Question about Boating
1979 cysler 440 ignition timing
1979 cyrsler 440 boat eng.
    Top Expert:
  • 10,875 Answers
  • Byron Reed
    Byron Reed Apr 26, 2015
    thank you your number one
I HAVE A 1978 EVENRUDE 35 HP NO FIRE TO THE PLUGS GREAT COMPRESSION???
evinrude 1978 -1979 have a capacity discharge ignition unit as the control for the spark system
it runs wires to an ignition coil
so I would be suspicious of that unit
check all connections for corrosion and bad connections
I typed in electrical schematics for 1978 evinrude out board engine and found a site --www.maxrules.com which in the list of schematics has 55hp 1977-1978
press on that and you get a schematics of the wiring diagram evinrude 1978-1979 55hp
now I am aware that you state that yours is 35 hp but if it has 2 cylinders then it is a fair bet that the wiring diagram will be the same
any way there are plenty of other sites that may be of benefit
Nov 26, 2015 | Boating
Install snowmobile track on a 1979 kawasaki 440
In order to install a track on the 440, you have to FIRST "Ensure you have the RIGHT TRACK". 15x121 2.5 pitch Normally they were 3/4 inch depth.
1. Remove Rear Axle
2. Remove Bogey Wheels
3. Take Chain Off Axle
4. Remove Front Axle with Old Track
5. Install New Track (Pay attention to direction of track if you get a Camoplastic)
6. Reinstall Bogey Wheels
7. Install Rear Axle
8. Adjust Track Tension.
Dec 15, 2013 | kawasaki Motorcycles
Trouble shoot
Hi, Brian you need "FIVE" things in order for a cylinder to run properly:
1. FUEL: in order to validate your not getting fuel spray some starting fluid into the air cleaner and hit the starter button, if it fires up and runs for a few seconds then you know you have a fuel delivery issue.
2. SPARK: remove the spark plug and with it connected to the spark plug cable ground the threads to something metal you should see a bluish white spark if not you have a faulty spark plug, spark plug cable, ignition coil, condenser, CKP, ECM, sensor or the wiring in between.
3. COMPRESSION: you must have at least 80-100 PSI for most bikes if not perform a leak down test you may have a burnt or bent valve or hole in the piston or broken rings.
4. CAM TIMING: confirm your timing marks are aligned to see if the cam chain or adjuster are worn out and the chain has skipped a couple teeth.
5. IGNITION TIMING: on older bikes check to see if your points have not closed up, timing plate has not become loose and confirm with a timing light for proper retard and advance functions, on newer bikes where timing is controlled by an ECM and is nonadjustable check you CKP, TPS, MAP, O2, sensor or it's counterpart for integrity.
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
Runs on only one cylinder
1980 Yamaha XS400 Special Only firing on one cylinder
Yamaha XS 400 SH Service Manual ENG XS360 2D XS400 2E 2F SG Supplement ENG...
OEM parts for Yamaha
http://mybikemanuals.com/yamaha/yamaha-xs-owners-manuals
Apr 08, 2012 | 1979 Yamaha XS 400
1979 buick im not sure if it was a park ave or a 5th ave but i need a diagram on how the power steerign and altantor belt goes on i forgot which one goes in forn of the other i replaced the water pump but...
A park Ave. is a Buick and a 5th Ave. is a Chysler the Buick can have 3 different engines so I need to know which engine. The cysler 5th Ave. is a 318 400 or 440 the buick is a 455 350 olds or a 350 chev or a 350 buick. 3.8 buick. The 8th number in the VIN will tell your parts store guy and he shoul be able to prvide the belts and the picture of how they go on. Sometimes the picture is on the fan shrould and sometimes it's on the package the belt comes in ( some gates belts that only fit your car.
Jun 27, 2010 | Cars & Trucks
Sonar not working properly, intermittent
Generally, that indicates air bubbles in the water under the transducer. If you have a transom-mount transducer, make sure the bottom surface is level or angled slightly down. If you have a thru-hull, make sure your bottom is fairly clean in that area.
Oct 20, 2008 | Garmin GPSMAP 440 Chartplotter GPS with...
Boating Logo
156 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
