Question about Braun Health & Beauty
Haven't used my Braun tammiso 1370 for Afew years , all lights flashing and not working
  • 3 Answers
"All lights flashing" on Tassimo is a general error condition. But the two absolutely most-likely conditions to cause it are:
1: Unit is not detecting a water tank with sufficient water in it. Inside the tank, near the bottom, there's a vertical chamber that holds a small, floating magnet. As long as the tank contains some water, that magnet should float to the top of its chamber, where it can be sensed by a detector hidden inside the brewer. Make sure your magnet is present and not stuck, and that the water tank is seated correctly.
2: Unable to read bar codes. Use a damp cloth to clean the bar code scanner window under the T-disc holder. Use the cleaning disc to test.
Posted on May 25, 2015
Reset light has appeared.What action is required ?
There is no Reset Light as far as I know and the manual seems to indicate the same. I have a series 5. The green light shines when you are using it. The red light flashes when the power in the battery is less than 20%. Put it on to charge and the light will flash green until it is fully charged and then the light will be solid green.
All of the manuals are here from Braun
http://www.service.braun.com/product/search.asp?rg=NA&c=US&l=GB&typ=ui&frmTyp=subgrp&sgrp=subgrp&grp=SH01%3C%7C%3ESH02%3C%7C%3ESH03%3C%7C%3ESH04%3C%7C%3ESH08%3C%7C%3E&s=&subgrp=Series+7%2C+9000+series+-+Pulsonic%2FProsonic%2CActive+P
This manual page is showing the light indicators.
http://www.manualslib.com/manual/20437/Braun-Series-7-720.html?page=8#manual
Braun SERIES 7 720 User Manual Page 8
Apr 01, 2016 | Braun Series 7 720 Electric Rechargeable...
Why have I got a red light on the bottom of my shaver when I am using it
It is common for many Braun shavers, that if the indicator light flashes red while the shaver is being used (switched on and running), it means the battery is low and needs to be charged soon.
Below is an example from a manual for a Braun model 7526 shaver. You can search that site for other manuals if this is not the correct one.
This model shaver has 3 indicator lights:
1) Green (Charging)
2) Red (Low battery)
3) Blue (Power cord attached and plugged into the wall)
Download the manual for the model 7526 here: http://www.manualslib.com/manual/20281/Braun-5301.html#manual
"The green charging light shows that the
shaver is being charged. When the rechargeable
battery is fully charged, the charging light
flashes or goes off.
If later on, the charging light comes on
again, this indicates that the shaver is
being recharged to maintain its full
capacity.
The red low-charge light flashes when the
battery capacity has dropped below 20%,
provided the shaver is switched on. The
remaining capacity will then be sufficient
for 2 to 3 shaves."
Nov 09, 2015 | Braun Health & Beauty
My Shaver will not charge or turn on
Model 7526 is not a new shaver. It was made about 8 years ago. If no lights illuminate when the power cord is attached, the circuit board is bad. Unfortunately, Braun no longer makes internal parts for this model
If you like this shaver model and want a similar one, you will find one at shaveroutlet.com. This model uses the same shaving head as the 7526
http://shaveroutlet.com/braun-series-1-195s-mens-cordless-shaver.html
Oct 27, 2014 | Braun Syncro 7526 Electric Shaver
I have a braun km32 kitchen machine that needs a new switch. Where can I find one?
Did you get it fixed? If you haven,t, let me know and I'll show you how I fixed mine. Jdfnnef@bellsouth.net.
Oct 30, 2012 | Braun Food Mixers
Worked the first time, now doesn't even turn on
there is no sense in trying to fix it as it is under warranty for 2 years. call or contact Braun using the information that came with the shaver
Jun 22, 2010 | Braun Series 5 570cc Electric Shaver
My 8585 braun shaver will not clean the lights flash but nothing
my braun 8585 is five years old and i would like to have it serviced and referbished, please let me know the cost if this is possible?
May 29, 2009 | Braun 8585 Electric Shaver
Braun Tassimo Coffee maker quit working
Hmm if not in covered try
http://rapidshare.com/files/238159116/Braun_Tassimo_3107_Disassembly.pdf.html?killcode=397312781122638452
Mar 15, 2009 | Braun Tassimo TA1400
Braun Coffeemaker Programming
to prgram the automatic operation, press the automatic buton until the green pilot light begins to flash. The time "12:00" or the previously programmed time appears on the display. When the green pilot light begins to flash, release the button and press the hour and minute buttons until the correct shows; ensure the hours are am or pm. After programming is completed, the green pilot light will go off after 5 seconds.
Dec 08, 2008 | Braun FlavorSelect KF 180 Coffee Maker
Health & Beauty Logo
203 people viewed this question
Top Braun Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Braun Health and Beauty Expert? Answer questions, earn points and help others
