Question about Electrical Supplies
How do I fix my fuel consumption problem
The fuel does not last as long as it use to
    Top Expert:
  • Electrical S... Master
  • 51,171 Answers
Fuel consumption in stationary motors relies on the load on the motor, choke position and air filter cleanliness
a rated load on a gen set is considerable less than advertised power rate
that means that if you have a gen set bought at 5.5 kva, the continuous rating is actually 4.5 kva and anything more puts considerable load on the motor and increases the fuel consumption
the difference in the ratings is to allow for the extra surge required on electric motor start up
add up all the appliances that you have going at once and see ti it is close to max out put as that may be a start of you consumption problems
Posted on Apr 26, 2015
How do i fix high fuel consumption
Have a dealer check you computer. That controls the fuel regulation
Mar 09, 2015 | 2000 Mitsubishi Lancer
Hoe do I fix high fuel consumption in my car?
IN order to improve fuel consumption you must make the engine run more efficiently. here are the most important ways.
typical maintenance. (check the manual)
1. check air in tires
2. oil and oil filter change
3. spark plugs change (TUNE UP)
4. air filter change
you personally can do most of these things. go to local walmart and get most of these items. very easy.
good luck.
Dec 19, 2014 | 2000 Audi A6
I have a problem with the consumption of fuel in my fx35 2005
fuel consumption higher driving in the city because you are stopping and accelerating causing more fuel get car in motion.to help fuel consumption problem some, replace air filter,keep check on tire pressure.low tire pressure will cause fuel consumption.
Oct 05, 2012 | 2005 Infiniti FX35
Ignition system mondeo mk3
might try changing fuel filter first...this may fix it.....
Aug 16, 2012 | Ford Cars & Trucks
What is the best mitsubishi lancer 2000 / 1600 cc motor gas consumption ???? last time i checked it was 400 k.m per 41 liter . is it good or it could be better ?!?!?
the factory mileage for fuel should be 7.2 litres per 100km but the fuel consumption will change as the car gets older so its only normal but you could improve on your fuel consumption by tuning the car
hope this helps XD
Mar 05, 2011 | Mitsubishi Lancer Cars & Trucks
High fuel consumption, could it be coolant sensor
I'd be looking at a partially clogged fuel filter first choice. Also check for a possible small fuel line leak. Question for you- when was last "healthy" tune up? A plugged air filter, worn spark plugs and colder weather all contribute to a "high fuel consumption"
Jan 07, 2011 | 1989 Toyota Camry
Hi i have a 318i bmw 2001 my fuel consumption is
Last month, my wife complained of high gas usage as well. I suddenly remembered that I had forgotten to change the air filter the last time I did the oil change. It had been over 5 months since I'd put a new one in. So, we got a new air filter, and monitored the usage, and it was back to normal again. Maybe try this?
Dec 01, 2010 | 2000 BMW 3 Series
My 156 sportswagon is burning fuel badly i put 2 gallons in and only got 31 miles for this i can hear an air leak coming from top of engine would this be a likley cause for such poor fuel consumption it's...
an air leak would weaken the mix of fuel to air so giving you better fuel efficiency but a poor power output.
was my last answer not to your liking, re **** fuel consumption on all fiat/alpha cars.but it is true, ask any owner........14.7 average mpg.......£205 road tax.....(tax it for a year and quadruple its value...)
Jun 14, 2010 | 2000 Alfa Romeo 156
High fuel consumption. only 200 miles per tank
it has gotta be the o2 sensor, map sensor, or the mass air flow meter.............. these are the main inputs to the computer that controls the fuel control....let me know how that works out please
Dec 08, 2009 | 2004 Acura MDX
Planning to buy a 2001 lancer, auto gear...am I doing right?
the lancer get's about 23-26 miles per gallon it is a low maintenance vehicle and as long as you change the oil and do regular maintenance on it the vehicl will last a long time... please rate this
Oct 03, 2008 | 2002 Mitsubishi Lancer
Electrical Supplies Logo
66 people viewed this question
Top Electrical Supplies Experts
Craig Butler
Craig Butler
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
