Question about Garden
Do u have a diagram showing drive pulley assembly
It is a swisher big mow 32. Model # AZV-12V- 8M. Serial # L100-339018.
    New Friend:
  • 26 Answers
Engine runs on my swisher 2560 but will not move, stopped while mowing
Drive belt may have broken or idler pulley could have malfunctioned or drive belt could have just came off alignment.
Sep 10, 2017 | Swisher Garden
Swisher xzt 60.. while mowing grass pushing the arms forward the blades slow way down.. how can i fix this issue? I just put new deck and engine belts on..
Swisher is proprietary in the service arena for information. The most common cause of the issue that you are describing is belt slippage. This could be due to oversize belt length. improper tension, loose pulleys etc. Also when you look at an area that you have mowed after one day, if the tips of the grass are yellow, the blade is not sharp enough.
Jun 21, 2014 | Garden
Do you have the belt diagram for a swisher 44" 10.5 hp pull behind? Just put new belt on, engaged blades and it started smoking then broke. I'm assuming it was too tight. Is there a tension control?
There have been issues with the bearing and the idler pulley on these machines. Here is a parts break down: http://www.searspartsdirect.com/partsdirect/part-model/Swisher-Parts/Tractor-accessory-Parts/Model-T11544/3291/1500230/P0708055/00004
Jun 05, 2014 | Garden
Need to know the pitch 8m for pto clutch
if your talking about the bolt that goes through the center of the pulley your model number shows it as a 3/8-24x1.75 long. everything I see on the pto is standard not metric. this link will show you the pto breakdown for your model
Parts and Diagrams for Cub Cadet 144 653 100
May 16, 2014 | Cub Cadet Garden
How do I adjust the travel speed on my swisher big mow model ZT2766
Belt slipping? Altering original equipment may cost you a IHT transmission. 500 bucks each
Apr 16, 2014 | Garden
Swisher 44" mower starts and runs but engine bogs
The engine in this machine seems to be powerful. If you can remove the belt from the pulley that drives the blade. Try turning the pulley buy hand. If it turns tight or not at all this is your problem. The unit that is the pulley to blade assembly is seized or ready to seize. Sometimes they are designed to be taken apart and repaired, and sometimes they are not. Did you check for a grease fitting within the pulley to blade unit?
I would like to hear how this works out for you. Best of luck.
Jun 13, 2011 | Swisher Atv Trail Mowers Choose Color
Swisher 60 deck belt breaks after mowing about 15 minutes.
Even though the routing is correct, have you checked that every spindle and idler pulley turns freely? These bearings can freeze up or bind because debris builds up in them. Also, if the bushings on the idler pulleys can wear, causing them to misalign. Keep checking. Also - is the belt snapping clean, or do you see a burnt, worn spot?
May 27, 2010 | Swisher 60" 26 Hp Zero Turn Radius Riding...
Looking for diagram to show the correct positioning of mowing blades for 42" mtd mowing deck
Send me an email and I can send you back the complete diagram and parts list for the 42" G Deck.
It is too big to show here and the online link has now been removed by MTD as these are now only available to authorised dealers.
Nov 08, 2009 | Mtd LAWN MOWER PART # 683-04163B FRAME...
I need a belt diagram for swisher t60 trail mower
Here's the manual for it - section 12 belt replacement, page 16. It goes over all pulleys except the idler - it goes under the idler pulley.
Aug 30, 2009 | Swisher 60" 13 Hp Trailmower #T1360h
Garden Logo
127 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
