Question about LG Microwave Ovens
My lg over the stove microwave rattles when using specialty settings
When we defrost, or use other specialty setting
  • Tedowen May 02, 2015
    Hi Karen Walter, I want to help you with your question, but I need more information from you. Can you please add the oven model number details in the comment box?
4 Suggested Answers
  • 132 Answers
SOURCE: Microwave clock and duration won't set
Good Morning,
Unplug the oven and wait 3 minutes then plugit back in and check to see that it operates normally. Do not run the oven empty - place a cup of water in it. Let me know if this helps and thank you for using FixYa!
Posted on Mar 30, 2009
MicrowaveSvc
  • 9098 Answers
SOURCE: We have an LG LMV1640DB1 over the range microwave.
Maybe, but your filter may be clogged, or your outside vent outlet may have a bird's nest or mouse nest in it.
If you're venting to the outside, you would be using a grease filter. They should be washed in hot soapy water every six months or when they get dirty.
If you're not venting to the outside, then you should be using a disposable charcoal filter. That cannot be washed, it must be replaced every six months or whenever it gets too dirty.
Refer to your installation manual and/or owner's manual.
If for some reason you don't still have yours, you should be able to download your LG / Goldstar manual here.
If not, you can download a similar one there or contact them via that page to order one.
You can find parts links here.
Posted on Dec 06, 2009
MicrowaveSvc
  • 9098 Answers
SOURCE: Hi sharp microwave R-33ST 900w was used to defrost now won't heat anything up how do I change settings back?
It should default to the highest power setting.
If not, you can reset it by unplugging the power for a minute or two, plugging it back in, and setting the clock.
Otherwise, refer to your owner's manual.
Posted on Apr 16, 2013
My 6 year old LG above stove microwave is giving me an error message E-4 when I try to use reheat.
try unplugging the unit for about 5 min..... for the microwave to reset. Plug back in and try a microwaveable safe bowl with a little water for 30 sec. This may take care of the error message.
F4 indicates an open sensor
Jan 05, 2018 | LG Microwave Ovens
2 slices of bread wrapped in paper towel microwave set on defrost set 35 seconds caught fire
Microwaves work by friction. They blast water molecules in the food so they move fast, just like rubbing your hands together makes them hot. Some types of microwave in defrost mode actually apply FULL POWER for a short period of time so to make the product warm to the touch. This heat then penetrates down to the core of the food, ensuring full defrost. In your case the heat was sufficient enough to heat the dry paper towel to set it on fire.
Bread is better defrosted on the low power setting as sliced bread is very thin. Items should only be defrosted on the defrost setting that are thick and need to be completely defrosted on the inside. Remember microwaves only penetrate the surface of food, making that hot. Thermal conduction does the rest.
You should never use paper towels in a microwave unless the instructions for doing the food say so. You wouldn't put a paper towel in a gas or electric oven, so don't put them in a microwave.
Feb 18, 2016 | In Microwave Ovens
Panasonic rattling noise
magnetron going bad, or fan blade
Apr 22, 2014 | Panasonic NN-S251 Microwave Oven
Apr 15, 2013 | Microwave Ovens
My microwave makes a rattle noise when turned on
check to make sure the plate is inline with the roller setting so it rolls around inside correctly when in use, other wise that will rattle.
Sep 27, 2012 | GE Spacemaker Over-the-Range Microwave
My LG over the range microwave makes a rattling noise when I am cooking. The sound is not there is the item I am microwaving is heavy.
This may sound a bit nuts, but remove the glass tray and support ring. Clean the wheels and ring. Also clean the glass and microwave surface where the wheels run. Any tiny bit of debris will stop the wheels from turning, and make a rattling noise.
If that doesn't help, you may need a new turntable motor.
Feb 26, 2011 | LG Over-the-Range Microwave
Can you put and over-the-counter microwave over a stove?
Yes, that is what they are made for, As long as it has a vent that can be used to vent the smoke from cooking it can be mounted over the stove. Normally the bottom of the microwave should be mounted 16" to 19" above the stove top. The microwave must have a vent with a blower motor in order to be used above a stove top. Most have a thermal switch that will turn the microwave vent on once the temperature reaches a set point.
Jun 12, 2010 | GE Spacemaker 1.7 Cu. Ft. Over-the-Range...
How do you set whirlpool microwave to 50% power
The microwave oven should be at a temperature above 50°F (10°C) ... microwave oven can be manually set to defrost. To defrost. manually, use 30% cook power. ...
www.whirlpool.com/assets/pdfs/product/ZUSECARE/8205987.pdf
Jul 03, 2009 | Whirlpool GH4155XP Microwave Oven
Good Morning,
Mar 30, 2009 | LG Microwave Ovens
Microwave Ovens Logo
61 people viewed this question
Top LG Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a LG Microwave Oven Expert? Answer questions, earn points and help others
