Question about Garden
Every time I start to engage the blades it cuts the engine out.
  • 1,169 Answers
Check your operator seat switch and it connection.
Posted on Apr 26, 2015
Testimonial: "Have checked all that. The seat switch is working fine. It also tries to cut out when the deck is lowered."
Cutting blade won't engage
with unit off look under at deck and inspect cable and pulleys and belt adjust and or repair
Sep 28, 2016 | Garden
17.5 briggs motor back fired 1 time and now when i engage blades the motor boggs down
The engine is timed internally and externally. Sometimes when it backfires the external timing key where the flywheel and crankshaft join will be damaged enought to put the engine out of time. The engine may run but when put under a load such as cutting grass it will fail. This is about a 30 minute repair and about $2.00 in parts.
Jul 18, 2012 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Cub Cadet mower ran and then when I engaged the blades, the motor cut out and will not start.
There might be some gunk in your carburetor. I would try and clean that out and see if that's works for you. Hope this helps!
Jun 06, 2012 | Cub Cadet Garden
My Craftsman riding mower runs fine but when I try to cut thick or tall grass the blades slow down and stop cuting, I replaced the belt thinking the belt was worn only to find I still have the same...
well yep it is,,,look at the deck first to check its not tight to turn look for sezed up bearings,,,then check that the drive belt/s are tight and not flopy and slipping also it would be a good time to check the cutting blades they need to be sharp and not blunt or they strain the belts and start them slipping too also the engine wont like the extra load put on it
Jul 28, 2010 | Craftsman Garden
Yard Machines RL 638, '07 model, will not start
Sounds like the blades may be engaged. The cable may not have disengaged completely the last time. When the engine is trying to turn over, the belt is engaged trying to turn the blades which could be why the deck is jerking. It will not start if the blades are engaged because of the safety switches.
Apr 30, 2010 | Yard Machines 155 Torque Briggs Stratton...
Mower cuts off when blade is engaged.
Not familiar with this model, but a thought, check for a kill switch.
Apr 27, 2010 | Poulan 38-Inch Steel Deck 15.5 HP Briggs &...
Engaging blades kills engine
there is a safety switch somewhere toward the bottom of the engagement handle if this switch is bad it will kill the engine there is also a switch under the seat that could be bad
Aug 23, 2009 | Garden
Engine cuts out when engaging clutch or engaging blades..
lift the seat and make sure the connector is firmly plugged into the seat switch
Jun 01, 2009 | Craftsman 21 hp 42 in. Deck Yard Tractor -...
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
