Question about Brother XL-2600I
The manual knob is difficult to turn. When you push the foot pedal, the needle will move very slowly.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 68 Answers
Are you referring to the hamdwheel on the side of the machine?
Posted on May 08, 2015
5 Suggested Answers
rizla
  • 1463 Answers
SOURCE: Foot pedal is not working!
sorry no nothing about sewing manchines ,althought this could be a wire loose in the pedal to sewmanchine .
ah you can get a manual from here http://welcome.solutions.brother.com/bsc/public/eu/eu_ot/en/doc/manual_index.html?reg=eu&type2=-1&prod=hf_xl2600i2610euk&c=eu_ot&lang=en&flang=all
if this helps
regrads
riz.
Posted on Nov 20, 2007
  • 66 Answers
SOURCE: Push on pedal, hear the motor, no motion, arggg
it sounds like the belt might have come off the handwheel
Posted on Feb 03, 2009
daviescry979
SOURCE: my needle won't move up or down when I press the
The needle on my sewing machine won't move. The pedal makes a noise but nothing happens. The hand wheel doesn't turn either. Please help this is the first time I have tried to use it and disaster
Posted on Nov 25, 2011
  • 8 Answers
SOURCE: turning wheel disconnected from motor?
I would try replacing the needle, as it may have got bent. I have had this happen and I was sure needle wasnt effected. when I changed needle it was fixed. The very tip of my old needle had a slight curve and wasnt connecting to correct spot on throat plate. make sure you have needle in highest position and that stitch selection in turned back to straight stitch.
Posted on Nov 08, 2013
The handwheel will turn manually but it will not move using the foot pedal. The sound it makes when I press on the foot pedal *sounds* like I am filling the bobbin.
foot pedal not moving needle - Home Forums - GardenWeb
ths.gardenweb.com > Home Forums > Sewing
Nov 8, 2013 - We have a Brother Limited Edition Project Runway Sewing MachineRefurbished LS2250PRW. I was trying to sew on a button and was turning the hand wheel to do ... front near the needle where you can run the machine with foot pedal ...just what I would experience when my Bernina was running, or not, ...
Sewing Machine Repair ' ThriftyFun
www.thriftyfun.com/tf/Home.../Machines/Sewing_Machines/index.html
The thread is being picked up from underneath, but will not form a stitch at all. ... Butwhen I push my pedal down my needle won't move, the motor runs, but nothing happens. ... I have a Bernina machine which is sewing OK with the normal foot. ....The hand wheel, the wheel at the end that manually turns to make the needle ...
Help me diagnose and fix a problem with my sewing machine - Sewing ...
artisanssquare.com > ... > Sewing Machines
Jan 11, 2016 | Bernina Sewing Machines
My machine will not sew on it's own.
Wife says it will likely have to be repaired by a machine specialist in your area. Sometimes when that happens, the time gets off and needs to be repaired. It works when you turn it because your going much slower than the speed the foot pedal goes.
Dec 28, 2014 | Sewing Machines
Turning wheel disconnected from motor?
Nov 08, 2013 | Brother Limited Edition LS2250PRW Project...
The foot pedal wont move the needle
Ok, I am assuming that you have an old style machine where the hand hand wheel has the larger balance wheel on the outside and inner knob to release the drive to the needle and feed dogs. If that has been removed and not put back together properly it won't work.
There is a special locking washer inside those that have "fingers" pointing to the inside of the circle. They must be fit into the shaft correctly before the knob is returned into place and the little screw is tightened down.
This guy is a bit of a windbag but watch his video... you'll at least see the part I'm talking about. He shows the part at about 9:50 in the video.
Aug 03, 2012 | Sewing Machines
My needle won't move up or down when I press the foot pedal or turn the side knob manually. What can I do to fix this problem?
Sep 27, 2010 | Brother LS-2125 Mechanical Sewing Machine
I am getting error message E4 when foot pedal is plugged in. Unplug the foot pedal and the machine goes back to normal with the exception that you really can't sew without the foot pedal.
Your reverse reinforcement stitch button was pushed or needle position was pushed while bobbin winder was moved to the right. You can download a free manual brother-usa.com and you will see all of the troubleshooting and error messages there
Sep 10, 2010 | Brother CE4000 Computerized Sewing Machine
Needle no longer controlled by Balance wheel or foot pedal, instead, manually turning Clutch knob now operates needle. How do I fix this?
sometimes the balance wheel has a portion that either pushes in or out....or a portion that twists clockwise... to connect the motor to the needle drive assembly.
Mar 04, 2010 | Sewing Machines
Needle will not move
Tighten the inner knob on hand wheel to make the needle move up and down.
Jun 28, 2017 | Yamata FY920
Needle won't move
I had that problem too! I usually turn the tension knob and it works,
Aug 07, 2008 | White Sewing 1632 Mechanical Sewing...
Brother XL-2600I Logo
85 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
