Question about Chevrolet 1997 Chevrolet Venture
A speedometer The speedometer does not work
  • Chevrolet Master
  • 954 Answers
In older cars when a speedometer broke, the cable from the front wheel to the transmission usually had to be replaced. On cars 1990 and newer, they are electronic. Speedometer problems are as wide ranging as a simple loose wire to a massive electrical problem that requires the help of a professional. One of the common causes on cars 1990 and newer is a bad speed sensor. To replace it, according to Buzzle.com: "You will find the speed sensor behind the engine, above the trans-axle.
Remove the connecting hose, air cleaner and electrical connector from above the sensor.
With help of a 10 mm socket, remove bolts keeping the sensor in place. Then, twist the sensor to take it out.
Attach a new O-ring to the sensor and clean the sensor flange and exterior sensor housing before re-installation.
Fix the new sensor in place and tighten bolts around it. Reattach the hose, air cleaner and electrical connector on to the sensor."
Also, Scotty Kilmer has an informative video on YouTube.com : https://www.youtube.com/watch?v=KE64o3NAdkY I hope this helps.!
Posted on Apr 26, 2015
Which fuse do i replace for the speedometer?
For speedometer related issues, the help links are provided below. Click the link below to go through its details: ----
How to trouble shoot speedometer?
http://schematicsdiagram.blogspot.com/2011/06/speedometer-not-working.html
why speedometer not working? http://technoanswers.blogspot.com/2012/01/1996-fiat-bravo-speedometer-not-working.html
Speedometer works but odometer not working? http://technoanswers.blogspot.in/2012/01/speedometer-works-but-odometer-not.html ----------- Speedometer runs backward?
http://technoanswers.blogspot.com/2012/01/speedometer-runs-backward.html
Warning lights on and speedometer died?
http://howtobyme.blogspot.com/2011/08/warning-lights-on-and-speedometer-died.html
ABS & Brake lights warning indicator steady on dash and speedometer not working?
http://howtobyme.blogspot.com/2011/11/abs-brake-lights-warning-indicator.html
Vehicles Cluster panel Not reading Miles?
http://schematicsdiagram.blogspot.com/2011/12/vehicles-cluster-panel-not-reading.html
Odometer works properly but speedometer works intermittently? http://technoanswers.blogspot.com/2012/01/odometer-works-properly-but-speedometer.html
How odometer works in cars?
http://technoanswers.blogspot.com/2011/11/how-odometer-works-in-cars.html
Speedometer not working on Ford?
http://repairhelpcenter.blogspot.in/2012/02/speedometer-not-working-on-1993-ford.html
This will help.
Thanks
Feb 04, 2012 | 1999 Ford Windstar
Where is the speedometer sending unit located
This will help.
Thanks
Feb 03, 2012 | 1993 Ford F250
This will help.
Thanks
Feb 02, 2012 | 1998 Chevrolet S-10 Pickup
What does it mean when the speedometer goes out?
This will help.
Thanks
Feb 02, 2012 | 2000 Dodge Intrepid
Cluster
For speedometer problem click the link below :---
-----------speedometer not working? http://technoanswers.blogspot.com/2012/01/1996-fiat-bravo-speedometer-not-working.html
---------Speedometer runs backward?
Warning lights on and speedometer died? http://howtobyme.blogspot.com/2011/08/warning-lights-on-and-speedometer-died.html
---------ABS & Brake lights warning indicator steady on dash and speedometer not working? http://howtobyme.blogspot.com/2011/11/abs-brake-lights-warning-indicator.html
--------Odometer works properly but speedometer works intermittently? http://technoanswers.blogspot.com/2012/01/odometer-works-properly-but-speedometer.html
----------speedometer is jumping? http://schematicsdiagram.blogspot.com/2012/01/isuzu-rodeo-speedometer-is-jumping.html
-----------This will help.Thanks.
Feb 01, 2012 | 2005 Dodge Magnum
2009 digital speedometer problem yamaha
This will help.
Thanks
Feb 01, 2012 | 2011 Yamaha XJ6 Diversion ABS
Speedometer and Odometer quick working. How do I
Follow the speedometer cable from the firewall, down to the transmission. It should bolt in the transmission, remove the cable from the transmission, and turn the gear to check to see if speedometer is working, if not, it's most like the speedometer head unit.
Mar 15, 2010 | 1990 Geo Prizm
My speedometer quit but the odometer still works (1998 F150) can you solve this
Usually it's the opposite. The speedometer works and the odomater and trip meter go inop. Most likely the speedometer assembly is bad. If the odometer is working you have a signal from the gray and black wire .
Dec 16, 2009 | 1998 Ford F150 Regular Cab
Honda civic 2007 The digital speedometer is working on top but the meter that shows the total mileage is not working. Would you be able to help?
if your speedometer is working,and the odometer is not,you will need to have the odometer replaced for it works off the speedometer
Nov 18, 2009 | 2007 Honda Civic GX NGV Sedan
Speedometer going crazy not reading correctly
speedometer cable? speed sensor or speedometer meter it's self! engine light on scan obd 2 to retreve codes don't gue$$
Jan 04, 2009 | 1995 Honda Accord
Chevrolet 1997 Chevrolet Venture Logo
52 people viewed this question
Top Chevrolet Electrical Supplies Experts
Lawrence Oravetz
jdthefixer
richie46
Are you a Chevrolet Electrical Supply Expert? Answer questions, earn points and help others
