Question about Sewing Machines
Added top feeder foot and material will not feed through. Do i need a diffevent presser foot, than the normal one, to use it correctly?
  • Sewing Machines Master
  • 10,205 Answers
Be sure the presser foot is attached properly. Sounds like you may be using a walking foot. They are pretty tricky to install correctly, so make sure you are following the instructions. Perhaps the following link will help:
Problems installing my walking foot
Posted on Apr 28, 2015
  • 631 Answers
1. Whatever presser foot you use it has a specific job it is made for. It is possible the foot you are using is for free arm.
2. Try to find out what the foot is made for. Look at pictures over the internet to help you out.
3. Mostly wide presser feet are used to pull the material through.
4. Sometimes you may need to increase or decrease the pressure on the feet depending on the material.
Posted on Apr 26, 2015
    Top Expert:
  • 45,365 Answers
Check the feed direction for the bottom section
check that the top foot is actually coming down onto the bottom foot
adjust if not or is the foot the correct one
Not feeding material.
Tension generally does not affect the feed unless it is way too tight. Most reasons for fabric not advancing under the presser foot is that the feed dogs have been dropped for darning. If the feed dogs are operating properly, as the handwheel turns the feed dogs should rise above the plate, move toward the back of the machine pulling the fabric, drop down, come forward and rise again.
The other possibility is that the presser foot pressure has been released so the presser foot is not holding the fabric down on the feed dogs. Some machines have a spring-loaded knob on the top of the machine, a dial, or something to adjust the amount of pressure the foot applies. Consult your owner's manual.
Aug 10, 2015 | Sewing Machines
How do i get the material to feed through
depending on the brand of sewing machine you have, make sure it's not in the darn mode,, make sure the presser foot is against the fabric so the feed dogs can pull it thru,,if the presser foot is against the fabric correctly then the feed dogs may need to be check to see if they need a adjustment or replacing
Dec 02, 2014 | Sewing Machines
Feeder not moving
knotted up thread under the material indicates that the needle thread tension is incorrect ( needs tightening)
once you have that correct the material, will feed normally
use scrap when adjusting and the correct tension is when the top and bottom threads meet at the join ( middle -center )of the materials being sewn
Aug 09, 2014 | Elna 2007 Mechanical Sewing Machine
Seems to be too much gap between pressure foot and tension plate .. material is held loosely
Are the feed dogs completely up?
Are the feed dogs worn or clogged with lint and yuck?
Is there a presser foot pressure setting dial or knob?
Is the correct foot on the machine?
Is the presser foot correctly mounted?
Is the needle plate correctly mounted?
Jun 25, 2014 | PfaFF Quilt & Craft Pro 7530
My janome machine sews on the same spot, the material does not move. I have moved the feeder foot but nothing happens.Sometimes the feeder foot stays down.Idont have a manual for this machine.Igot it as a...
the feed dogs in the needle plate area are what moves the fabric while the presser foot hold the fabric
if the feed dogs are not up, check to see what position are in,,they should be in the bobbin area
if you can't move them they should be checked at a repair shop
Nov 20, 2010 | Janome Sewing Machines
Brother ps 33 material will not feed through machine
Are the feed dogs up and working?
Is the presser foot down?
There should be an adjustment somewhere on the top of the sewing machine, above the presser foot where you can adjust the pressure of the presser foot - left for less and right for more.
Is the fabric under the presser foot when you begin sewing?
Feb 19, 2010 | Brother Sewing Machines
Simplicity Serger pro 432-- feed dogs will not pull material through. They do not come up high enough to catch the material.
The most common troubles with feeddogs not working properly is either lint trapped in between the feed teeth...remove the needleplate and clean out the lint which may look like felt in extreme cases. or... the presser foot tension is too low, in which case, increase tension...there will be a knob of some sort at the top of the machine directly above the Presser Foot Shaft. It is a remote possibility that the feeddog height needs adjusting ...it will have been a major trauma of a severe jam or tugging etc to cause this. As it would almost certainly result in other timings being affected and particularly in the case of a Serger/Overlocker, the added risk of breaking loopers (expensive), I would recommend a service by suitably qualified technician to restore all to optimum condition.
Best Wishes Martyn
Bargain Box in Australia
Sep 07, 2009 | Simplicity Serge Pro SW432 Mechanical...
Material won't pull through feed
you need feed teeth Pulling at a height of 1mm and you need pressure from a presser foot on the top. Check these
Mar 17, 2009 | Sewing Machines
I have an 1130 bernina and love it! with all fabric types the top material is not moving along with the bottom material when sewing seams. the lighter fabrics are puckering and the seams are anywhere...
The 1130 does not have a consumer adjustable presser foot. Check to be sure you are using the correct presser foot .Some feet are slightly different in height which is how the pressure is regulated. If this is not your problem it will need to be seen by a technician.
sewman7
Jul 14, 2008 | Bernina 1008
Sewing Machines Logo
65 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
