Question about Champion Dishwashers
I have a champion uh100-b that won't turn off properly with the on off switch
When I turn off the unit it goes through the drain process but then fills and drains fills and drains.. the process continues over and over and will not turn off unless I turn off the breaker or turn the fill switch to the off position. this unit has been cycling fine until now
catriver
  • 878 Answers
SOURCE: washer fills then drains
Daisy, check your drain hose going into the drain. It sounds like you have a siphoning problem. If the drain hose does not have a air gap the water filling will siphon right out. Check this first and post back, Catriver.
Posted on Sep 21, 2006
catriver
  • 878 Answers
SOURCE: Dishwasher Does Not Cycle
IA, these GE pumps have a habit of sticking if the unit hasn't been run for a while. First you want to verify that the motor is in fact getting power, this will eliminate the timer. You can use a meter on the quik connect from the motor while in the wash cycle. If the motor is getting power, see if the pump is stuck by turning the motor vanes (Do this with the power off). If it's hard to turn and then frees up than this was more than likley your problem. You remove the bottom toe panel and will be able to check this out without removing the dishwasher. Catriver..post back
Posted on Dec 30, 2006
  • 68 Answers
SOURCE: LXGH E5 Code
I need to check my codes to be positive. And I'll check them this weekend. But, I believe E5 is from excess water in the unit, and so it won't go into rinse and add more water.
First and most common -- the drain hose, at the back of the unit is kinked. The unit gets pushed back against the wall and kinks the line.
Second, your probes are dirty. The ones in the back right corner detect water level. Clean them with a green scrungee even if they look clean.
Good luck - Mike
Posted on May 10, 2008
Krazytech
  • 725 Answers
SOURCE: Bosch SHX46A02UC-21
float switch is in the flood position and the drain pump is running.. there is water under the dishwasher or that switch is stuck up..
Posted on Aug 21, 2008
  • 9 Answers
SOURCE: does not advance to drain cycle
I would bet that it is the timer switch assy.
Motor runs ? yes
washes? yes
drain tube clear ? yes
If there is no drain valve to deal with, the problem must be the contacts during the timer cycle, since the main obviously works or you wouldn't be able to wash anything.
you need a new timer switch assy.
Posted on Nov 20, 2008
Water in the Safe-T Switch
It is a Condensate Overflow Control , your drain line may be clogged if it is clear and no water present you may have a bad sensor. If the unit is not draining properly it can cause a freeze up of the coil and compressor damage.
Jan 14, 2013 | Rectorseal Safe-T-Switch
I have a Bosch SHU9955US/14 (Integra) dishwasher. There is currently a 0 with and asterisk showing on the display and the unit will not run.
see this causes and fix it. God bless you
Thermal Fuse If the dishwasher won't start the thermal fuse might have blown. The thermal fuse helps to prevent damage to the dishwasher by turning off power so that it doesn't overheat. Once blown, the thermal fuse will have to be replaced for the dishwasher to work.
Door Switch The door switch, or switches, are sometimes called interlock switches. The door switch prevents the dishwasher from running while the door is open. If the dishwasher won't start, the switch or switches might be defective. To access the door switches, remove the control panel or inside door panel - depending on the model. They can be tested for continuity.
Main Control Board The main control board provides power to nearly every component of the dishwasher. If the dishwasher won't start the main control board might be defective. YOU should first check for more common parts. Many times control boards are replaced unnecessarily because the problem was not diagnosed properly.
Touchpad and Control Panel If the touchpad is defective, the control board might not get the signal for the selections made. If the dishwasher won't start and the display doesn't seem to change properly when the buttons are pressed, the touchpad might need to be replaced. On some models the touchpad and control panel are sold together and will need to be replaced at the same time.
Touchpad If the touchpad is defective, the control board might not get the signal for the selections made. If the dishwasher won't start and the display doesn't seem to change properly when the buttons are pressed, the touchpad might need to be replaced.
Timer The timer allows power to flow to the proper parts at the proper times. If the dishwasher won't start, the timer might be defective. Keep in mind that timers are often misdiagnosed as the cause of a problem. Check other components first before replacing the timer.
Sep 29, 2012 | Bosch Dishwashers
Sony HXD560 won't boot up
Download its user manual and refer its troubleshooting page. To download it, click here.
Jun 09, 2012 | Sony RDR-VX555
I have a champion 10000 watt gen welder won't bur
Make sure the switch for remote power or control at machine is on the right setting. It will arc but very faint if this switch is not on the right setting.
Mar 17, 2012 | Hobart Welding Tools
My A/C won't turn on, I have a Goodman unit in my condo. The fan isn't turning on, nor anything else on the unit. The thermostat is working, and trying to kick the unit on. Help?
If this is a fairly new instillation you may want to check the drain line to see if it has a float switch and if it does you may want to check and make sure the drain line is draining properly. If the float switch is activated it will shut down the whole unit depending on how it has been wired. Also you may want to make sure that you have two legs of 110/120v going to the air handler. Most AC's need 208/230v ac to run and it is very common to loose one of the 110 legs that provide you the 208/230v. This usually occures at the breaker.
Sep 01, 2011 | Goodman Heating & Cooling
Do you know what the proper Champion part number is for a Toro 51972 weed trimmer is? This was purchased used and it had a RCJ4 Champion plug in it and I just need to verify that this is the correct plug....
that is the correct spark plug for the unit. i work at a power equipment store where we work on homelites. 90% of the time it wont start or run right is usually carb issues . need to get it rebuild or replaced
Aug 25, 2011 | Toro& Electric String Trimmer
HF error flashes, then after 7 min. drains machine, but won,t go in wash cycle
Kenmore HE3T front loading washing machine. About every 2 minutes the cycle stops and flashes an "f" then an "h" on the display over and over again. **
That error code can be the result of no water detected entering machine after 30 seconds or pressure switch (water level control) activation not detected after 8 minutes of filling.
If there is no water in the machine at the time, make sure that both water taps are turned on, check for kinked fill hoses or plugged sediment screens in them and verify the water fill valve operation.
If there is water in the unit, verify drain pump and water pressure switch are operating properly, the pressure switch hose is in good condition and properly connected to the pressure switch. Also, make sure the water is not siphoning out of the machine prematurely due to an improperly installed drain hose
That error might also be caused by too much suds in the wash water like can result from using non-HE detergents
Nov 29, 2010 | Kenmore HE3T Washer
My champion juicer just stopped working. Makes no sound at all when I flip the switch. Any ideas?
Championjuicer.com sells replacement switches. Order the oil seal and o-ring too to save on shipping. Newer models have a safety cut off that does not allow the juicer to turn on unless all parts are properly positioned.
Oct 25, 2010 | Champion G5NG853S Household Juice...
Takes long time to start washing cycle, makes groaning sounds as it gets started, then barely into process it beeps and flashes "f" and "h" alternately.I noticed that when I tried the "rinse/drain" cycle...
F/H" No water detected entering machine or Pressure switch trip not detected.
If after 30 seconds the control does not detect water entering machine and then valves will be turned off and the error code will be displayed.
Or
If the control has turned the water valves on and after 8 minutes the flow meter has detected 10.5 gallons of water passing through it, but has not detected the pressure switch trip, the valves will be turned off and the error code will flash.
Press PAUSE/CANCEL twice to clear the display.
  • If there is no water in the unit:
    1. Make sure that both valves at the water source(s) are turned on all the way.
    2. Check for plugged or kinked inlet hoses or plugged screens in the inlet valves
    3. Check inlet valve operation
  • If there is water in the unit:
    1. Check Drain pump operation
    2. Pressure Switch Hose is in good condition and properly connected to Tub and Pressure switch
  • Check there is not a siphon problem
  • Check wire harness connections to:Inlet Valves, Pressure Switch, Drain Pump, Flow Meter, and Central Control Unit (CCU)
  • Check all hoses for possible leaks
  • Check pressure switch operation
  • Check flow meter operation
  • Check CCU operation
Aug 12, 2010 | Whirlpool Duet GHW9150P Front Load Washer
I have a 1998 Champion 181 bass boat. The navigation lights are not working properly. - When I plug in the front green/red light, it immediately comes on with control switches in the OFF position. (The...
Check the switch. It sounds like it has seen better days. Also check the wires on the back of the switch to see if they are shorting out. The problem is at the switch area. Good luck.
Apr 15, 2009 | RTO Oar Sockets
Dishwashers Logo
71 people viewed this question
Top Champion Dishwashers Experts
Owen Barnes
Are you a Champion Dishwasher Expert? Answer questions, earn points and help others
