Question about Oreck Cordless Steam Iron
I dropped it and broke the bottom blue plastic piece off. Can it be repaired?
    Top Expert:
  • Oreck Master
  • 42,705 Answers
There are special supa glues on the market that will glue it together
they are made by locktite and available from locktite agents and bearing supply shops.
Posted on Apr 26, 2015
Dropped it and now the bottom piece is cracked how do i change it
Irons are not repairable items unless they are professional use models. You just buy a new and better one.
Feb 28, 2016 | Irons
Parts for Model DG8030
Google Rowenta repair. They have stations all over the US.
Jul 25, 2014 | Rowenta DG8030 Expert Pressure Steam Iron
Steam button broke?
I've looked up parts for this iron. Sorry to say the steam button is not listed. The button may be able to be repaired at a small apliance repair center, but I do not know what the cost would.
May 07, 2014 | Rowenta DG8430 Pro Precision Steam Station
Where can I order the steam trigger part that is broken. I need the part number. It is a Rowenta DG980. Thanks
Rowenta RS-DG0123 Knob Trigger, Blue
http://www.smallappliance.com/product.asp?pid=4477&cur=USD&cam=GA_B_rowenta_part
Carefully pry off blue handle cover on top with a popsicle stick.
A quick (maybe permanent) fix while waiting for your part: you can "weld" the plastic trigger back together. It doesn't have enough surface area for glue. Position the break back together. Secure parts so they don't move. Heat a medium-small flat blade screwdriver until it will just melt the plastic with a gentle touch. Touch the tip parallel to the break and melt a shallow groove about 1/4 of the way into the break. You should be centered on the break so you melt a bit of each piece. This will be the start of melting the two pieces together. Now, as you do each side of the break, use the flat of the blade to "trowel" the curled up plastic back into the groove you just made. Be careful not to distort the side that activates the switch. Ours is holding so well that I keep the new part in case this ever breaks again.
Less is more: use only enough heat to melt the plastic with a gentle touch. If it's red-hot you went WAY too far. You can always try more heat, but if you fry the part, you are done until your new part comes.
Sep 14, 2011 | Rowenta DG-980 Iron
The top plastic piece that runs the length of the top of my Rowenta DE 831 broke. Can I get a replacement part for this? Can an exploded view of the parts be obtained, or a manual? Thanks.
Only if you check up with Rowenta this part will be available but if you can search around in service shops you may be able to salvage one from a coil damaged iron that was discarded.
If not fabricate the top with a fibreglass or plastic repair shop and it can be doe to suit the top after a paint job.(If broken use good glue and then paint on top)
Aug 31, 2010 | Rowenta DE851 Iron
A PIECE BROKE OFF OFF THE MAIN BODY WERE THE
Try filling the hole with some fibreglass resin ( the stuff that motor car shops sel for fixing car bodies). This would provide a quick setting, hard filler.
Dec 14, 2009 | Rowenta Commercial Garment Steamer - White
My Oreck Cordless Iron leaks constantly. What can I do to stop the leaking?
Find where the leak is coming from, and coat the leak or crack with silicone.
Jul 29, 2009 | Oreck Cordless Speed JP8100CA Iron
Oreck Cordless Steam Iron Logo
157 people viewed this question
Top Oreck Irons Experts
Kevin Getz
Kevin Getz
brian kossman
Level 1 Expert
Are you an Oreck Iron Expert? Answer questions, earn points and help others
