Question about Shark Shkl3kitxmbt388il 3 Motorcycle Snowmobile Bluetooth Multi Interphone Headsets 3 Riders Bluetooth Intercom Triple Pack
I just received this today. It said to charge headsets for 3hrs. But it also said when charging red light would come on headset to let you know its charging. No red light on any?
    Top Expert:
  • Shark Master
  • 51,202 Answers
If the battery is not connected properly and making good contact with the terminals then it will not charge and no red lights
Posted on Apr 26, 2015
Testimonial: "All power up. Tried all cords and jacks for charging. Nothing on all 3? No red lights at all"
  • 2 more comments
  • Bill Boyd Apr 26, 2015
    is there a battery in the unit to start with. no amount of cord and charger changing will do anything if the battery is not actually connected with the terminals. If it is brand new out of the box ,take it back for a new one.
  • Ronm860
    Ronm860 Apr 26, 2015
    must be. they turn on. all i have is a usb on one end and a small plug that goes into head set. they work, just no light when charging. maybe they came fully charged
    that is a possibility but normally if charging the red light will come on to show circuit and then go off or turn green to show charged. If new take them back to get the answers from the shop geek
  • Ronm860
    got them from amazon. im the shop geek.lol
I bought these yesterday and they worked great. today i cant seem to get them to charge.
Mi9ght have a bad cable or charger is bad. Take back to store with receipt if only 24 hrs old.
Feb 15, 2016 | Radio Communications
Red blinking light
Hi, Ephraim. The flashing red light indicates that the device is showing "low battery". It could be that the LG phone charger fits the charging port on your bluetooth headset but it is not compatible with your device. In order for you to know that it is charging, the device should show a steady red light(means charging).
Please take a look at the table reference below.
•With the Charger Plugged In
______________________________________________________________________
•Headset Indicator Headset Status
Red-----------------------------------------------Charging (battery level less than 50% charge)
Yellow-------------------------------------------Charging (battery level more than 50% charge)
Green--------------------------------------------Charging complete
With No Charger Plugged In
Off ---------------------------------------------Power off
Three blue flashes------------------------Powering on/off
Steady blue --------------------------------Pairing/connect mode
Rapid blue/purple flashes -------------Connection successful
Quick blue flash --------------------------Incoming/outgoing call
Slow blue pulse --------------------------Connected (on a call)
Slow blue flash ---------------------------Standby (not on a call)
Slow red flash ----------------------------Idle (not connected to phone)
Slow purple pulse -----------------------Connected call muted
Steady red ---------------------------------Attempting to connect
Quick red flash ----------------------------Low battery
Note: After 20 minutes on a call or of inactivity, the light stops flashing to conserve power, but the headset remains on
Hope that'll help you in some way.
**Please rate my post and/or leave a comment** ...Thanks...
Sep 25, 2013 | Motorola Mobility H560 Bluetooth Headset
Headset not charging
Sometimes it takes longer than two hours. Leave it plugged in overnight if you can. The indicator light should go off after fully charging.
Aug 14, 2009 | Motorola Mobility H500 Wireless Headset
I Can`t switch my headset on, and it stops charging after 20 secs
Move the call control button up or down, the indicator light will flash blue if it's paired or blue and red. If it flashes blue and red you need to pair phone with the headset. the passkey is 0000.
Jun 17, 2009 | Plantronics Explorer 340 Wireless Headset
PL-CS55 headset lifts receiver but only get buzzing sound in
Try a system reset:
1. Lift the headset off of the charging cradle (the base).  Make sure the headset is turned off.  The green light on the base won't be on if the headset is turned off. 2. Hold down the call answer button on the headset at the same time as mute button.  The mute button is found on the little black wheel on the top of the headset.  Use the tip of your finger to push it straight in. 3. Hold both buttons until you see a green light on the headset flash.  It will be right below your thumb.  Hold both buttons until the green light flashes for a series of 2 flashes.  Then let go of both buttons. 4. Put the headset back on the charging cradle and wait 30 seconds.  Lift it back off and try again. 5. If this doesn't work repeat the process once more or try a resubscription.
Resubscription procedure:
1. Put the headset back onto the charging cradle.  Make sure the red light on the base is on and the yellow light is flashing. 2. On the back of the base there are two buttons for the microphone adjustment that can be pressed down.  Press both of those down until the red light and yellow light on the front of the base start flashing. 3. While the headset is still on the charging cradle press and hold the mute button until the red light on the base goes solid, and the yellow light stays flashing. 4. Unplug the power to the base and then plug it back in. 5. Wait 20 seconds and try.
Apr 22, 2009 | Plantronics PL-CS55 Wireless Headset
4pr909 bluetooth headset chargine issue
It may be defective. Even if its not charging well it should still light up if there's a charge connection. Return it if you can and buy a better one.
Apr 21, 2009 | Cell Phones
Plantronics Pulsar 590A headset won't charge anymore.
I too have the same problem as jessehaye154, does anybody know of a solution?
Apr 10, 2009 | Plantronics Pulsar 590A Wireless Headset
Not charging...
had it for 2 years never used, tried charging it today and wouldnt show the light saying that it is charging
Jul 14, 2008 | LG HBM-550 Wireless Headset
Charging H550
The indicator light turns red when the battery is
charging. It may take up to 1 minute for the
indicator light to turn on. When the headset's
battery is fully charged (about 2 hours), the
indicator light turns off.
Jan 09, 2008 | Motorola Mobility H550 - Bluetooth Headset...
Shark Shkl3kitxmbt388il 3 Motorcycle Snowmobile Bluetooth Multi Interphone Headsets 3 Riders Bluetooth Intercom Triple Pack Logo
143 people viewed this question
Top Shark Radio Communications Experts
eradiostore
eradiostore
Are you a Shark Radio Communication Expert? Answer questions, earn points and help others
