I hooked up my DVD player to my hct tv. I am getting video but I am not getting any audio. I hooked them up the way it's color coded. Yellow for video red and white for audio still no sound help!
  • Televison & ... Master
  • 3,554 Answers
Make sure you plugged them into AV as component in looks similar but is a different . Did you change the input source on tv to av 1 or av2 . make sure you did not plug into AV out it should be on AV in on the TV.
Posted on Apr 26, 2015
SOURCE: No color on dvd player
A cable could cause this problem. I would try using a standard RCA patch cable and go from the composite video output of the DVD player to a composite video input of the TV. See if that produces color. If not, the DVD may be at fault. On the other hand, if you get normal color, the S-video cable could be bad.
Hope this helps.
Posted on Dec 21, 2008
  • 899 Answers
SOURCE: No color and no audio
yes , this is why , on your dvd there is a "yellow for video" output on it ,and then there is a "red output jack for right audio"
and then there is a "white output jack for left audio" does your tv have these inputs?
the blue , green and red "RCA JACKS" are called " composite video" which seperates the colors of given video
the red and white RCA jacks are for right and left audio and are required when using composite or the yellow video jack
there is also a "s-video" connection that is one cable but seperates the colors for better picture quality ( dvd player only)( vcr and tuner do not work with this)
then there is a optical or coax digital connection for a reciever that decodes the connections audio digital signals for dolby digital surround sound
Posted on Jan 08, 2009
  • 15 Answers
SOURCE: DVD Player connection to the tv... Theres three
Red is usually the left channel audio, white the right channel audio, and yellow the video. Look for something to the effect of "audio out" and "video out" on your DVD player.
Posted on Jul 08, 2009
  • 192 Answers
SOURCE: Trying to hook up the dvd player to the tv and I
Your TV probably has several different ways of connecting video. One is component, which uses three cables. They are red, green, and blue (RGB). The video output on your DVD player will match this color scheme.
Another scheme for video is composite (because it combines the red, green, and blue into one cable). Composite video is usually a yellow "socket". It is simpler to connect, but the video quality is noticeably poorer than component (RGB).
Another scheme is S-Video. This is one cable (round and black), but you will see four pins inside the connector (and four holes in the "socket"). This accounts for the three cables in the component scheme with the convenience of having only one cable. The picture quality is almost as good as component as well.
In your case, there may be confusion between composite and component. If you have red, green, and blue sockets on both the DVD and TV, then make sure you use them and connect them color for color.
Now for the sound, this is simpler. Red is the right channel, and white is the left. Make sure you connect red to red and white to white. Then, viola, everything will be right.
I hope this helps.
Posted on Aug 24, 2009
  • 630 Answers
SOURCE: toshiba sd-k970 dvd player sound but no video.
I presume that you've selected the correct inputs on the TV? Go for HDMI if you have it on your TV. If not use the yellow (composite) and ensure you have nothing in the S-Video (Toshs don't like using composite and S-video at the same time).
Posted on Aug 30, 2009
How to hook up wires from dvd to tv, what is the order
Your tv and DVDs have color coded wires white,yellow and red..just mscth them..most have words like video or audio out and in...would be out to TV on the DVD in on the TV pretty much self explaining..good luck
Oct 05, 2014 | Sungale DVD-2026 DVD Player
Trying to hook up my daughters dvd and tv. I've got one set of cables with yellow red and white connections,where do they go?
Red is for Left Audio Output, to TV Left Audio Input
White is for Right Audio Output, to TV Right Audio Input
Yellow is for Video Output to TV Video Input
You should see the same color coded RCA jacks on the rear of your TV unit. Just match the inputs to the correct device ie: Video 1, Video 2, etc
Aug 09, 2011 | Televison & Video
I have an old DVD player from 2002 & I'm trying to hook it up to my TV (old TV too). Do you have a graphic of the hook up? The TV has a spot to hook up my cable for my basic cable channels. The DVD...
You connect up a DVD to a TV via the Audio Visual leads, they go into the Red White, the Audio, & Yellow, the composite Video. In & Out. They wire color to color. Then you select AV on the TV. & press Play on DVD.
Feb 07, 2010 | Toshiba SD-2800 DVD Player
Help hooking a dvd player to a tv
  • have you try to hook the rca jacks to the tv they should be color coded red, white, yellow, yellow is the video, red and white is audio. same as hooking to tv box.
Mar 24, 2009 | Panasonic DMR-E30 DVD Recorder
I am trying to connect an akai dvd player to directv, please help
ruettab,
good day. to connect your any DVD player to any TV screen always remember this color code
from DVD back part:
yellow = video out
red/blue/green( in a row) = component video out ( this can only be used for screen with component video inputs)
Black = digital audio ( rarely use unless)
Red and white (in a row) = Audio output (left and right audio)
where to connect from TV screen.
Locate where A/V INPUTS (audio/video socket) from your TV screen, you can see it either at the BACK/SIDE or somtimes in FRONT of TV screen , having marked as "AV1"AV2"AV3' .
Once you found TV input, you must first have RCA cable (color code cable to connect player to screen) then connect the RCA cable at the back of your DVD player, simply follow color code
RCA yellow marked cable = DVD yellow socket
RCA RED and WHITE marked cable = DVD RED and white socket (second row for your player)
then connect the other end of the RCA cable to TV screen, first select which input where you gonna place the DVD player ( either AV1, Av2 or Av3 if do have multiple inputs)
once decided which INPUT to connect the player.
ex. if you select AV1 as input there would be 3socket on its row (yellow/red/white)
now connect the other end of RCA cable to the screen by following the same color code:
RCA yellow cable = TV screen A/V1 input yellow socket
RCA RED and White = TV screen A/V1 input red and white socket.
cheers,
mark
Jan 31, 2009 | Akai DVD-3850S DVD Player
Have a Sanyo DP42828(42"). My Satellite is working after the card resetting itself. But which 3 holes do I hook the (RED, YELLOW, and WHITE) for the dvd player?
dems,
Are you reffering to your DVD player to be conected to with your TV screen?
For DVD player connection the 3 colored RCA jack socket are:
YELLOW = video out
RED and WHITE = Audio out (left and right channels)
to hook up to your screen, at the back of the screen or side of it you'll see RCA socket indicating "AV1" "AV2" AV3" this are all Audio/video inputs where you can hook up all you A/V device or game consoles. These inputs also have the same 3 colored socket (yello = video red/white = audio)
connect your DVD player to any of this input following the same color code.After connecting the cable, select the input where you hook up your dvd player. Do this by pressing "A/V" buttons in remote commander of your TV. continously press this button until it reaches the exact location where you plug your player ex. AV1, AV2,AV3
note: in some cases the remote commander doesn't indicate this A/V button but a picture of a box having a arrow pointing inside the box.
cheers,
mark
Jan 05, 2009 | Sanyo DS31590 31" TV
I have a samsung 32 inch LCD HDTV and trying to hook up to Pioneer DVD player. There are three colors of wires to connect the DVD to the TV. I get the sound(audio) but not the video. It just shows black...
Just make sure you hook up the wires to the correct plugs. They should be colr coded - red and white for audio and yellow for video. The sockets on the TV will have the same color code. If not, its just a matter of trying various combinations. If nothing works, then try using a different cable.
Sep 26, 2008 | Televison & Video
We just received a big screen tv as a gift and we want to hook up our dvd player and our vcr and have lost the manuals. HELP
You can hook your dvd player in tv by using component video input terminal having green-red-blue colors for video signal and red-white for audio signal. so total 5 wires been used here. color order should be exact at both units, tv and dvd player i.e green to green, blue to blue and so on.
vcr can be hooked at composite video input in tv having 3 pins, yellow for video, red-white for audio in both units, vcr and tv. pins color should be exact on both units.
need further help, post here please.
Sep 24, 2008 | Televison & Video
Hooking up dvd player
Your cables are coded red(right audio), white(left audio) and yellow(video). The cable inputs on the dvd player and tv are likewise coded. Just connect color to like color. In setup, do not
change NTSC! If you should go to PAL you'll never get out of setup and all you'll have is screen roll, as though the vertical hold gave out.
Sep 18, 2007 | GPX D1816 DVD Player
Televison & Video Logo
51 people viewed this question
Top Televison & Video Experts
Electro Med Services...
