Question about Directed Electronics Dei Directed 450t 7 Channel Expander Module For Alarms
How to install the dei 535t to viper 690xv - Directed Electronics Dei Directed 450t 7 Channel Expander Module For Alarms
Python same as Viper?
Hello Anthony,
This remote will not work with your system. It is only compatible with the Viper 591XV, Viper 690XV, Viper 790XV, and Viper 791XV.
Feb 03, 2014 | Directed Electronics 479V Remote Gen 2...
My viper alarm rpn 479v p x is not working. When i press the unlock or lock button it doesnt work it just beeps. The remote is also flashing rx. Whats wrong?
I got the Problem that my pager-function doen't work. I try it like the Manual saying (*-Button) but the two ways that gives doesn't work.
- Start the Programmmode while Pressing "P" on the Backside.
- Press the "STAR-Button or Panic-Button (Orange Key) on the Sender"
it Beeps 2 Times. (i try it again with 1 beep as reponse again)
i Wait 5 Seconds
it beeps 2 long times
i try the Responder, Activate the System, disarm the System. But the Pager don't change the state or receive any Signal.
The Transmitter is working perfect! No Problems to control the Viper 690XV.
What i do wrong?
Is there any hidden Feature or needable Programming in the Viper 690XV-Brain?
Thanks alot for any helpful Answer :)
May 02, 2012 | Directed Electronics 479V Remote Gen 2...
Hi what tupe of starter i should purches for my car i have santa fe 2002
It really depends on what features you are looking for. I installed Audiovox for 12 years and DEI for 8. I like the DEI much better. The Audiovox always had problems with their remotes and would break down. DEI remotes last much longer and all the options are better on it too. They are the leaders in the field.DEI is the makers of Viper and Python as well as automate.
Nov 12, 2010 | 2000RS-M Remote Starters Manual...
How to install viper smart start modual
only a authorized dealer can program your unit and if you manage to install it only a dealer is able to activate it so i suggest to have an authorize dei dealer install it
Jun 05, 2010 | Remote Start System
Viper 690XV Installing with INT-SL Data interface module
The number 2 pin on my cars OBD II is the data carrier which is then connected to the purple wire of the INT-SL Data Interface Module.
Data Interface Modules are becoming the standard for alarms and remote starter installations. These modules will make installations 75% faster and more accurate. I also recommend using Posi Taps to tap into your OBD II.
This a safe and 100% effective reversible method of connecting wires without crimping, cutting, or soldering. If you have any questions feel free to drop me a line or simply Google: "Posi Taps" by posi products. For Interface modules Google: "INT-SL". Good luck with your next installation. And remember the has endless resources providing you take time out to research them.
By the way my Viper install was a sucess.
Best regards,
Rico
Sep 06, 2009 | Viper Security and Remote Start System...
Need instalation manual VIPER DEI 300 CAR ALARM
http://www.directeddealers.com/manuals/OG/Viper/G3901V_09-2007_web.pdf
May 03, 2009 | Viper Vehicle Parts & Accessories
No install instructions
email me at face2face11@bellsouth.net and i will give them to you. i 've been doing install professionally for 10 yrs and have access to directechs (DEI technician website)
Dec 31, 2008 | 791XV The 791XV is a 2-way Security and...
Directed Electronics Dei Directed 450t 7 Channel Expander Module For Alarms Logo
123 people viewed this question
Top Directed Electronics Home Security Experts
D. E. Hev
Tom Chichester
 Russ Hill
Russ Hill
Are you a Directed Electronics Home Security Expert? Answer questions, earn points and help others
