Question about Refrigerators
Ice buildup at the bottom of freezer, how can I fix this?
Ice buildup bottom of freezer
  • Refrigerators Master
  • 744 Answers
Hello;
My name is Peter. I am a retired field service refrigeration technician.
Although, I am retired I do work on the side with a small customer base.
Last week I made a service call with the same problem, which is common.
You have a frozen freezer drain. Every 8-10 hours your freezer will shut down except for the light. You defrost heater will turn on for 20-30 minutes. Then your unit will turn back on.
If you have a frozen drain the condensate (Water) during the defrost mode has no where to go except to the bottom of your freezer.
I have found pieces of food product such as corn, berries plugging up the drain along with ice.
A service technician would pull the back wall off the freezer to access the freezer drain. Clear the drain with hot water and put in a heat sink, a 12 to 14 gauge bare wire connected to the defrost heater into the drain.
Ok, you do not want to spend $180.00 + for a service technician.
Then,
1.) Unplug your unit.
2.) Remove the front bottom toe plate.
3.) Raise the jacking bolts by turning them counter clock wise.
4.) Pull the unit out so you can get behind the unit.
5.) Remove the lower bottom cover.
6.) Remove the drain tube.
7.) With a turkey baster and old towels under the drain shoot hot water into the drain connection.
8.) With a coat hanger try to clear the drain.
9.) Keep shooting hot water up into the drain and inside drain pan.
10.) Take your time. Spend at last an hour doing this process.
11.) If the bottom of your freezer is full of water, then you did a good job and cleared your drain.
Posted on Apr 26, 2015
Depending on the age of the fridge, it could be equipped with a defrost timer that cycles the defroster element on and off at preset intervals to melt the condensation away inside the cabinet. This timer may be located under the box and most times in the back or side near the compressor. Another possibility would be a broken defrost element, in which case entails disassembly of the inner panels of the box and extracting the element for replacement. This element can be purchased at an appliance parts supply and is most times not very costly.
22yooper
  • 828 Answers
SOURCE: Ice buildup at bottom of freezer and small puddle.
Freezer has a drain in the back under the cooling coil. Melt Ice from drain area with a hair dryer, check drain and clear, under bottom in back behind a removable panel you will find the drain exit from the freezer going into the drain pan. This drain line has a loop for air seal, make sure it is cleared.
Posted on Aug 09, 2008
  • 4 Answers
SOURCE: side by side leaks out front door on freezer side
try checking the tube that water drains out , it could be plugged with crumbs or old partials of food and causing the problem, This has happened with my fridge at one time , affecting the defrost cycle of the freezer and dripping water out of the door, The tube was located under the crisper in the back of the inside of my fridge, Hope this solves your problem
Posted on Apr 19, 2009
jumptrout51
  • 3361 Answers
SOURCE: Water leaking from bottom of freezer door, and ice
The defrost drain line in the freezer has frozen closed. Turn off the fridge. Remove the freezer bins. Use a hair dryer to thaw the drain hole on the bottom rear shelf of the freezer.
P.S. Your fridge is on recall from Maytag for a defective start relay.
Posted on Apr 29, 2009
Greg20
  • 149 Answers
SOURCE: Ice buildup on the coil and ice buildup on freezer floor
you will have to unclogg it..hot water/hairdryer..flexible tubing to push out the clog. the ice on evap coil bothers me though. do all the coils get frosty white(close the door for 10 minutes then check) I fear they aren't and you have a freon leak.
Posted on Jun 13, 2009
heatman101
  • 43501 Answers
SOURCE: why is there heavy ice
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Oct 25, 2010
Buildup of ice on bottom of freezer compartment. Ice then melts and leaks out the bottom
sounds like you have a stopped up drain line where water drains out when freezer is in defrost mode. My Amana freezer does it quiet often.
Jul 15, 2012 | Amana ABB2224WES Refrigeration :...
Frezer temp @ -5 ,referagerator @ 47 degrees. how can I get it colder /
determine if freezer fan is running. If not thats the problem.
Remove the back panel in freezer to access the fan.
Check for frost buildup on back bottom of freezer panel
Sometimes this is a auto defrost problem or ice buildup on
freezer coils.
If ice on the freezer coils is restricting air to the ref.
To confirm ice you will need to turn off ref. for 24 hrs and let the ice melt OR remove back panel in the freezer and visually look for ice in the evaporator coils. if it works fine when you turn it on take your mod number to a local Appliance parts store and they will sell and instruct how to fix the Defrost system
If this was helpful please rate me.
Leo Ponder Appliance-Tyler,Texas
imufo2@sbcglobal.net
Aug 24, 2010 | KitchenAid KSRS25IL Side by Side...
Frost and Ice Buildup
If everything is cooling fine and the frost is not on the back wall but just the floor at the bottom then your defrost drain is stopped up. Remove the bottom basket and clean up the ice on the floor of the freezer. Look on the back wall and you will see some more ice up a littler higher at the back. This is where the drain is. Clean all the ice out from this area too using hot water or a hair dryer. Once you find the drain hole make sure you get all this ice out of it as well. You can take a screw driver once you have melted the ice and gently push it through the drain hole. Once the hole is cleared you should be able to pour hot water freely through the hole. (It is best to turn the refrigerator off while you do this)
Jul 01, 2010 | GE Profile PSS26NGS Side by Side...
My freezer has ice building up on the bottom
Defrost freezer, and make sure the door close well each time
Mar 07, 2010 | Frigidaire Freezers
Ice buildup in freezerator freezer section
If it is not a frost less freezer you'll have to remove perishables to another fridge/freezer; unplug and de-thaw the unit.
Nov 21, 2009 | Gladiator GAFZ21XXMK Bottom Freezer...
Whirlpool refridgerator-model#ETICHMXKOO4-We have
There is ice buildup in the drain and maybe under the seperator. Remove the back panel in the freezer and the botom floor of the freezer and remove the ice. Be careful of the styrofoam ducts. Eric
Aug 10, 2009 | Whirlpool Refrigerators
Excessive frost/ice buildup near bottom on freezer
Hello.
If you remove the bottom drawer in the freezer you will be able to see the back of the freezer. You will notice a large build up of ice in the bottom of that panel. If this is the case, you will need to empty the freezer up to the icemaker bucket. There is a panel with several screw in it that you will have to remove. Once removed you will want to defrost as much of the ice as you can with a hair dryer. Once you get the ice down to the hole you will want to heat some water up in the microwave and pour it into the hole repeatedly until it clears the line and drains on its own. This will remove whatever bug of ice particle that blocked it. Put everything back together and you will no longer have this problem.
Jul 16, 2009 | Maytag MSD2756G Side by Side Refrigerator
Top Freezer works fine but there is no ice building up in freezer the bottom fridge not cooling properlyThings are not as cold as they should be
Remove the back panel from the freezer to verify no ice behind the freezer panel. Look inside the air vent on the freezer panel for ice buildup. Make sure the freezer control is set to minimum not coldest freezer.. Make sure the freezer fan motor is working.
May 28, 2009 | Electrolux Refrigerators
Build up of ice in bottom of freezer compartment
During the defrost cycle heaters in the wall of the freezer are turned on to melt the frost build up. This melted frost "water" is supposed to run out a drain in the bottom of the freezer and collect in a pan under the refrigerator/freezer where it will eventually evaporate. If this drain is blocked it will cause a lot of water to collect in the bottom of the freezer and that water will eventually turn back into ice. I recommend defrosting the freezer manually, removing all the ice/water buildup in the bottom, and trying to unplug the drain line to the pan underneath. Also check the seal on the freezer door. If it's not sealing well it could be letting a lot of moisture enter the freezer which would lead to more frost buildup and more water during the defrost cycle.
May 22, 2009 | Hoover HCA390FFK Bottom Freezer...
Refrigerators Logo
269 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
