Question about NordicTrack Exercise & Fitness
I think my resistance on my nordictrack cx1055 is not wotking
2 Suggested Answers
ercupa190
  • 12223 Answers
SOURCE: nordictrack cx1055 vibration problems
see the next steps: Lube and use the logically. God bless you
Inspect the leveling feet on the rear stabilizer of the elliptical. Note if both sides are not flush to the floor. Unplug the machine if they are not flush to the floor.
  • Turn the leveling feet on one side or both with your hand until they are fully in contact with the floor so the machine will not make noise and tilt sideways during workouts
  • Plug in the machine. Use the machine as normal and listen for any noises. Clean and calibrate the ramp again if there is noise but the machine doesn't rock, and adjust the leveling feet again if the elliptical wavers.
  • Posted on Aug 06, 2012
    Just bought a nordictrack audio strider 900 every thing works OK a part from the resistance . Go to alter resistance and nothing changes Any ideas as to why Kind regards nick
    the resistance is done by a magnet and a motor that moves it closer or farther away from the flywheel. possible the motor is bad or not adjusted properly
    Jan 30, 2016 | NordicTrack Exercise & Fitness
    My cx1055 elliptical resistance is not working how it should. Once I get to resistance lever 4 or higher it starts out with the resistance but then it slips as you step into it. Any suggestions?
    Nordic Track Nordictrack Cx1055 Elliptical Incline Motor For ...
    www.fixya.com/search/p3944353-nordic...cx1055_elliptic/resistance
    Nordic Track Nordictrack Cx1055 Elliptical Incline Motor For Model Number 285090, ...the bolts that secure the magnet4=if there are slips, the resistance will . ... my schwinn 460 elliptical resistance cannot be changed When I increase the ... Every time I increase the resistance it will go to that level of resistance but within a ...
    Need someone to install a new resistance motor on a Nordic ...
    www.shopyourway.com > Manage My Life > Questions
    Aug 10, 2013 - I bought a CX 1055 Nordick Track elliptical at a garage sale. I noticed that the resistance doesn't really change between levels. ... 100 dollars, but how much would it cost to have someone come out and do the replacement for me? ... I wonder if maybe something shifted when I brought it to my apartment?Missing: slips
    [PDF]View Manual in PDF Format - NordicTrack
    https://service.nordictrack.com/.../pdfDownload.do?...2...
    NordicTrack4. Place the elliptical exerciser on a level sur- face, with a mat beneath it to protect the... The CX 1055 elliptical exerciser is an ... 1055 elliptical exerciser features adjustableresistance ..... press the Odometer button again; the words "My.
    Jan 05, 2016 | Exercise & Fitness
    Nordictrack cx 1055 There is No Resistance. It used to take several seconds to get resistance. But now the resistance is Zero. The Ramp raises and lowers just fine. Is there a video somewhere showi
    Sounds like a small control board may have died, more specifically, a failed capacitor or such. Resistance is often achieved by pulsing an "eddy current" brake driven by a transistor, or draining a generator charge electrically, which are attached to a central crank, which stiffens the torque required to rotate and the user sees this as a increase in resistance :-) you can always contact jatinah electronics for further help.
    Feb 02, 2015 | Nordic Track Nordictrack Cx1055 Elliptical...
    Why my commercial vr resistance levels not working at all? Do i have to replace the resistance motor?
    https://service.nordictrack.com/CustomerService/manuals.do?dr=NT
    https://service.nordictrack.com/CustomerService/contactUs.do
    Jun 16, 2014 | Nordic Track NordicTrack Commercial VR...
    Nordictrack elliptical CX1055 stopped beeping. The unit used to make a feedback sound when a button was pressed. This was in the form of a beep. The unit has not been jarred or mistreated, it just stopped...
    follow this troubleshooting steps and fix it.
    God bless you
    Check power problems if the console on the elliptical machine does not light up. Make sure that the plug for the machine is secure in the outlet. If it is plugged in, ensure that the outlet is receiving power. Check the breaker to make sure it has not tripped off.
    Be sure that you are using the correct adapter that came with the elliptical machine. Because different adapters are able to handle differing amounts of energy, the wrong adapter will not transfer electricity like it should. If the adapter is pinched or damaged, this could also alter its effectiveness.
  • 2 Make sure the correct adapter is being used if the resistance settings seem to be too hard or too easy. If the correct adapter is being used, reset the machine. To reset the machine, either switch the "On/Off" button or unplug the machine from the wall. Doing this will allow the device to reset itself to the default resistance. Turn on or plug the device back into the wall and retry all of the levels of resistance.
  • Sponsored Links
  • 3
    Do not be concerned if you see small particles left on the guide rails. Over time, the roller wheels gradually wear down. When this occurs, they leave residue on the rails. Because this is considered to be normal wear, all you need to do to fix the problem is wipe the rails off with a damp cloth.
  • 4
    Minimize the risk of receiving erratic readouts on the monitors by avoiding outside interference. For example, gripping the heart rate handlebars too tightly can affect the monitor. Similarly, the heart rate grips can be rendered less effective when there is too much vibration. Consider not holding these monitors throughout the workout to minimize vibration. The readouts also can be affected by jewelry. To minimize errors, take off rings and other jewelry before working out on an elliptical machine.
  • Read more: http://www.ehow.com/how_6149016_troubleshoot-elliptical-machine.html#ixzz2gTKOfuoB
    Oct 01, 2013 | Nordic Track Nordictrack Cx1055 Elliptical...
    Nordictrack cx1055 vibration problems
  • Aug 05, 2012 | Exercise & Fitness
    Why does my blower motor wotk on all speeds except high on a 92 s10
    you need a blower resister most likely. or the speed control switch. 99 out of a 100 times the resister shot craps
    Jul 12, 2012 | Chevrolet S 10 Cars & Trucks
    We have a Nordictrack Futura 2200 and when we set the weight resistance it jumps back to 10lbs. no matter what we set it for it jumps back to 10lbs
    When the resistance setting changes, the motor will be heard. To prevent damage to the motor, do not pull any of the cables while the resistance setting is changing. If the motor has difficulty adjusting the resistance level and no cable is being pulled, there may be too much tension on the Upper Cable (110). Adjust the tension as described below. To decrease the tension on the Upper Cable (110), turn the two 3/8” x 38mm Tension Screws (106) twice, counterclockwise. Select the desired resistance setting. Repeat this step if necessary.
    Apr 24, 2010 | Nordic Track Nordictrack Futura 2200...
    Exercise & Fitness Logo
    77 people viewed this question
    Top NordicTrack Exercise & Fitness Experts
    Howard
    Howard
    Electro Med Services...
    Ross Metcalfe
    Ross Metcalfe
    Are you a NordicTrack Exercise and Fitnes Expert? Answer questions, earn points and help others
