, if your headset's user guide happens to be missing, feel free to download it from this location.
Regards, Carlos
Sep 10, 2010 | Plantronics Explorer 220 Bluetooth Headset...
Just received a brand new, in original packaging, ...
Your headset should enter the pairing mode just by opening its boom. If it has never been paired before, it will be in pairing mode right away. Otherwise, make sure that the bluetooth radio of all devices preivously paired with it, are turned off (or, at least, out of reach). As soon as its boom is opened, and it can't find any paired device active, it will enter the pairing mode. Once your headset is in pairing mode, make the bluetooth application of your phone search for new devices. After a while the H700 should appear on the phone screen. Select it and make the application connect. If a pairing code (or PIN, or passkey) is requested, enter '0000' (four zeros). The pairing process should be done only one. All subsequent connections between any two previously paired devices should be done automatically, provided that their bluetooth radios are on and with each other's reach.
Hope you are able to sort your problems out.
Regards, Carlos
May 19, 2010 | Motorola Mobility H700 Wireless Headset
How do I put it in discover mode?
How to Pair Cardo S-800
1.Turn on your phone and turn ON its Bluetooth function.
2.Make sure the headset is turned OFF, then press and hold the Power Button for approximately 8 seconds until the LED status indicator begins alternating blue and red, indicating that the headset is in Pairing Mode.
3.Set the phone to search for Bluetooth devices by following the instructions in the phone’s user guide. This is usually found in the phone’s Bluetooth menu and may be referred to as “discover” or “add” a device. (Settings > Connectivity > Bluetooth - turn ON - > Discover Devices)
4.After a few seconds, the phone will list the “Cardo S-800” as a discovered device. Select it from the list and press “oK” or “yes”.
5.When prompted, enter the passkey “0000” (4 zeros) and press “oK” to complete the pairing
6. When the pairing pairing is successful the headset’s LED status indicator will begin flashing.
You should now be able to make and receive calls using your headset. To initially connect the headset to your phone, you may need to tap the CTRL Button once on the headset. iMPortAnt: if pairing is not completed within 2 minutes while the Pairing Mode is activated, the headset will return to Standby mode, flashing blue once every three seconds and you must start the Pairing process again from Step 2 above.
If you found this information helpful, please give me a big thumbs-up when you rate my answer. Thanks.
Feb 07, 2010 | Cardo S-800 Bluetooth Headset Wireless...
How do i place a h555 motorola bluetooyh in pairing mode
Step A - ENSURE HEADSET IS IN PAIRING
MODE
Power on headset by sliding the Call button
towards the microphone to initiate easy
pairing. After a few moments, the indicator
light will be steadily lit in blue to indicate
headset is in pairing mode.
Step B - SET YOUR PHONE TO LOOK FOR
YOUR HEADSET
On your Motorola phone, press (Menu) >
Settings > Connection > Bluetooth Link >
Handsfree > Look for Devices.
The phone lists Bluetooth devices it finds.
Select Motorola H555.
Select OK or Yes to pair your headset with
your phone.
Enter the passkey: 0000
Select OK.
When your headset successfully pairs and
connects with your phone, the indicator light
changes from steadily lit to flashing blue.
Troubleshooting: Make sure that any devices previously pairedwith the headset are turned off. If the indicator
light is not steadily lit in blue, turn off both the
other device and headset, wait 10 seconds,
then turn headset back on. Wait for the indicator
light to become steadily lit in blue, indicating
the headset is now in pairing mode.
User Manual
Aug 22, 2009 | Motorola Mobility Bluetooth Hands Free...
Nokia 6070 stays in headset mode w/o headset pulled in
Try restoring factory settings which is in settings
Jul 09, 2009 | Nokia 6070 Cellular Phone
LG shine stuck on headset mode
reset the phone or cntuck to lg care
Apr 10, 2009 | LG Shine KE970 Cellular Phone
Plantronics bluetooth
you have to first put bluetooth headset in pairing mode by holding the phone hook button down until blue indicator on headset goes solid blue not flashing then set your phone to find bluetooth device by looking under your phones menu and look under bluetooth or connections make sure to turn on bluetooth function and choose find or add device phone will detect bluetooth device and will display the type of device on your phones display tell it to bond or connect once you select yes thats it the bluetooth headset will start to flash and its ready to go.
Jan 14, 2008 | Plantronics 510 Voyager Headset - PLN-510...
Bluetooth pairing
1.Explore blue tooth devices from your motorola phone.
2.it will sure find your blue tooth headset.
3. Make sure your blue tooth headset is on
4.in pairing function select your blue tooth headset
Dec 22, 2007 | Motorola Mobility Bluetooth Hands Free...
Radio Communications Logo
43 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
