Question about Keyless Entry Remote Fob Clicker for 2002 Explorer With DoItYourself
After going over a few potholes in my city, started hearing noise from back of truck, could this cause rear differential problem
    Top Expert:
  • Ford Master
  • 46,730 Answers
Unlikely but a check of the suspension may reveal broken bolts, failed rubbers and bent units, including shocky shafts.
Posted on Apr 26, 2015
a 6ya Mechanic can help you resolve that issue over the phone in a minute or two.
click here to Talk to a Mechanic (only for users in the US for now) and get all the help you need.
Whining noise on my 2002 Tahoe 4wheel drive in the front
Whining when you start it up in park. Check the power steering fluid. If it starts after you are going down the road, check wheel bearings and front differential. If you live in Indiana/pothole city. You may want to check alignment.
Mar 25, 2015 | 2002 Chevrolet Tahoe
2005 subaru outback xt makes thumping noise in rear
Start with inspecting the rear tires for out of round or bulges.
Next, inspect the rear shocks for oil leaks,
Both of these can cause the thump you describe.
Jul 18, 2017 | 2005 Subaru Outback
Rear differential noise
I'd check the universal joint very carefully.
May 19, 2017 | Hyundai Cars & Trucks
I am having a noise that appears to be coming from the rear of my '05 Jeep Liberty Sport 4x4. The noise kind of builds up to a certain level, then backs off and in a few seconds begins to build back up...
it could be a u joint hard to tell.it could be in the rear end(differential).if you accelerate and the noise is there then this indicates a ring gear to pinion gear problem or if its there but not as noticeable when at a steady speed then it sounds like differential bearings.if you hear it when turning then it could be axle bearings.
Apr 27, 2011 | 2005 Jeep Liberty
Clanging noise rear and rear don't pull
The axle probably lost a keeper ring on the inside of the differential and the pieces may be going through the differential and ring&pinion gearing making the noises you hear. You will need to drain the oil out, find the broken pieces, and inspect all gearing for broken/damaged teeth, and for any noisy bearings. Flush the case out with cleaning solvent. Re-insert the loose axle after cleaning and inspecting it well--especially the interior end. Replace the keeper (new) on the axle end inside the differential spider gearing. Inspect the brakes on the loose axle side for any oil deposits and for any damage that might have been caused when the axle came out. If the differential is badly damaged, it might be cheaper to find another rear end in a wrecking yard. Hope this helps!
Dec 26, 2009 | 1997 GMC Suburban
How much in ny to replace front end differential, horrible whaling hum from front end. did local shop cause this when seals were done last year, i heard they have to torque it properly or this damage will...
only if seals leaked out the gear lube.
you need to check the fluid level first,
and make sure your not hearing a front wheel bearing going bad,does it make the noise only in four wheel drive?
before you start worrying about price of front differential you need to locate for sure what is causing it.
Dec 06, 2009 | 2000 Jeep Grand Cherokee
2002 dodge 1500 rear end making whining nosie
This could be one of several problems: If the noise increases with speed, and you are only hearing it from the rear differential and not the transmission, it could be the rear differential carrier bearings, or rear axle bearings going bad. If you are only hearing the noise upon acceleration or deceleration, the rear differential ring and/or pinion gears may be going bad and the rear differential will need an overhaul. You'll have to get the rear wheels off the ground and see if you can pinpoint the location of the noise with something such as a stethoscope. If it's coming from the rear differential, you'll need to pull the bolts and the cover to determine if the gears are still in good shape, or if there is any pitting. Same with the carrier bearings; if you see pitting/ discoloration, they'll need replacement. If the noise is coming from one side towards the end of the axle shaft near the wheel, it's most likely a axle bearing going bad, and you'll need to pull the wheels, remove the diff. cover to release the C clip which holds the rear axle in place at the differential, and pull the axle out. You also need a special tool with a slide hammer to remove the axle bearing and seal.
Nov 20, 2009 | Dodge Ram 1500 Cars & Trucks
1999 chevy blazer starts, but makes noise and no acceleration
Smoke coming out from the middle of the two rear tires right? Sound like your rear differential is out of lubricant. Leftover lubricant is probably getting burned by heat from the friction. Have your rear differential lubed up.
May 01, 2009 | 1999 Chevrolet Blazer
2001 pt cruiser hear a thump noise
This is either caused by a wore out strut/shock in the rear of the car or a broken spring.
Jan 19, 2009 | 2001 Chrysler PT Cruiser
Keyless Entry Remote Fob Clicker for 2002  Explorer With DoItYourself Logo
Top Ford Vehicle Parts & Accessories Experts
xxxxxx xxx
Thomas Perkins
Thomas Perkins
Colin Stickland
Colin Stickland
Are you a Ford Vehicle Part and Accessory Expert? Answer questions, earn points and help others
