Question about Garden
The center bowl will not hold water. Any suggestions will be appreciated
  • Linda Everson
    Linda Everson Apr 29, 2015
    I used silicone sealer from the pond store. Problem solved
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
    Problem Solver:
  • 19 Answers
Thanks for the update. Please mark the question as Solved ;)
Posted on May 15, 2015
Cannot get my 8hp troy built Briggs & Stratton chipper vac to start. I have tried everything! suggestions would be appreciated
Clean the bowl under carb,theirs a nut at the bottom holding it ,pinch your gas line so gas won't come out.remove gas and reinstall.
May 25, 2015 | Troy Heavy Machinery
Toilet tank...leaking into bowl
rubber flapper in the center of the tank replace.
May 03, 2017 | Home
When the toilet is flushed water comes out from under the toilet bowl
The wax ring has gone bad. If the toilet moves when you set on it you might try snugging down the bowl bolts on both sides but be very careful not to go to tight you will brake the bowl.
If you decide to try to fix this your self with you buy a new wax ring buy the one with the horn in it they seal better.
Jan 31, 2011 | Home
Toilet bowl doesn't hold water but tank is full
The bowl is filled up with the little hose inside the tank, it locks inside of the overflow drain. And runs water in there as it flushes to swirl the water and fill the bowl. Water seeks it's own level, and the level in the bowl is at the top of the trap. It has to hold water, unless it isn't filling or it is leaking. Check out the filler and hope the bowl doesn't have a crack in it. Hope this helps.
May 03, 2010 | American Standard Home
We have a v illeroy and bch cistern that cracked
yes i can,,,he done the scews up to tight that hold then down and the move ment in them is cracking the screw holes out, undo the screws a little that hold them down and maybe put in some rubber washers as well,,,you only sit on them, its not a jig your doing
so they realy dont need to be done down tight only just to hold them thats all,
Jan 12, 2010 | Villeroy & Boch 6610 11 Subway...
I have a American Standard Cadet three, it flushes properly but the bowl does not fill up with much water unless I hold down the handle....is this normal?
in the tank check that the small white hose is not kinked or has fallen away from the center tube where the flush flapper is located the white hose goes into the center and fills the bowl
Oct 01, 2009 | American Standard Compact Cadet 3 Right...
How does it come apart for cleaning
The hot water did work for mine. Here is the solution I discovered:
After removing the food plunger and juicer cover: (1) Unscrew the 3 screws that hold the cutting blade plate in the center of the basket and lift off the cutting blade plate; (2) Unscrew the base counterclockwise (it will unscrew from the threaded center piece) and lift it up; (3) Lift off the basket and juice bowl. Now you can clean the basket and juice bowl.
To reassemble, reverse the process.
Sep 20, 2009 | Juicers
In the tank, when I flush, water comes shooting out of the black plastic thing, about 2 feet high! How can I make this stop so it flushes properly again? (its an eljer 2001)
is the black thing between the the tank and the bowl?
if so, go to any of the home center or plumping store for the seal.
shunt off the water and unbolt the 3 bolts that holds the tank to the bowl from the buttom. you may need a flat screw driver to help hold the bolts. pull up the tank slowly, and lay it on the side, replace the seal, reseat the tank on to the bowl and tighten the bolts. make sure all bolts are equal pressure and the tank is level.
May 05, 2009 | Eljer & Patriot& Elongated Toilet Bowl
General Electric 6-Quart Slow Cooker double bowl
According to instruction book: To use Double bowls in the crock water must be used. Otherwise crock may overheat and crack.
1-Pour one quart of water into the crock. Prepare recipe according to instructions. Place food in the bowls.
2-Place both bowls into crock. Cover & cook.
To Use Double bowls in the base (without crock)
1-Prepare recipe according to instructions. Place food in bowls.
2-Place both bowls into the slow cooker base. Cover and set control knob to desired setting.
Hope this helps.
JL in CA
Jul 03, 2008 | GE 106851 6-Quart
Garden Logo
303 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
