Away.turned water to wpduet washer off. Forgot,started when home. E01/F08 code. pump Motor won't stop, door locked and codes won't reset.damaged? Can the machine be reset, need repair It's brand new,
My Maytag Maxima XL was showing F08 E01 and I followed the advice above. Turned off the water, detached the hoses, cleared out the ends, reattached and turned the water back on. Fixed! So happy I did it myself (50+ yr old woman)!
Posted on Oct 07, 2015
    Top Expert:
  • Washing Mach... Master
  • 45,233 Answers
Call for a repair man
Posted on Apr 26, 2015
  • 142 Answers
SOURCE: Hotpoint Aquarius wd440 washer/dryer wont pump out water HELP!
Try unplugging the unit and plug it back in. This may reset the controls.
Posted on Jun 02, 2009
  • 56 Answers
SOURCE: GE WBVH6240 Front load washer. Pump running while empty
you would need to go into the fault codes and read them. the tech sheet should be under the lid or in the kick panel
Posted on Feb 07, 2010
ZJLimited
  • 17970 Answers
SOURCE: i get an f06 and
F6 code is an issue with the motor drive tachometer.
Most often this is caused by poor connections at the machine control or motor controller. Locate the main machine control by removing the top panel and the motor control by removing the rear panel. Remove each connector, one at time, and reinstall. If this does not work, you likely have a faulty control.
E1 means that the thermistor is open and needs to be replaced. The connections can be loose but the most likely cause of an E1 error is a bad thermistor.
If you're comfortable and confident in your do-it-yourself skills and have access to a volt/ohm meter you can check and replace this part yourself.
For replacement parts - head on over to SearsPartsDirect.com - PartSelect.com - or RepairClinic.com and enter in your full model number for a full parts listing.
Hope helps.
Posted on May 28, 2011
rickead1
  • 1998 Answers
SOURCE: door locked, won't turn on. won't reset
Remove the bottom panel which would give you access to the pump area if you look up along the side that the door lock is on you will see a cord with a loop on it pull this cord and the door would open. The panel must be removed in order to locate this pull cord. If you have any further questions message me back and please also remember when our chat has fully concluded to rank how this opinion has helped in your appliance situation it allows me to continue helping others in similar situations in the future Thanks Rick
p.s if after you open the door and you were to leave the unit unplugged for 7 minutes if the error did not go away or if the door once again locked up you would have no choice but to replace the door lock assembly on the unit Thanks again Rick
Posted on Jul 04, 2011
Testimonial: "Good advice fast! Thank you so much for your time and expertise!"
  • 86 Answers
SOURCE: have a whirlpool AWO 3551 washing machine. Door
My daughter had the same problem for about two years. A repair man came out and told her to call the company and tell them she wanted it fixed under a recall. She said the computer board had to be replaced and it was recalled due to a flaw in the machine. The service man came back again after she called, and he fixed it for free.
Posted on Jul 16, 2011
I have a maytag front load washer,two years old, E01 and F08 code, the machine is running, will not shut off and the door will not unlock. I unplug it but door is still locked.
After unplugging the machine, I would start by trying to suck the water out using a wet/dry vac attached to the drain hose going into your wall. You can even use your hand to form the adapter between the hoses. It may take several tries to empty it depending on the size of the vacuum, but it sounds like quite a bit of water in the tub. If this does not work, my guess is that your drain is clogged on the other side of the pump. To clear this, you (and others just needing to know about error codes) should be able to find the error troubleshooting guide the service company refers to taped to the back, inside rear of the machine. You will need to remove the panel at the bottom of the machine by removing some screws and lifting the panel up and out. Use a flashlight to see if the guide is still taped to the inside of the machine. It will give you great information on the error codes. The drain pump assembly is to your right on the Epic series, and possibly other models. If the error codes suggest you have a drain pump issue or clog, you will need several buckets and towels to drain the water. I used two full buckets and did not have water visible in the window. Good luck! My drain pump was bad, and replacing it was easy.
Dec 03, 2016 | Maytag Washing Machines
Bosch shx36l05uc/21: After running diagnostics the 'wash' button keeps flashing, can someone tell me what the problem is?
Hi Jeff, As you can see there's 3 different Bosh washing machine models, Hope you can find your error code.... CHEERS..
Bosch Washing Machine Fault Codes
F16 - Door lock error
F17 - Inlet valve error detected
F18 - Drain error detected
F23 - Anti flood device has been activated
F34 - Door lock error
F42 - Motor fault
F43 - Motor fault
F44 - Motor fault
Bosch WAE Range Washing Machine Fault Codes
F16 - Door lock problem
F17 - Inlet valve
F18 - Drain pump
F21 - Motor
F23 - Anti flood system activated
Bosch WFP Range Washing Machine Fault Codes
F01 - Water intake timeout
F02 - Heating timeout
F03 - Draining timeout
F04 - Motor fault
F05 - Uncontrolled motor startup
F06 - Short on NTC Detected on hot water intake
F07 - Open circuit NTC Open circuit wiring
F08 - Door open when program started
F09 - Unexpected heating
F10 - Communication error
F11 - Overheating
F12 - Short circuit
F13 - Mains voltage too high
F14 - Mains voltage too low
F15 - Faulty temperature sensor on motor PCB
F16 - Faulty rinse sensor Displayed only in test
Mar 30, 2016 | Bosch Dishwashers
Whirlpool washer with error code F08 E01, what does it mean?
Check your water supply is connected and turned on as this is a water supply error. Press on/off button to reset and then press on/off again. should clear if water supply is good.
Feb 06, 2015 | Whirlpool WFW9351Y Duet 3.5 cu. ft. HE...
How are the Whirlpool Duet washer & dryers serviced? From the front or the back
you have to pull it out,this code means you're having prblems with the washer filling,most likely it will be the water valve but i would shut the water off,take the lines off of the washer,stick them into the washer or a bucket and turn the water on,if the water comes out then you know it's the washer and you need to change out the water valve on the washer.
Aug 18, 2014 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Whirlpool f08
whirlpool f08
f08 e03 error codeF8E2 is DISPENSER SYSTEM ERROR - Dispenser motor is unable to reach the desired position. Possible causes: Check the mechanical linkage from the dispensor motor to top of dispenser. See TEST #12 (Dispensor Distribution System) on page 21. Someone else can post to contents of Page 21. Good luck.
Read more: http://forum.appliancepartspros.com/washer-repair/529426-f08-e02-error-codes.html#ixzz34yTou7Nz
Yes, it is a dispenser system error. The technician manual says to check the mechanical linkage from dispenser motor to top of dispenser.
However, in my case this page from whirlpool was helpful:
https://www.whirlpool.com/product-he...r-code/PH5260/
It says a common solution for this error (f8 e2) is:
The detergent drawer or detergent cartridge might be clogged with detergent. Clean out the detergent cartridge per Use and Care Instructions.
If cleaning the detergent cartridge did not correct the problem, please contact us.
For any additional questions, please call our Customer eXperience Center toll-free at 1-866-698-2538, Monday through Friday 8AM-8PM Eastern Standard Time.
You will be asked to provide the model and serial number which is found on the front door rim after opening the door.
So I washed out my dispenser and now it's working again.
Read more: http://forum.appliancepartspros.com/washer-repair/529426-f08-e02-error-codes.html#ixzz34yTzjNdt
May 15, 2014 | Whirlpool WFW94HEAW Duet Front Load Washer
Receiving error code FL on washer display.
The FL error code means:
Flood Condition:FL flashes if any overfill condition occurs. This condition occurs when excessive water in the tub causes the overfill switch to trip. The control must realize that the trip was due to an overfill condition instead of a suds lack condition in order for FL to be displayed
With an overfill condition, the beeper repeats a warning every 10 seconds with no time-out. The pump is cycled in drain mode for 30 seconds on, 30 seconds off until the overfill switch resets or power is discontinued to the unit.
Press STOP/CANCEL to clear the display.
This problem i see on these are the water pumps getting clogged with lint or other things, causing the pump not to pump all of the water out at times.
Dec 07, 2012 | Crosley CW6000 Front Load Washer
Maytag Maxima washer error codes E01 F08
Mine was resolved after changing the Symmons slide valve at the inlet to the hoses. This valve is spring loaded and does not work if not exercised as open and close on regular basis. My hot water supply was completely shut off and cold water remained open at all time. Check the incoming water pressure by unscrewing the hoses from washer and check water outlet by filling the bucket from both sources. Symmons slide valve at the wall is W-400 and was 25 years old.
Aug 16, 2012 | Maytag Washing Machines
Washing Machines Logo
436 people viewed this question
Top Washing Machines Experts
