Question about Schumacher Electrical Supplies
Schumacher model# 2352 wiring diagram 200 amp 12 volt battery charger?
3 Suggested Answers
  • 5245 Answers
SOURCE: need a 3 position switch for a Schumacher model se-2352 battery charger
Search for 3-position rocker switch
Use google and google image search.
Quick search shows 16 amp switches.
Probably the switches inside charger control contactor or relay.
Or connect directly to a circuit board.
The board might be bad, or relay points burned.
Posted on Oct 27, 2012
  • 1181 Answers
SOURCE: What is the wiring diagram for the switch on a schumacher model se-150-15 battery charger?
Posted on Mar 29, 2015
Do you have a wiring diagram for a Schumacher se-1010-2 battery charger?
What did you find on Google and forum sites are also a great sourse of information.
Sep 16, 2014 | Schumacher SE-1010-2 12-Volt 10-Amp Dual...
Manaul for schumacher battery charger model se4020
Your battery charger supplier or manufacturer should be able to supply you with an operating manual.
Aug 14, 2014 | 10/40/200 Amp 6/12-Volt Manual Battery...
Wiring diagram se-4020 battery charger
try this web site
http://www.manualslib.com/manual/523935/Schumacher-Se-2254.html Schumacher SE 2254 Owner Manual
Feb 08, 2014 | 10/40/200 Amp 6/12-Volt Manual Battery...
Need a 3 position switch for a Schumacher model se-2352 battery charger
Oct 26, 2012 | Schumacher Electrical Supplies
How long does it take to charge CCA 7000 battery ( car ) when I use SE-2158 battery charager wih 2 AMP/12 VOLT
2amp 12 volt is a slow charge it will take about 6 or more hours. when the needle on charger is down in green to full charge its fin. hope this helps
Sep 13, 2011 | SE3010 2003010 Amp Manual Starter and...
Both Battery clips have come off of Schumacher SE-5212A Charger. Need wiring diagram to make sure I replace them correctly to the battery cable wires.
use a voltmeter. turn on unit to a low setting, place volt meter leads on broken wires one on each. if the voltage goes positive on meter. the positive clamp goes on the wire that the positive(red) voltmeter lead is on and the same for the negative.
Good luck
Jun 28, 2011 | SE3010 2003010 Amp Manual Starter and...
Looking for wirring diagram for schmacher SE-1275A battery charger. Wires got pulled out of component need to know where white wire & black wire goes.
yay I emailed schumacher asking about this and they got bak to me within 12 hours or so with EXACTLY what I needed
I looked a long, long time without finding anything like this online, and many different people asking the same questions
so please save this picture for your records, and if you have a minute, go post it on an unanswered schumacher battery charger wiring diagram question
Jan 18, 2011 | Schumacher DSR ProSeries Battery Charger -...
Lost the wall charger of my Schumacher 400w power inverter (model PP-2200), where can I get another one?
Ah, I see, it seems what you have is a power pack. If so it would contain a gelcell battery, probably 12 volts. If this is true, then you may charge it with any 14-16 volt wall charger. You have to make sure you observe correct voltage and correct polarity when connecting up. Also you may have to obtain and change the plug on the charger wire.
I'm assuming the battery DC output is inverted to AC and you use it to power small AC appliances.
Mar 21, 2010 | Schumacher 400w Power Inverter
Electrical Supplies Logo
292 people viewed this question
Top Schumacher Electrical Supplies Experts
D. E. Hev
Are you a Schumacher Electrical Supply Expert? Answer questions, earn points and help others
