WP DUET E01/F08. Away Left water off. Started, coded, pump won't shutoff. Dr locked, can it be reset or is it repairman time?
    Genius:
  • Washing Mach... Master
  • 1,585 Answers
To replace door lock its a fiddley job can b done from top with lid removed
Posted on Apr 26, 2015
  • 1294 Answers
SOURCE: Whirlpool Duet Error code F 32
Plug off the wall. Open up behind, you will see a thin tube coming down from the control panel (pressure switch to be precise) to the waste area below. Disconnect this carefully from the top, blow into it, air should pass thru, it shd not be clogged; refit carefully. Before refitting, fit a similar tube to the pressure switch & blow - you should hear a click; if not there shd be a problem with your pressure switch. Anyway refit your old tube & try the machine.
Dont forget to refit the main exit hose at the position you found it. All you guys are going to rate me....................
Posted on Jun 16, 2008
woobie dog
  • 1273 Answers
SOURCE: code dl-f
Hello.
You are correct in that the fault code stands for door lock error. Here's the book answer:
Door Lock Error occurs if the door cannot be locked. It will try to lock it 6 times before displaying the error.
Potential Causes
• Door Lock Mechanism broken or removed from the Door
• Check Door Lock/Switch Assembly
• Check the wire harness connections to the Door Lock/Switch Assembly and Central Control Unit (CCU)
• Door Lock/Switch Assembly Failure
Replace failed component.
Try pressing pause/cancel several times to reset it.
Best regards, --W/D--
Posted on Aug 20, 2009
jsrock516
  • 5911 Answers
SOURCE: whirlpool duet washer getting a f21 code.sems water not empting
"F21" is a Long Drain error code. This is an indication that you have an obstruction somewhere in the drainage system. In most cases, this means you probably have a clog in the drain pump. The following link explains:
http://www.fixya.com/support/r1484065-f21_error_code_whirlpool_duet_kenmore
You may have something getting caught in the pump impeller and slowing it down. Included is a follow-on link that explains how to check the drain pump to clean. You may also have to remove the inlet hose that runs from the bottom of the wash tub to the inlet side of the drain pump. Debris can commonly clog in this area as well causing the drain cycle to fail.
NOTE: If these preliminary measures do not correct your problem, you may have to replace the drain pump. It does not take much to damage the pump impeller or motor. Since the error code is generated if the drain cycle exceeds 8 minutes, if the pump is damaged and can't pump at the required volume, the error code will continue to appear until the pump is replaced.
NOTE: The "SUDS" error can commonly occur with the F21 error code as this is can be generated when air is sensed in the drainage system.
If the door won't open it could be jammed due to the program being interrupted.
If you have questions about this repair, or require additional assistance, please let me know. I hope this helps you.
NOTE: If replacing the drain pump is required, the following link explains how:
http://www.fixya.com/support/r401845-replacing_drain_pump_whirlpool_duet
For troubleshooting guidance, the washer comes with a technical data sheet. It should be located behind the lower toe panel directly below the door. If not located behind the panel, it will be affixed to one of the interior cabinet walls. The tech sheet includes diagnostics procedures, troubleshooting tips and the error code list.
Posted on Nov 25, 2009
  • 643 Answers
SOURCE: F35 code on washing machine WP Duet top of line
This indicate that there is a Problem with Pressure Switch.On Most of the Whirlpool Washer's ( Duet ), if you Open the top panel, then there would be 3 Screws. After that you would have an access to Pressure Switch.With the tub empty, remove the vinyl hose from the switch and blow backwards through the hose to clear any restrictions. If the fault codes return after doing this, you will likely need to replace the pressure switch. Here is a link where you can order it Its
#23 on the diagram.
Hope this answers all your questions
Please remember to Rate/vote for any solution that helps you out.
Leave a comment if you need more help.
Thanks for using Fixya.
Posted on Jul 05, 2011
ZJLimited
  • 17970 Answers
SOURCE: error code e01 f08
Knowed as F8 E1 error code...
This code indicates there maybe a problem with the water supply to the washer. Turn on the water. Check the household faucets to see if the hot and cold water faucets are turned on. Completely open both faucets for proper fill.
NOTE: Both hot and cold water must be connected to the washer and turned on; the washer will not properly operate with only one incoming source of water.
Turn off the water and remove inlet hoses from the inlet valves in the back of the washer. Inside the inlet valves are screens. Remove any accumulated film or particles from the screens. Reinstall hoses, turn on water, and check for leaks. See the Installation Instructions for details; you can find them by entering your model number in the search tool below.
Is the water pressure less than 10 psi? If the water pressure is too low, the washer may not properly operate. To find out your exact pounds-per-square-inch (psi) value, contact your local water utility company.
Are you using HE High Efficiency detergent? Use only HE High Efficiency detergent. Using non-HE detergent, or more than the manufacturer's recommended amount of detergent, can cause excessive suds. The excess suds can prevent the washer from detecting the incoming water.
Concentrated detergents labeled 2x and higher will require a small amount of detergent based on load size. Always follow the manufacturer's recommendations.
To remove the error display, press Power once. Then press Power again to restart the washer. If pressing Power does not work:
Unplug the washer or disconnect the power for one minute.
Plug in the washer or reconnect the power.
Re-select the cycle and press Start.
NOTES:
* On some washers, when the washer is started for the first time after this error code, it will begin to drain. You will not be able to pause or cancel the cycle for about 8 minutes while it drains. This is normal.
* If the error remains on the display, and all of the other conditions above have been checked, call for service.
Hope this helps. Your feedback is important and I'll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using Fixya, and have a nice day.
Posted on Oct 26, 2011
What do error codes e06 and e01 mean?
E01 and e06 codes - Fixya
www.fixya.com/support/t14040885-e01_e06_codes
Aug 19, 2012 - e01 and e06 codes washer will not do anything other than lock the door. - Whirlpool Duet: WFW94HEXW Laundry : question. ... Error message E06 onWhirlpool. Unplug the machine and wait 10 minutes before restarting it.
Aug 24, 2015 | Maytag Washing Machines
Started with E01 and E25
The E01 fault code means that the dishwasher has suffered a power module failure.
The programming of replacement power modules E01 up until E05 has been locked down by Bosch so in the event of an error code of this type it's recommended that you contact a Bosch approved dishwasher engineer.
Apr 12, 2015 | Bosch Dishwashers
Whirlpool washer with error code F08 E01, what does it mean?
Check your water supply is connected and turned on as this is a water supply error. Press on/off button to reset and then press on/off again. should clear if water supply is good.
Feb 06, 2015 | Whirlpool WFW9351Y Duet 3.5 cu. ft. HE...
How are the Whirlpool Duet washer & dryers serviced? From the front or the back
you have to pull it out,this code means you're having prblems with the washer filling,most likely it will be the water valve but i would shut the water off,take the lines off of the washer,stick them into the washer or a bucket and turn the water on,if the water comes out then you know it's the washer and you need to change out the water valve on the washer.
Aug 18, 2014 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Maytag Maxima washer error codes E01 F08
Mine was resolved after changing the Symmons slide valve at the inlet to the hoses. This valve is spring loaded and does not work if not exercised as open and close on regular basis. My hot water supply was completely shut off and cold water remained open at all time. Check the incoming water pressure by unscrewing the hoses from washer and check water outlet by filling the bucket from both sources. Symmons slide valve at the wall is W-400 and was 25 years old.
Aug 16, 2012 | Maytag Washing Machines
Purchased a Maytag Maxima washer two weeks ago--beginning to think it's ****. Have been trying to was a load of laundry for 2 1/2 hours now and can't get the washer to spin the load dry. Have tried...
I just bought the same washer and there is a problem with the steam sensing device. Check for code in time window. mine has a F08 and E01. Repairman coming in 2 days.
Feb 18, 2011 | Maytag Washing Machines
My washer is 2 days old. I selected the bulky level to clean a load of towels. The time showed 1 hour and 15 minutes . After 15 minutes, the bell rang and the code f08 and E01 appeared. This also happened...
Pull out the reciept. Read the info that came with it. Call for warranty service OR if possible, return it to store fro exchange or refund. Some appliances cannot be returned to store, therefore read blurb first.
Jan 17, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Code dl-f machine will not start up, usually you hear the door lock and then water enters- but door does not lock which is why im thinking dl stands for door lock? i unpluged machine hoping it would reset...
Hello.
Potential Causes
Aug 20, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
219 people viewed this question
Top Washing Machines Experts
