Question about Garden
I need info on how I go about changing the cylinder . thank you.
I already have it open and can see the cylinder and the arm is broken.
    Top Expert:
  • 10,875 Answers
Posted on Apr 26, 2015
Compression cylinder low #2 and #3 cylinders.
there are only four possibilities left:
1: valves are not fully seating - adjust rocker arm / cam
2: piston rings are bad - replace rings
3: holes in pistons - replace
4: cylinders out of round - most complicated repair, bore / machine cylinders and replace piston rings with oversized rings.
of course you could just have 'gunk' on the valves preventing full closure........
Jul 23, 2014 | 2001 Hyundai Tiburon
No compression in rear cylinder
You are showing 2 different problems, no compression in any cylinder and no compression in rear cylinder.
Going with no compression in any cylinder, if the camshaft is not turning you should not have compression in most cylinders. If one cylinder has both valves closed you may have some cranking resistance. Your timing chain or gear is broken. Look if you can at any openings for a PVC pipe in the valve cover or oil fill cover on the valve cover.
There is a chance you can see some valve rocker arms and if they are moving when the engine is cranked. Otherwise you will need to remove a valve cover to observe the rockers.
May 13, 2014 | Ford Taurus X Cars & Trucks
Shakes and misses while accelerating , has a tick to the engine , i already replaced the spark plugs and wires, 1 new coil pack, air filter, fuel filter , new rear rocker arm and push rod. and oil change
Sounds like you still have a problem where the ticking is coming from. You may have to run a compression test on that cylinder you put the rocker arm on, are that side of the motor that is ticking. Could be the cam lobe wore down and need a camshaft.
Mar 09, 2011 | 1995 Chevrolet Lumina
My printer keeps printing blank papers and tells me to clean the platen glass. i've wiped it down and nothing's changed. Help!
I have a tip posted here on Fixya that addresses this very problem. Here is the content from that tip:
This tip works on all Canon Imageclass 6500 series machines including the MF6500 MF6530 MF6531 MF6540 MF6550 MF6560 MF6580 MF6590 and MF6595.
First of all if you are experiencing blank copies and or prints the best thing to do is try a different toner cartridge. In rare cases the black copies/prints CAN be caused by a defective cartridge. In MOST cases it is caused by a broken or detatched laser shutter lever or arm. When a toner cartridge is inserted and the door closed, a small plastic arm opens the laser shutter. If this arm is broken or has become disconnected then the shutter is not opened. This blocks the laser from writing the copy or print image onto the drum and this results in no print being applied to the paper. If the arm is broken you CAN open the laser shutter manually and block it open. What you need to do it open the cartridge access door, remove the cartridge and look for a 1/2 inch wide slot running from left to right in the metal frame that is in the back upper section where the cartridge goes. The plastic arm that operates the black plastic shutter is on the right side. If broken you can manually lift up the shutter and "block" it open using something like a folded up scrap of paper. I know it sounds strange but I have used this repair on several of my customers machines and they have all worked fine since. If you can not find or effect the repair yourself at least you will know where to point the service person when they come out to look at it.
Good Luck and Thank You for using Fixya.
WheatlandServices
Nov 18, 2010 | Canon imageCLASS MF6530 Monochrome Laser...
I need help changing out the master cylinder in my '94 toyota 4x4 pickup truck. It is a 5speed, i have already changed out the slave cylinder and installed the master cylinder but i still can not get the...
did you bleed the system?? you must bleed the system from the clutch slave. if this has been done, I need more info!! How does the clutch pedal feel, is the clutch slave engaging at all??
Sep 27, 2010 | 1994 Toyota Pickup
The glovebox falls open quickly instead of opening slowly.
Hello, and welocmed to FixYa. Please allow me to assist you.
More than likely, if your cabin air filter was recently changed, the mechanism to allow the box door to open slowly was not reconnected. We see this issue quite often.
Suggestion: Open the glovebox. Look at the side closest to the passenger door. You should see a small plastic cylindrical device with an arm fastened to the side of the glovebox dor with a phillips screw. If the arm is disconnected, just remove the screw and reconnect the arm.
A less common occurance would be the other side of the cylinder being disconnected, also. Either way, it sure sounds like your loweing device has somehow been disconnected.
Thanks for choosing FixYa for assistance.
Jun 09, 2010 | 2009 Toyota Venza
The clutch is stuck to the floor bord and i cant shift
you may have a faulty clutch master cylinder or faulty clutch slave cylinder- leaking clutch fluid. most of the time both are replaced at the same time which should be recomended by your mechanic, the bolts to the master cylinder are very hard to get to and require the right tool.
you should be able to move car forward by selecting 1st then cranking engine till it starts, gear changes while driving are hard but not impossible. i recommend a tow truck to a local repairer.
Dec 22, 2009 | 1995 Isuzu Rodeo
Working on a 2000 Audi A8. Need info on changing
If it's anything like the six cylinder engines from Audi, which I'm very familiar with, and from what I remember of the V8, you have a timing belt that drives the water pump, crank, and exhaust cams, and also includes a tensioner and an idler roller. The timing chains come into play in the cylinder heads. What Audi did was to only drive the exhaust cams off of the crank, using the timing belt, and inside each cylinder head there is a timing chain assembly that is used to drive the intake cams off the exhaust cams. On a periodic service (like the timing service) you only need to do the timing belt. The timing chains are only replaced if the tensioners fail - you'll know this by a diesel-like clatter from the cylinder heads. Failure of the chain drive assemblies is very rare, which is good because they're incredibly expensive (on the V6 engines they're upwards of $700 each). If you're doing this job because it's due based on mileage, don't touch the timing chains in the cylinder heads - only change the timing belt, tensioner roller, relay arm, hydraulic tensioner, idler pulley, water pump, and serpentine belt. You can leave the chains alone.
Dec 01, 2009 | 2000 Audi A8
95 eagle talon broken lower control arm how do i fix?already bought new control arm.
Jack the car up and remove the tire. Use a ball joint separator on the front lower control arm and remove the remaining 2 bolts, if working on the rear lower control arm, remove the 2 bolts holding the arm in place and install the new control arm.
An alignment is recommended when changing any part of the suspension, especially control arms, tie rod ends, etc.
Nov 19, 2009 | 1995 Eagle Talon
HI I HAVE A 2001 MAZDA TRIBUTE AND THE CODES PO301 AND PO303 CAME UP IN THE DIAGNOSTIC REPORT. THE CAR TURNS OFF WHEN I WARM IT UP IN THE MORNING IN THE COLD AND AFTER THAT ITS FINE I ALREADY CHANGED THE...
cylinder 1 misfire and low compression. Plugs and wires changed plus new fuel injectors. The engines still misses and no one can find the cause. When put on the computer it read misfire cylinder 1.
Dec 31, 2008 | 2004 Mazda Tribute
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
